bigcam112
Members
    44
Everything posted by bigcam112
  1. hi, i am new to the whole db drag thing? if thats even what it is called. how does these competitions work? i would imagine who ever had the most money would win... i mean its not like you can run and make your system louder or anything so since it is all just bought how is there a rightful winner if people just drop thousands and thousands of dollars? sorry it might sound stupid but i really dont understand.. vocab might help me too! thanks
  2. bigcam112
    fi decal
    awww. i was sooo hoping one sticker would at least come with my order. =(
  3. bigcam112
    comp. and how it works?
    so its basically how i thought it might be... just different classes against the same wattage... but then again i think im sure many people have the same setups... i mean there are a lot of go to companies all with different technology but i mean now adays doesnt 1000 watts sound like 1000 watts no matter what subwoofer in the same box? and i mean if you have a car that can hit a high score in db... your car can hit that all day so i mean there is no variable in the next car show. you always going to slam out the same hella high score and beat everyone... or maybe im just sounding dumb.. someone please help me!
  4. bigcam112
    subwoofer wiring
    i was wondering what guage wire i have to use on a Fi BL 12" subwoofer to wire it down... im sure there is a technical name for this but all i know to call it is wireing it down to 1 ohm... so the wire i will be using inside of the enclosure to run it to the terminal for power and what guage i will be running to wire off the speaker to 1 ohm.... does it really matter? i have i think 14 guage "speaker wire" maybe it mean that i can use it for everything wired to the speaker but i dont know for sure... any clearing up of this would help a lot... thanks in advance! i will be running a 1600 watt amp BTW
  5. bigcam112
    subwoofer wiring
    http://sonicelectronix.com/item_8531_Kinetik+HC+800.html is that what you mean? its not too bad on this website price wise. how would it hook up? just take the place of the cap i suppose? and with this would i be able to run 14 volt to my amp all day? or will it still drop?
  6. bigcam112
    subwoofer wiring
    so as far as the extra battery goes... can i just buy any battery? im sure there must be a specialty one just for this application... how is it hooked up? and how much does it cost? if you can post maybe a link to the website so i can just order one that would be great! thanks
  7. bigcam112
    subwoofer wiring
    is there a reason for this? the only thing is, is the fact that my electrical system is soo small in my car they dont even make a aftermarket battery small enough to fit it... and with more power ill be asking quite a few people to get a jump =/
  8. bigcam112
    subwoofer wiring
    this is not even on the same topic anymore but what is everyones take on caps? i have a cap now 1farad monster one... if my lights dont dim when i get everything installed even if the amp has more power than the cap there is no reason to upgrade correct?
  9. bigcam112
    subwoofer wiring
    man it sucks that after i really look at it my "little" project is something huge... everything needs to be changed... ill give you all the stats so let me know if i need to change anything else while im at it... 12" BL, 1600 Watt amp Already changed power and ground to 4guage and now changing speaker wire to 10 guage anything else i need to change while im at it? the guy at the shop said all the other wires running to the amp are all fine... whats your opinion?
  10. bigcam112
    subwoofer wiring
    ok good i also had to change my original number it was 16 guage... so 10 is the best?? and i can use it to wire all of the sub? including wiring it down to 1 ohm and to the terminals and to the amp?
  11. bigcam112
    FI vs RE
    thanks Devil and Flakko for your words of encouragement... thanks to you.. you wont see me on the cover of tomorrows newspaper which reads, "pissed off consumer shoots up local car stereo store"... hehehe.... jk im really not that pissed he just thought he was a dumbass know-it-all...now im ready to prove that guy otherwise
  12. bigcam112
    FI vs RE
    some stupid idiot today at the local stereo shop just got filled to the brim with RE audio subwoofers... i told him i read somewhere that one of the owners of RE is now making MY sub at Fi... he looked at me with the stupidest face and was like nooo, they are owned and operated by the same people they started with i talked to them... like a goddamn smart ass... ill for sure rub it in his stupid face next time i see him..
  13. bigcam112
    breaking in new sub
    i'm pretty sure this a must... actually im definetly sure this is a must... is there anything people usually do to break it in as safely and as quickly as possible?
  14. bigcam112
    breaking in new sub
    Thank you everyone for your help... flakko that sounds like the easiest way to do it and probably most sense making... ill just play it as a normally do i just wont push it beyond its limits.. thanks for your help again
  15. bigcam112
    breaking in new sub
    so basically i dont really have to "take it easy"... you think it can handle being slammed right out of the packing? it seems like to me maybe the same as a car if you treat it good in the beginning it will last longer in the end...
  16. bigcam112
    super newbie ohm question
    ok gotcha.. thanks for making it a whole lot easier!
  17. bigcam112
    Hi, i new to the forums and would for my first post to ask something that even after being around car stereo often i still dont understand.... which is Ohms... say i have a subwoofer that i run at 2ohms with a amp that can run 1000 watts at 2ohms... then i have the same subwoofer that i am running at 1ohm and a amp with 1000 watts running at 1ohm... just the change in ohm with no change to either the sub or amp will the sound be any different or would it be the same? any input helps thanks in advance!
  18. bigcam112
    so if thats the case why do people go lower and lower in ohms? which is i guess "better"?
  19. bigcam112
    BL 12" power handling
    I am planning on buying a BL 12" sub with all the trimmings for xmas... my mom recently bought me a BXI1606D Hifonics amp.... will this be too much power for this sub? i really hope not! =( any input would really help thanks in advance!!
