TZwiers
New Members
    10
Everything posted by TZwiers
  1. TZwiers
    Blown SP415
    I bought my SP415 dual 2 ohm back in October and received it in November and after only 5 months of use, the foam surround is ripped. I can't seem to figure out how this could have happened so any input would be great. Also curious if this is covered by FI's warranty. But here's the setup: -1999 Grand Prix GT Sedan -FI SP415 dual 2 ohm wired to 1 ohm. No spaced spider and no cooling (daily use, didn't see the need) -AQ2200d tuned to 2100 watts RMS using a multimeter -DIYMA oversized 0awg CCA power (appx. 22') and ground (3') with a 200 amp circuit breaker near the battery -Optima Yellow Top -Ohio Generators HO Alt (its an older model but I had them test it and it puts out a minimum of 165 amps and max of 234 amps, and with a smaller pulley it idles at about 200 amps) -Box is appx 4.02 usable cubic feet (after displacement) with sub mounted up and 6" Aeroport entering the cabin -Polk PA660 powering (2) 5.25 Alpine Type S and (2) 6x9 Alpine Type S The electrical is all solid and nothing was rubbing on the sub so how could this happen? The only thing that I could think of is if there were some goofy pressures in the box that were created..but any help is much appreciated.
  2. TZwiers
    Blown SP415
    I know it looks like it is (the clearance was very tight. I had to assemble the sub to the box in the trunk which was extremely tricky) but I checked multiple times for anything touching. The only thing that was close was the foam enclosure I installed around the 6x9s to help the speaker handle the pressures from the sub (which I had to cut out as you can see in the picture). But I'm 98% positive that it wasn't rubbing on anything
  3. TZwiers
    Blown SP415
    eBay sells a ton of high quality foam surrounds (and even more shitty ones) that will fit on the SP415. When your engine needs a new gasket you don't go and buy a new engine, you just fix the part that needs it. Although the foam surround is not genuine Fi, foam surround is foam surround as long as it can handle the massive movement.
  4. TZwiers
    Blown SP415
    Could something like this work? The internals should be fine right?
  5. TZwiers
    Blown SP415
    Hahaha, no joke. "First day of Spring" is next week...pshhh
  6. TZwiers
    Blown SP415
    I've never done a recone before but I am looking into it. I will do anything to not have to ship the sub since that's so damn expensive. Once the recone is done I'll definitely make sure to do it the right way. Thanks to everyone for all the help! Winter is almost done so i hope to have it back and kickin before it gets warm
  7. TZwiers
    Blown SP415
    I just had a friend come over and peek at it too and he literally just said the same thing about the subsonic filter. I thought I had it set right but indeed, I had it set at like 15 Hz or so. The next question is where to get the recone done..
  8. TZwiers
    Blown SP415
    hahaha, thank you azagtoth502
  9. TZwiers
    Blown SP415
    http://tzwiers.imgur.com Couple images of the build and the tare in the surround.
  10. TZwiers
    Blown SP415
    I shot sales@ an email today so I'm waiting to hear back from them. Trying to get a picture up but can't seem to figure it out, makes me feel pretty dumb but it seems like it'll only post a picture from the internet (URL) or from "my media" which I can't figure out. Help?
