mazzasec
Members-
492 -
Content Type
Profiles
Forums
Gallery
Everything posted by mazzasec
I dont understand? How are they not gonna be for daily use but for showing off? So basically your gonna have a badass system and just keep it in your garage? Then when you hear someone elses your gonna go home get your system car and shut them down?
LOL Thats crazy! Yes it does have to do SEC crew. I am with them! Who are you!!!! LOL
Gain 100% full? OUCH! Should have been less then 50% up
Yep I love where I live.!
Yep the 3000d will put out 3000w all day on 12 volts
Im in Atlanta to! You ever come out to the shows? Theres atleast 3 a month!
Are you stuck on JL? There are many other options, a bunch arent as pricey as JL and are equal or sometimes even better then there quality.
250 mechman alt help
mazzasec replied to cjosisek90's topic in Amplifiers / Head Units / Processors / Electrical
Sounds wack to me. So basically what your saying is your alternator is only charging at 8 volts? Double check your grounds. Also do you have 1/0g power from the alt to the battery? -
Saz 3000d vs. Powerbass 3000d
mazzasec replied to DjFreddyFred's topic in Amplifiers / Head Units / Processors / Electrical
Sundownerz! -
I listen to Rap and Hip Hop which sub would be the best???
mazzasec replied to Smallk07's topic in Fi Technical
I was gonna say the Q it gets lower, if your gonna be feeding it 1300-1500 watts (which that RF is capable of doing on good voltage) id get the bp power upgrade. -
Whats your electrical consist of? I heard those RF 1000 can put almost 2000k watts up -
excessive amperage
mazzasec replied to truckaudioman's topic in Amplifiers / Head Units / Processors / Electrical
Trust me Mechman is the best out there! Over on the caraudio.com forums thats who everyone is getting there alts from. He gives you a 50 dollar rebate as well if you use pics of his alt in build logs. I ordered my alt Friday and got it Monday! Mechman is doing worlds wonders for the car audio scene! -
excessive amperage
I hear alot EA is a hit or miss. Go with Mechman alternators! The best IMO! -
MMM powermaster! Tempting!
Ive owned both. The ICON is a very good sounding driver, definetly good for low music. As for BL's I found it that my 15" BL's had problems hitting the lows. Anything 38hz and lower the BL's had problems getting loud. If you just want output get the BL's they sound decent. If you want low and sounding good get the ICONS.
Ok well the old setup is in the Sig. New setup will consist of. H/U - Still chitty sony one Front Stage: 2 Sets of PG RSD's Front Stage amp: Sundown 100.4 Sub Stage: 2 18" Fully loaded Fi BL's dual2's Sub Amp: Sundown Saz3000d @ .5 Electrical: 4 Deka Intiminators and a 250 amp Mechman alt Wiring: Kicker hyperflex So far I got 2 Dekas and an 18" BL on the way. First pic there 2 of the batteries the 3rd should make it a perfect fit all the way across and the 4th battery will be under the hood.
Two ICON 10s Found a new home today
mazzasec replied to Mark LaFountain's topic in Sound Solutions Audio (SSA®)
Dang! Thats a big box for 2 tens! -
SSA Icon 10" Test Enclosure (breaks 140db @ 24hz!!)
mazzasec replied to Thumpper's topic in Pound That Sound
Did you get my PM Thumpper? -
Need some opinions! I am gonna be running a 3000d. I am gonna have good electrical. Should I stick with the 1ohm load and see what kind of power I can get out not dropping below 13 volts or since I have the electrical to back it up go with .5? What kinda power difference will I see?
Dang awsome numbers! So whats the box tuned to?!?!? -
Alright well right now I am running it on my stock alt at .5 with volts dropping to 11.8 I dont do it all day daily. Ill play it a couple songs feel it to see how warm its getting then back off for a good bit. Went to a local comp and burped a 148. What kinda output is the 3000d putting out a .5 on 11.8 volts? And what kinda output gain will I see at 13.5
Well currently I have no room in the back of my SUV. So the only option to mount the amp is on the box. My box is subs up port back. I have room on the top to mount the amp. I put a couple coins,keys, and other chit on top to see how bad it vibrates. It definetly vibrates, but will it be bad for the amp?
Ya ive owned BL's to. Not once did I say to myself "man these subs sound bad". They get loud and dont sound like complete poo! Good subs!
Its a 3000d. Also the top is 2 layers of MDF.
Your volts dropping to the low 11's?
