slim2fattycake
SSA Regular
    3,046
  • Days Won
    7
Everything posted by slim2fattycake
  1. slim2fattycake
    Comp box for 2 15" type r's
    fixed.
  2. slim2fattycake
    Too much Amp for a SSD12?
    eh, you're going to waste money for no difference if you go from the ap1500 to an saz1000 but its your system and money.
  3. slim2fattycake
    1hz difference noticable?
    The ear can hear a difference between 1hz frequencies but cannot hear the difference between box tuning of 1hz.
  4. slim2fattycake
    2 21" Wardens
    hahaha what a tool. what was his system? nothing, right? that's why he's talking.
  5. slim2fattycake
    Quote for psp ports
    Thanks. So two 6" couplers, two 6" flares, 12 4" couplers, 6 4" inside flare, and 6 4" outside flare.
  6. slim2fattycake
    Help choosing a sub
    dependent on your box but both should be able to get down low. The Q is designed to do it easier though. It's up to you.
  7. slim2fattycake
    Lanzar amp
    If you want to stay under 200 then you can get a audiopipe ap15001d for 150 or an audiopipe ap18001d for 190.
  8. slim2fattycake
    Help choosing a sub
    You do know that Fi has a website that you can buy direct from. They also don't have dealers. AA is the dealer side. You can wire either one to 1 ohm. It depends on the coil configuration you get. You want to get dual 2 ohms to wire a 1 of the to 1 ohm.
  9. slim2fattycake
    don't forget to use your subsonic filter.
  10. slim2fattycake
    16v system ?
    where is this?
  11. slim2fattycake
    Lanzar amp
    The only lanzar I'd get is an opti drive.
  12. slim2fattycake
    Help choosing a sub
    it depends on the volume of the box and the power. You may need subsonic filtering even in a sealed box. I think all sub amps need to have this feature. I hate those fixed subsonic filters as well.
  13. slim2fattycake
    Help choosing a sub
    It looks to be dual 2 ohm so you can wire it down to 1 ohm to your amp.
  14. slim2fattycake
    Help choosing a sub
    What is the coil configuration of your 15s? Also, you can do 3.5 cuft NET tuned to 35hz with a single 6" aeroport about 14" long if you have the space. Sub and port displacement should be around .35 cuft and a couple of wooden dowels shouldn't take up anything really.
  15. slim2fattycake
    Help choosing a sub
    As long as it fits in the trunk and I can get to the spare tire in case of a problem whenever I need. that doesn't tell me anything. Its not like I have your car in my garage. Did you build the box for the two 15s? What's the dimensions on that box? You may be able to get a ported box with the same dimensions as the box you have now.
  16. slim2fattycake
    Help choosing a sub
    Fi doesn't have dealers. You're thinking of AA. What's the maximum dimensions you want to give up for a box?
  17. slim2fattycake
    Help choosing a sub
    I say try to flip it around to where the subs face into the cabin and see what its like or build a box for the one 15. I still think 2 15s sealed is louder than 1 12 ported on the same power if your not in depth about firing and position testing. Those subs look to be pretty good subs. I have always wanted to try the 8 or 10s. If they're rated for 1000 watts then why not use one and sell the other? you can get a ported box for a 15 with an aeroport in there. If you can get a sealed box for two 15s in there. It would save you money or more than likely gain you money but still get you the goal you want. And really make sure that you like LOW bass or high 30s to 40s bass. Lots of normal rap songs peak in that range.
  18. slim2fattycake
    new theater sub build and more
    Well I picked up 10' of 6" pvc and waiting on argent to get a quote for the flares but if I cannot get a quote by next week, I'll just buy them somewhere else. I may not have two 18s to play with now because after reconing both the 18s, the ixl still had slight rubbing or some type of noise when I pushed down on the cone. I really don't know why. I checked gap and spacing and there was no motor damage so i cannot figure it out. However, I can always do a 12" build for music if I need more up top from the avalanche.
  19. slim2fattycake
    Help choosing a sub
    NVM
  20. slim2fattycake
    About Stetsom Amplifiers
    uh oh. sound digital in the house.
  21. slim2fattycake
    175db on music
    That is an epic picture lol. and 24 current viewers
