95Honda
SSA Tech Team
    2,231
  • Days Won
    39
Everything posted by 95Honda
  1. uggghhh... THERE IS NO SUCH THING AS OVERSIZED AWG(!)... They are either, #1 lying and miss-labeling the cable, or, #2 Just plain lying... Again, for the 20th time, AWG is cross-sectional area...
  2. 2X 1/0 = 107 mm^2 1X 4/0 = 107 mm^2 If you compare the 2 runs of CCA to the single run of Copper (the same cross sectional area) the Copper will absolutely destroy the CCA by a HUGE margin....
  3. "2x 1/0 CCA has the capability of being just as strong if not stronger than 4/0-300MCM Copper." God dammit Shizzon, check you math before posting things like this.... THIS IS NOT REMOTELY CORRECT!!!
  4. 95Honda
    best sq sub under $300
    Doesn't really help to throw out an RMS rating of the sub, it doesn't have anything to do with what you are looking for, and doesn't mean/correlate to anything... Best budget "SQ" sub on the planet right now would be a Parts Express Dayton HO/HF 12 or 15 driver. Less than $150, IIRC...
  5. Just make sure everyone understands a few things from this thread: CCA and Copper of the same AWG are the exact same size. CCA does not have the same current carrying capability as Copper of the same AWG. The copper coloring of CCA is very thin plating that doesn't really help much. It is mostly there for looks. There are no performance advantages whatsoever for CCA. CCA has more resistance and therefore voltage drop of the same AWG Copper cable.
  6. ^^ No. Welding cable is not 2X as expensive as CCA.
  7. 1/0 aluminum is the exact same size as 1/0 copper, unless one manufacturer is lying. AWG doesn't change based on conductor material. AWG is not based on current carrying capability, it is based on cross sectional area of the conductor. This doesn't change when a different material is used. CCA is aluminum and is garbage. It is a marketing gimmick. Copper cladding on the aluminum is used for looks as there is no skin effect with DC to make the cladding worth anything.
  8. 95Honda
    2 fi ssd's
    The RMS rating has nothing, I mean absolutely NOTHING, to do with how much power your subwoofer(s) will require, period. No such thing as underpowering, either... You'll be fine with just about any of the amps you are considering.
  9. Physical construction may be different, that is it. The cross-sectional area of copper will always be the same unless the manufacturer is lying, which is almost never the case with welding cable, especially cable that has been rated by a reputable US third party. Swap-meet garbage "car audio" power cable is where you run into erroneous AWG identification ... You saw it (mistake) on this site last year with a cable comparison. O.D. of the conductor portion was measured. This tells you absolutely NOTHING when dealing with straded wire. NOTHING. The only way to make a meaningfull comparison is to measure the AWG of the individual strands and then count every single one. If you don't do that, don't even try and compare cable.
  10. Are you joking? This is one of the most idiotic things posted in some time. AWG is AWG unless the manufacturer is lying. Welding cable will always meet AWG spec, car audio may not...
  11. 95Honda
    Carver Amplifiers
    I have used maybe 3 or 4 pairs of those tweeters. Hard to beat for the price. Will handle a fairly low crossover point as well.
  12. I put "Car Audio" batteries along with "Car Audio" power cable. Mostly marketing hype and paying for soemhting that looks really neat... Seriously, screw up the Walmart battery and just take it back, to any Walmart, get a fully charged battery in return. Try that with anything else...
  13. Unless weight is a concern, the biggest battery Walmart sells with crush anything 3x it's price. You can also bring it back anytime you kill it and swap it for a new one...
  14. 95Honda
    Clipping
    That and the fact that clipping doesn't hurt anything.
  15. I certainly does not. bcae1 has not (or anyone else has published on the web) objectively tested actual driver failure like I have to back this up.
  16. 95Honda
    ofc and cca wire
    The overall thickness has nothing to do with the amount of conductor cross-sectional area (Awg).
  17. 95Honda
    ofc and cca wire
    Additionally, you can never correlate overall physical diameter to actual gauge. This is another reason people have no idea what they are talking about when they compare wire. CCA is a marketing gimmick. If you are running it, you fell for it. Plain and simple.
  18. 95Honda
    ofc and cca wire
    ^^ You are making a subjective assessment, and it is useless.
  19. 95Honda
    ofc and cca wire
    Well, they obviously know what they are doing with everything, except DC current transfer.
  20. 95Honda
    ofc and cca wire
    There is never a reason, ever to use CCA other than wanting to see a big ass diameter wire for a cheaper price. It is 100% gimmick, seriously. You can't make a blanket statement like 50 amps less, or pushing the wire to it's limits. The variables in comparing the wire vary much more than that. Aluminum wire of the same gauge as copper (CCA or just plain aluminum) is inferior in every way at every current level. It Is more brittle, more prone to connection interface loss, and greatly inferior as far as cooper loss (resistance). You can tie 00 welding cable in a knot smaller than your fist. If you ever do an install with a bending radius less than that, you are asking for trouble with any type of wire. Welding cable will also handle heat, abrasions and chemical wear better than ANY car audio power wire.
  21. 95Honda
    ofc and cca wire
    CCA is a gimmick brought out by car audio companies. It is 100% not worth the money or time. People who will tell you otherwise do not understand how current flow through different metals works...
  22. What does the RMS have to do with anything?
  23. 95Honda
    FI SP4 Inverted Motor Noise (wtf)
    If it is loud as you say it is, something is wrong with the sub.
  24. 95Honda
    Best 10s for me?
    Those boxes are horrible. You could have a better design for those same drivers in that trunk...
  25. Any time you make the box smaller, you loose overall efficiency.
