2,231 -
Days Won
39
Content Type
Profiles
Forums
Gallery
Everything posted by 95Honda
I would also try it without the rear set connected. The load will be easier on the amp, the front set won't run the amp into hard clipping as easy as both sets connected... Image will probably be better also. I would put the better of the two sets in the front. Also adjust the HPF as the other guys have stated...
LOC gain question
95Honda replied to lakaiguy's topic in Amplifiers / Head Units / Processors / Electrical
The problem is, most people have no idea how to properly use an scope. If they did, then you would be spot on... -
LOC gain question
Just remember, the RMS power has nothing to do with how loud the sub is, how much power it needs or anything else output related, at all... -
LOC gain question
^^ No. Your ears are your best friend... -
Also, please don't take my views as a simple bash on the guy doing the test. I am only basing my opinion on experience. I just finished up a 2 year tenure here: www.afotec.af.mil I was a suitability evaluator. Basically, I evaluated electronic systems for the military. I used extensive amounts of test equipment and completed objective test reports on military space assets, in other words, I know what I am doing. This is why I have a tough time with a lot of "car audio" tests...
LOC gain question
The gains at any position is absolutely fine... -
Model and look at response. If there isn't a huge difference, just get whichever one you can get a better deal on...
Testing not done in accordance with manufacturer specification, un-calibrated cheap test equipment, questionable load (I couldn't see it)... I have never tested any IA equipment so I cannot comment on their quality. What I can comment on is a meaningless test. This is the problem with the mobile audio world...
This will be a good chance for you to use the skills you have learned here. Carefully measure the enclosure dimensions and model it with your driver. -Find out what the vent velocity will be. -Actually verify the tuning. You have no idea if it was even designed right in the first place... Here is your chance to do this right...
12" Xcon in 4th/6th order bp, T-line, Horn?
95Honda replied to jazzy's topic in Sound Solutions Audio (SSA®)
I doubt you will get much feedback on a transmission line or horn, they are hardly ever used in mobile applications... Your best bet for the bandpass alignments will be to model the driver, most impressions you are going to get will be subjective... -
German AGM's
95Honda replied to Billetproof97''s topic in Amplifiers / Head Units / Processors / Electrical
That is the advantage if you pick them up at AAFES, if you aren't happy, just take them back... I would also see if they can get anything besides Optima, you never know what they will order in... -
Enclosure reccomendations for a single Zv4 15
95Honda replied to DedicatedEnthusiast's topic in Sundown Audio
Don't ever, ever design an enclosure to "handle" a certain amount of power, especially by making it smaller. You loose efficiency, increase compression and decrease bandwidth. It never makes anything louder, you may think so, people may swear to it, but they are wrong. Design the enclosure with your response goals in mind and your available space. The power is the last thing you figure out, because you may not actually know how much power you need to get full output from your alignment until your enclosure is complete. Additionally, except in DSS's case, RMS has nothing to do with power requirements. It is a thermal rating. IT HAS NOTHING TO DO WITH POWER REQUIREMENTS. IT IS A THERMAL RATING ONLY. It is only a thermal rating. -
German AGM's
Optimas are one of the best batteries out there. If you hear a bad review from someone who does an objective test I would listen, to everyone else, I would not. Look at every large diesel generator we run in the AOR... Almost all Optima starting batteries... -
German AGM's
That isn't too bad I guess. Have you checked the BX/PX? They sell Optima and can get many others, there is no shipping charges if they order them, either... Pair of Optima batteries would be cheap, and it is AAFES, so you could just bring them back if it doesn't work out and get all your money back... -
Try to stay below 20 m/sec, which should be easy, even around tuning. And honestly, you probably will be fine, in a car, with higher velocity...
OK, model with that amount of power, Shoot for low enough vent velocity. It won't be too tough to get a slot port in a box that big, 30Hz isn't really too low at all...
German AGM's
How much are they going to cost? -
There is no rule of thumb, especially if you don't know the power you will be applying to the driver. Have you modeled yet to see the difference between the two boxes? You should really do that before cutting any wood. And if you do indeed end up with an 8 cubic foot box, that is big, you should have no problem with an adequate vent for a single 18" driver...
3 amps, 4 LOC's, 2 tweets, 2 mids, one crossover.
95Honda replied to re-sx-18-d3.2's topic in Advanced Discussion
Seriously, if you are going to be a prick about everything you won't last on this forum. Please take this as a warning. -
Reading comprehension? Seriously? Bro you are talking to a couple of guys with engineering degrees. We are trying to help. Narrow your question down, don't be a smartass and we will try and help. Post a bunch of garbage and you will won't get much help... -
In this case, advice falling on deaf ears is two-fold... OP: Hook all your stuff up, if it sounds good to you, go with it... -
I would also sell the 3-way and buy a high quality mid-bass and tweeter if you are going active... If you don't have an 8" or larger driver, there is no reason for 3-way, pretty much most of the time...
Objectivity is out the window with most car audio... People who don't understand what is actually going on perpetuate all this BS.
The RMS rating of the drivers has nothing to do with output or matching, at all... I would start simple with a single 2-way up front. Get that right and move on from there. I wouldn't even mess with the sub stage until you get the 2-way sounding right... -
.9 total Q is A-OK for IB...
