puscifer2
Members
    307
  • Days Won
    2
Everything posted by puscifer2
  1. You did know ssa is a zed vendor right? Your questions could be answered right here. Just an FYI
  2. puscifer2
    2 12 dss ethos (new build)
    I said the same thing when I first got my setup rolling. It will continue to impress as time passes.
  3. puscifer2
    Welcome to the IHoP v.2
    Hey Sean... BAM! This came into the shop today. 6" lift and 305/35R24. What the pucking fuck???
  4. puscifer2
    By far the best concert I have been to. I've seen them twice now. The version of indigo children they played, i have been trying to find ever since. It was beautiful.
  5. puscifer2
    LOL Dirty Mofo! The whole thumb?Once I had the thumb in there already, I just said fuck it and went fist deep. I mean, what more could I do?Milk the prostate! Supposed to let a cute Asian chick do that.May have to take him with you on the next trip. Before it becomes a personal problem
  6. puscifer2
  7. puscifer2
    http://i.ebayimg.com/00/s/NDE3WDU2Mg==/z/-IQAAOSwv1RUZAD~/$_1.JPG The map sensor just sits on the top of the plenum. As far as the distributor, it has a keyed mount. So unlike old school designs it cannot be changed. However, when it was installed they could have it 1 or so tooth off and the computer can no longer compensate for it. Not saying that's the problem it has. I am personally curious about the catalytic converter. There is a back pressure gauge you can get to check pressures on either side of the cat.
  8. puscifer2
    J the advice I posted was from someone with exactly the same symptoms as you describe on a similar engine build. Wild cam, bored, stroked, ported and polished. Used to be a 289. Ended up closer to a 360cu in. Holley carb. Just like you he step by step adjusted the carb for our altitude, timing and the like. That's what worked for him.
  9. puscifer2
    J - been talking with some old school techs. They tell me you should shrink the gap on the linkage to the accelerator pump. So it will react faster to an on demand WOT.
  10. puscifer2
    Stock cam? Does it fall instantly, or gradually, or at high rpm?
  11. puscifer2
    FT1 Tweeter question
    I think your overestimating how loud your sub stage will be. Normal tweets that come with a component system would suffice. I'm running 2 12" dss ethos on 3k. With crescendo comps. up front. Trust me they do fine.
  12. puscifer2
    May I ask HOW are they a hazard? How is silence from the outside bullshit dangerous in your opinion?These are literally being purchased just for the gym. Maybe a flight if ABSOLUTELY need be as well. Just wasn't wanting to take the 'back of the truck' Ferrari beats to the gym. I don't sit around and listen to headphones, nor will I be running with them.JAnything wireless has a battery. It adds weight to your head. If it's over ear or around ear it will be heavy as Fuck. Any exercises where your head moves and they WILL come off at some point. The headstrap is usually an inch over your skull and gets banged by stuff. You sweat and it grosses up the whole unit, makes in slippery....I don't care about noise cancellation as a risk, in ear monitors cancel better than anything anyway.In ear monitors are the most out of the way solution. They are purpose made for you to sweat and move like crazy but not get in the way. The added weight and size of wireless cans make absolutely no sense to me.I never have had a problem with my wires beats which have batteries as well. Never had an issue with banging the top of my dome while lifting.JYou aren't lifting hard enough.LolI kid I kid.Let's put it into perspective, if musicians don't use wireless headsets, but use in ear monitors because it's more ergonomic why should you.If you don't run, jump rope, jump around or move quick then maybe the wireless can work. It still isn't optimal. Even if a musician is using a wireless audio receiver, the headphones are going to be in ear monitors.They just work better for a situation where you are moving.You gotta do you , but some good in ears with a good wire will not only outlast and outperform wireless headsets, they will also get out of the way more.On the ears are useless always. Only two options. Over the ear or in the ear. For any situation with noise I'd much prefer the ITE.No running or jumping around, literally lifting weights, stretching, and maybe once in awhile some stationary bike riding. Thats it.I can understand the logic behing ITE, and if I Could find any that fit comfortably,I would give them a try. I just have yet to ever find any. Over the ear, is insanely comfortable for me. J http://www.bestbuy.com/site/jbl-reflect-bt-earbud-headphones-black/5633063.p?id=1219144863943&skuId=5633063 These are what I use at the gym. Even on the treadmill they don't fall out. I used to use my westone lm pro10's only down side was the cord
  13. puscifer2
    Since I need a new one though.....HTC has been my jam for a good while. not this year, they got leap froggesWhat does one buy then??I've been hearing rave reviews on the new nexus
  14. puscifer2
    I bought the debut album. Really liked "solitaire unraveling." They just started getting worse and worse from there. Nice reference to gwar tho. They are pretty similar musically these days.
  15. puscifer2
    Are we talking Slayer or Cannibal Corpse?Just sayin if you were to start jamming with reign in blood, you may get a crowd
  16. puscifer2
    Nothing says GTFO like a sawed off...
  17. puscifer2
    Nitrogen is used for two reasons, first it's a bigger molecule than air so it doesn't lose pressure. Second is pressure fluctuates with temp, nitrogen holds a more consistent temp. So unless it's for racing or extreme conditions it's just a gimmick rather than help.
  18. puscifer2
    Advice on 3 way front stage
    It has less to do with location than how it's mounted in that location. Don't get me wrong you can definitely change the staging by moving the driver to a different spot, but a properly installed speaker will be far more effective than just a simple swap over.
  19. puscifer2
    My parents bought toro when they first bought their house 30+ yrs ago. I finally bought them a new self start toro because they couldn't pull start anymore. Damn good machine!
  20. puscifer2
    More info needed. Start with "tried deadening" what did you do?
  21. puscifer2
    FAR FAR better coverage in slc than any other carrier. Not sure why tho.
  22. puscifer2
    not watching porn nor opening attachments from shady sources or internet unsaavy friendsThat's what I don't understand. I was shopping for a new phone on att&t's website. First and only thing I had done after I upgraded ram, hdd and windows.
  23. puscifer2
    Just for surfing around or do you have specific concerns?I'm totally spacing my general security software. I'll look it up for you though. Had a very sketchy blue screen telling me the computer needs to restart. Once it finished I killed the Internet and fired it back up. Seems to work fine just don't want to risk it. It's windows 8 if it matters.
  24. puscifer2
    What would you guys recommend for an anti virus?
  25. puscifer2
    sq of the judge
    Fi Q?? Or I believe the death row is along the same vibe
