creatormass
Members
    188
Everything posted by creatormass
  1. creatormass
    specs on FI subs
    Depending on how your sub was built, it could be made to handle more power. I bought a pair of 10" BL's for SPL, the rating says 1000 watts rms, but I had them built to handle much more. They should be able to handle as much as 5000 watts each on a quick burp. I've been pushing over 2000 watts to each with no issues yet.
  2. creatormass
    box for a 88 s-10 blazer
    According to the recommendations in the pinned topic they require 1.8-2.5 cu ft per sub, plus port displacement. Have you got the room for a 4 cu ft box in the Blazer? In my S10 Blazer if I make a 4 cu ft box I'll be going way over the window line in the rear. I'm not sure what a crx style box is supposed to look like, all the crx enclosures I've seen were round tube style enclosures. I'd do a standard rectangular style box with the subs and port facing the rear door. For comps you'd want a different placement, but for street that's going to pound the best. Just make sure you leave a few inches between the port opening and the door.
  3. creatormass
    Your db Numbers
    2001 Chevy Blazer Excessive Amperage 200 amp alt, Optima Yellow top under the hood and a Kinetik 2400 in the rear. MA Audio HK4000D Two Fi 10" BL's 1.5 Cu ft tuned to 49 Hz Termlab Burped at 52 Hz Highest Score on the floor was a 149.2 in USAC Stock 601-1800 A 147.0 with DbDrags Street A
  4. creatormass
    Whats better then having a 150db+ daily driver?
    if your gonna get rid of the 15's see about picking up some 18" T3's. As long as you don't wall them you'll be in a different class than Rooney.
  5. You should be ok with just a single run of 0/1 gauge, it won't hurt to add another one but I don't think it's going to be necessary. The battery in the rear will be supplying almost all the poweer needed for your system, the front will just give it a little extra in case you run low.
  6. creatormass
    break in
    I've heard that the break in period is just a myth. I've never "broke in" a sub, just hook it up and let them rip.
  7. creatormass
    10" BL enclosure
    I have a pair of 10" BL's. I'm running these with an MA Audio HK4000D, I've been running it at 2 ohms so they'd get about 1900 watts each. I'm planning to drop the ohm load to .5 and send them more power, at least 2500 watts each. What would the recommended enclosure size be for this increased power? I'll figure out the ports and such after but I want to know what size enclosure would be right for that amount of power.
  8. creatormass
    can fi compete?
    Sounds like this might be along the lines of that MTX joke, the JackHammer.
  9. creatormass
    How did you guys find SSA???
    I think I found this in Fi Car Audios Myspace page. Figured I'd have to sign up, hardly anyone in the Myspace groups have a clue about Fi's.
  10. You don't need to fuse a ground, no need for it. And you didn't really finish your battery question.
  11. creatormass
    Nice to see you got it already Marty. That thing was pounding pretty sweet when I saw it at SVR this year. You planning to compete with both next season? You'll have to register one under your gf's name.
