poundindak69
Members
    726
  • Days Won
    1
Everything posted by poundindak69
  1. poundindak69
    just a little overboard on this build
    thinking about picking up enough wire to do the big 3 this week before the amp gets here might have some pics up. would i be good i used the 4ga i have laying in my truck for the big 3? i possibly could double up on it on every part if needed cause that save me some money at the moment. and should work on grounds in the back also. then well have
  2. poundindak69
    yeah i know what you are saying. im gunna get the big three finished then maybe pick up a new battery for the front then see were i sit. and after that ill upgrade as needed.
  3. poundindak69
    Congrats. Now step up that electrical. oh thats the next step :), will probably run the 3500 turned down for a little until i get everything i need, then let them see some real power . i would like to find one or two more sprinter batteries like the one i have so i dont have to change that one out. and do you think id be fine with a stock 130 amp alt at this moment with 3 batteries on it and 1/0 everywhere? Hard to tell. All you can do is hook her up and monitor your voltage. You might only need two batteries btw. One for starting and one mounted near your amps. Batteries wired in parallel, same make/model I assume. The reason I say only two batteries is because batteries can be counter productive in this situation. A depleted battery or a battery that needs a charge will be an additional load on the alternator. You might see a voltage drop and assume your amplifier(s) or installation is the culprit but it could be too many batteries loading on your alternator. Check out this video thanks man for the tips and the link. i guess ill see what happens.
  4. poundindak69
  5. poundindak69
    just picked up a SAZ-3500d!!!!! cant wait for it to get here.
  6. poundindak69
    Happy Birthday Don!!!
    :drink40: happy birthday !!!
  7. poundindak69
    MECA Finals Death Penalty Rebuild.
    looking goood!!
  8. poundindak69
    yes i am, and i dont have any idea were to really start with speakers, would i be able to just hook up the amp and then run the speakers i have now? what confuses me the most is the active passive stuff. Powering speakers passive means that the signal going to the speakers from the amplifier has to pass through a crossover first. You can have a full range signal going into to the amplifier and a full range signal coming out of the amplifier and crossovers packaged with the component set will divide the frequencies for the speakers. Commonly when you buy a two way or three way component set they are packaged with crossovers. This is the most common method when adding a component set. It works well and sounds good. Passive component set Powering speakers active means that the signal coming out of the amplifier is already crossed over (signal is divided for the speaker being used). So this means that the speaker you are powering is directly wired to the amplifier without a crossover in between the two. Some people buy amplifiers that have the crossover circuitry in the amplifier. Other people buy separate crossovers or signal processors that divide the signal then the signal goes to the amplifier. When running active you can choose to use speakers from multiple manufactuers and an assortment of other options are available that you do not have with a passive system. Speaker selection and crossover frequency points can be difficult when running active. Using a passive component set can be easy and for most people they are very pleased. For your first setup of this multitude running a passive soundstage would probably be your best bet thank you very much for the info, helped clear all my wrongs thoughts on that stuff, lol. and ill run them passive as the speakers im using have crossovers with them.
  9. poundindak69
    alright sounds like a plan, ill look around here and see about picking up a nice 4 channel and a bunch of wire. and see were i get.
  10. poundindak69
  11. poundindak69
    voltage is pretty steady but do plan on upgrading to bigger amps in the near future. and i dont plan on switching this setup for a while . and for front stage were would you start? i mean at the moment i have upgraded speakers that i got with the truck. should i just add an amp and see if i get any improvements? or should i switch two different speakers all together. i was also thinking maybe looking into get 8" aeros and switching them out with the ports i have now.
  12. poundindak69
    trying to think of what to do next on this build, should i start with addin to my electrical or build beauty panels for the box. work on the front stage a little?? idk and ideas im open for, so please so some input. cause im kindof of just stuck at the moment.
  13. poundindak69
    db-r Customer Service
    so when are you gunna let me have that
  14. poundindak69
    SSA Member Meet (East Coast)
    im down for driving anywere to meet some new people!!
  15. poundindak69
    DROP IN TEST DD vs. Fi
    warching this
  16. poundindak69
    Team SSA / Decent GEO SBN Video
    yummmy
  17. poundindak69
    XCON 15 flex'n my Hyundai
    looks loud!! and love the face cd player cover.
  18. poundindak69
    1998 Chevrolet Silverado Z71
    good looking box man.
  19. poundindak69
    been really busy the last few days gettin ready to leave town for work, so i havent been able to shoot any vids for you guys. but i will try once i get settled in philly( if any one is in that area and want a demo hit me up) and ill try and shoot some more vids and hopefully work on it little by little .
  20. poundindak69
    ill try and get some music like that in a vid for you.
  21. poundindak69
    haha Big Tymers - Get your Roll on alrighty ill see about a different camera today also
  22. poundindak69
    i really need to use a different camera, my phone sucks
  23. poundindak69
    whats a good site to download songs since limewire has got shut down?
  24. poundindak69
    so anyone got any songs requests?? gunna try and grab a few better vids today.
