loudcav
Members-
830 -
Content Type
Profiles
Forums
Gallery
Everything posted by loudcav
Im not a smoker but being around them dose not bother me in the least bit. if you dont like it perhaps you should concider moving somewhere that has a smoking ban
in that case use the maxx link you can use it as a gain matching device and a line driver to boost your output make sure if you are just useing it to gain match that you only use the posative outputs if you use both the posative and negative it wont work
Anyone ever heard of a brand called Brand X?
loudcav replied to reaudiofreak85's topic in Amplifiers / Head Units / Processors / Electrical
deffinatly 8000 watts maxx hell it only has 2 180 amp fuses that should tell you right there that it can only do 8kw if it was struck by lightning -
maxxlink dont use it to strap use it to gain match
deffinatly needs 6s maybe even 8s you need to fill out those monster wheel wells
Id go with a D3400 under the hood should slide right in you will want the I-bar to addapt to the side terminals then Id go with anything from the D2400 to the D3100 in the trunk
Indy Slamology 2009 June 20-21
loudcav replied to mccleery3's topic in Competitions & Other Organized SPL/SQ Events
I dont think Greg is doing USACI besides you really never have to be a member of any org to compete unless its finals -
not a bad idea but Jacob wont do 2 versions he would end up doing just the Sundown Audio remember he would rather stick money into developing equipment than clothes
that is going to be one nasty Excursion
it accepts up to 1/0..but you aren't required to use that size wiring you really should use 1/0g wire I cant and wont recomend smaller wire than 1/0 unless its a short distance from the battery to the amp and even then 1/0g is the best
how high do you have the low pass? I usualy keep mine pretty low
fairly close to me Im a bit south in London
I think hes more dissapointed that a couple years ago he had 4 L7 15s off a MA 4k doing almost a 150 in the truck as it is
I ran one of my old case 3000ds at 1/2 ohm for a wile only reason I did tho was I wanted a single amp and my options were 2 or 1/2 ohm the amp ran fine deffinatly was more efficient when I ran a pair at 2 ohms 1 ohm each tho
hes got more than enough power for now 2 2200s should be fine for a lil wile atleast
I think Jacob has it on the site that you can down load it
Budget? the astro can get stupid loud and has the ability to pack alot of gear
you can also buy one off your local rep
a few SQ guys run the amps the nearest SQ guy to you is Alpine Andy and hes in Lafyette Indianna
its kinda like my truck truck did like a 132 but it sounds alot louder
I would think that you could paint them just make sure you dont get any inside Id think it would be more of a hassle than its worth
Hey Jacob I predict you will get a phone call from someone looking for 8-12 3500Ds
Im sure Jacob would inclued the glue for a small fee
Nightshade.. physical similarities between original, and newer
loudcav replied to 01 S 10's topic in Sundown Audio
it depends whos it was Ive got a pair of much older nightshade 18s that are upgraded the motors are from the very first shipment -
Ill probably be wearing a few diffrent shirts that weekend a Sundown one a memphis car audio one and if he gets me one Ill have on a Loud enough to bang in pink one
