loudcav
Members
    830
Everything posted by loudcav
  1. loudcav
    SSA FORUM NEW LOOK
    How do I change back to the dark one most forums Im on are dark I like dark
  2. loudcav
    cavalier wall work log
    ok Im back to working on it a bit sprayed a bit of foam in some areas to deaden it a bit and I went and got some shorter screws for my seatbelt still had to cut them down a bit tho. well and I got the first layer on part of the back wall here thursday Ill probably run and get some 2x2s so I have a place to screw the pieces that are gonna form part of the angle on the back and side walls. the last pic is how I secured thebottom to the floor when Im done theres gonna be 2x4s verticly bracing the back wall should be very strong when Im done
  3. loudcav
    Where did the E8s go ?
    so Jacob whos are they?
  4. loudcav
    to my house?
  5. loudcav
    Sub Suggestion
    Good to know Jacob. I guess I'll go all Sundown, you have always supported me. ya hes good to his team members
  6. loudcav
    Sub Suggestion
    lol Jacob I played music on a stock one free air lasted a couple minutes both of my 3ks strapped to it
  7. loudcav
    Sub Suggestion
    Do you think the death penalty will enjoy 6k watt burps? Im not sure mabe talk to Chad hicks
  8. loudcav
    Sub Suggestion
    why would wayne shoot the DP 21 down? someone has a jackhammer
  9. Gotta love them B stock nightshades I know on one of mine atfirst when I looked at it I thaught he gave me one that was A stock
  10. loudcav
    ok you all suck !>?!?!?!?!?!!?
    out law is in the passenger foot well port wars is at the mouth of the port and super port wars is measured however far you can throw it back in the box
  11. hey Jacob roughly how many of those 15s do you have? I may know someone intersted in 4
  12. loudcav
    wow is tonight the night when all the morons comeout?
  13. loudcav
    Installing Powermaster 1200
    honestly in mine I just use the bolts like what came with it if I need longet ones I go buy them they are like 6mm if I remember right
  14. loudcav
    First Comp.... First Place
    I never heard how you ended up through it I saw the pic of you sitting on top of it
  15. loudcav
    well both sides have one layer on them and I was able to get screws on the top and one side of each piece now I just need to find a good way to join the 2 pieces together I dont really wanna resin this early in it but I may have to right now Ive got a tube of liquid nails around each one
  16. loudcav
    ya its going to take a wile but now that I think about it I know how to make that piece around the window solid Ill pick up some fiberglass matt and glass it into place
  17. loudcav
    got the first layer on on the one side the piece covering the window is just held in with liquid nails right now Im trying to figure out how I wanna hold it in Im trying to stay away from using screws in that area because if I miss the small lip Ill put one through the glass Ill probably use some sort of a putty to hold it may try and overlap the next layer
  18. loudcav
    its deffinatly gonna be a long build since Im not used to wood working and its my first attempt at a wall I should be able to get it to look alot better in the final layers should be more twards the B pillar and flat this layer is just a base so it dosent have to be perfect. those wheel wells arnt going to really be a problem Im more worried about those wires than anythingbut Ive got a couple Ideas to hide them if Im lucky Ill get them under the floor if not Ill cut the next layer a bit diffrent and hide them that way just burry them inbetween the layers of wood I was just affraid if I left them on the side walls they would get cut that and they were in the way
  19. loudcav
    oh yeay the car is a daily driver /demo ride made to play music loud as hell not just some fart cannon
  20. loudcav
    hey Jacob
    Hey Jacob they just picked it up its still got its same tracking number
  21. loudcav
    hey Jacob
    I got the NS18s today and one of them has a broken basket Ive got pics uploading now Ill put up here as soon as they are done. kinda pisses me off cause the package looked perfectly fine no evidence of problems
  22. loudcav
    Sundown Audio CLOSED June 20 - 24
    sure you will!!!!
  23. loudcav
    I was at the slamology what car were you driving??? THE Avalanche. ya I hear that Jerry was quite busy. even had an incident with Baldmans windshield
  24. loudcav
    Done for the season
    the van is allready gone his main proplem is he isnt in the states right now so others are doing the work on the van
  25. loudcav
    So its not real when we post we put a TL at the Kick and post a score...Now I know to ignore you. Ive only metered in the kick once at the USACi event at SVR I was just fooling around mainly wanted to do port wars
