loudcav
Members
    830
Everything posted by loudcav
  1. I wouldnt strap them at 1/2 ohm each amp would see 1/4 ohm
  2. loudcav
    I need a 200 amp alt
    ya I believe they have the cavalier listed on their site its too bad they dont make one for the ecotech I had to go with Ohio Gen a couple years back to get a quality one
  3. loudcav
    Is this an official Sundown product?
    the Dude sells alot of Mass D garbage thats for sure
  4. loudcav
    http://myworld.ebay.com/robotunderground/ looks like a few other companies might be pissed if they would look into him
  5. loudcav
    Prototype Big Boy SPL Motor
    *laughs* Yes, if the motor is made @ this size I will call for motor bracing in the instructions. Have also worked out some pretty solid shipping methods for future runs of woofers with a little expert advice. Should be able to get them to customers intact. perhaps wrap the woofer in a trash bag then use some spray foam in the box around it
  6. loudcav
    when the final product hits the streets I bet it dosent look anything like that proto knowing you
  7. loudcav
    Nightshade B-Stock
    honestly I wouldnt be afraid to run them inverted either its a very minor flaw that most would never notice Jacobs just very picky
  8. loudcav
    SAZ-3000D POWER TESTING
    the amp requires a 300 amp fuse
  9. loudcav
    So say I wanted to run 2 of these really bad but I had 2 dual 1ohm subs meaning I wanted to strap them @ 1ohm daily (music). Could it be done with a 250amp alt, a Deka Intimidator 9A78DT up front, 3-Deka Intimidator 9A31s near the amps and 2 runs of 2/0? Plus with that much current draw...would the 300amp anl support that 392 amp draw ur showing? ya a fuse can allow mo0re than what its rated for then theres the option thats not supported by warrenty of not running a fuse
  10. loudcav
    blown mojo
    Im not sure if the mojo amp will take 17.9 volts he may have left it on too long
  11. loudcav
    Working on improving SAX-100.4
    so when are you gonna trash the bass boost on the rest of the amps?
  12. loudcav
    NDMstang65, Fi car audio, shawn fleming......
    Just send them an email and dont use the sales one
  13. loudcav
    cant wait !!
    If those are the APX Clarions, then they are not cheap on the inside. Quality Zeff design used in CV and Arc's I believe. But the Sundowns are a more robust amp for sure, and the power output potential is higher for the Sundown so it is a quality step up. Great choice. he had the DPX ones the cheap ones alot of people bought
  14. loudcav
    cavalier wall work log
    well hopefuly on thursday Ill be back to work on the car the truck has to go to the damn dealership I did a bunch of work on it today and its acting up dad and I went over it a few times and just cant get it right he thinks when I cleaned out the throttle body with some carb cleaner I knocked some trash loose and down into a sensor but Im not so sure about that I think its the tranny
  15. loudcav
    The victim all torn out progress from yesterday Im working on getting that piece on the other side in Im hopeing to get more done before I go back to work tomorrow not exacly the most motivated person at times its going to be alteast 2 layers on the sides and back and a tripple baffle I might go thicker on the dides depending on how these first layers go up this layer is pretty rough not really that square so I might have to go thicker to get what I want from it no big deal really its just the shape of the bare sheet metal sucks. and the gear
  16. loudcav
    cant wait !!
    bout time you get rid of the cheap Clairions
  17. loudcav
    well looks like the car is on hold for a couple weeks Im getting ready to do quite a bit of mechanical work on my daily driver Silverado its got a bit over 90k miles on it so its time for quite a bit of work time to swap out quite a few original parts I didnt buy any performance parts but it still should get quite a boost in performance
  18. loudcav
    Another 1st place
    I wish.... I have to go to my nephews b-day party. ya I know Im probably not gonna be out for the rest of the year I offered to let an extreme guy run the one nightshade 18 Ive got here and to use the amps but I guess hes not gonna take me up on that
  19. loudcav
    Another 1st place
    you gonna go to the 3X and norris' shop today?
  20. 3 10 inch sundown SD1s
  21. loudcav
    Wired Remote for SAZ-1500D
    well keep the remote for the 100.4 since they are the same piece
  22. loudcav
    that is correct on the 1500 and 3k the remote controls the gain and wont allow the knob to take you higher than what the gain on the amp is set to
  23. loudcav
    the wired remote on the 100.4 controlls the bass boost even tho its the same remote as trhe 1500 and 3000D Okay so the remote for the SAZ-1500D is a level control and the remote for the SAX-100.4 is for the bass boost. Is that correct? I just don't get that because the SAZ-1500D has a bass boost as well. ya. who honestly uses the bass boost on the 1500D?
  24. loudcav
  25. loudcav
    Playing with broken 18" Nightshade
    sux, i cant watch this link for some reason Do you have Quicktime? if you do it just takes a wile to load
