bulldogfreddy
Members-
117 -
Content Type
Profiles
Forums
Gallery
Everything posted by bulldogfreddy
Looking ~15^3 after displacement with 18.5 x 9 slot port on driverside tuned ~34hz since it will be at B pillar. Had talks about tuning it higher since it will b pillar (midgate) and will go lower anyway in Hz's. Also to do center ports with separate chambers instead. Will be running a Memphis Mojo 4kw and have upgraded my electrical. Looking more at a daily setup and a shared chamber with slot or separate chambers.
2 zcon 18's box questions in Chevy Avalanche
bulldogfreddy replied to bulldogfreddy's topic in SPL & SQ / Fabrication
Thanks. Still trying to see how to seal it off. -
Metered it last week and hit 153.7 with driver door open. Thinking about 6th order now. Score is good for being tuned low. -
I hear you Lee because I just did my transmission flush and will do rear differential tomorrow. I had battery isolator for a while but disconnect it due to people said that I was losing a half a volt. I added the second battery tray but never used it. Lol. Have you ever thought about getting the dual alt bracket?
Nice work
Good stuff, now time to cause damage. Lol
ABC box http://s1310.photobucket.com/user/bulldogfreddy1/library/ABC%20box
Just moving from other post with install and more work ahead. Still trying to break them in and really get loud with front window halfway. Have to find somewhere here to play here.
Need a custom box for a 2012 silverado extended cab
bulldogfreddy replied to cehmke's topic in SPL & SQ / Fabrication
I can see what I can come up with to see what everyone thinks about it with a cutlist. -
Have add more, going glass whole door. Door panel was mess up from last install. -
First test today and I had to hold on. Not even half power and was crazy with windows up. With just front windows halfway down was stupid. Lol. Thanks SSA. Still working on trim plate color. -
Painted the back side with bedliner and have to prime and paint the front later. Should I paint blue like the box or bedliner black? -
On the Team also?
What size zcon? 1.5 months... you got lucky lol , I've been waiting almost double that time and still no update. I hope Aaron take care of you. My subs also came in and my order was in March.
Thanks bro. Finally got the box in after fighting with it. I went with stainless steel hurricane nuts (T - nuts). Will try working on beauty plate and reposition amps. Thinking about moving batteries inside center console. -
http://s1310.photobucket.com/user/bulldogfreddy1/library/ -
Going have to finish everything up since the subs will be here today or tomorrow. Can't wait to hear these subs. -
Looking good.
Welcome
good read
Was looking at Mayhem
Happy birthday
This is what I came up with so far if it helps. I got 6 1/4" down the center in the rear. So you can add 20 3/8" + 6 1/4" then you can take you port correction from there. Hope the picture helps and is close to what you had.
