lakaiguy
Members
    126
Everything posted by lakaiguy
  1. well for one i need an amp stable down to 1 ohm and i'm pretty sure the zx line is only stable down to 2 it feels like kicker amps and RE subs just don't go together like a peanut butter and caviar sandwich
  2. under $300 both those amps are under $250
  3. lakaiguy
    In the market for different subs
    SEs are good
  4. lakaiguy
    i messed up on my choice of 1 ohm
    yep you did.
  5. lakaiguy
    yep you did.
  6. lakaiguy
    HiT dEM LoWS!
    that MIMS song doesn't really bump for me Top Shooter by DMX Cali Diseaz by Shade Sheist
  7. you can keep the stock HU, and if all you want is more bass you'll get it but like mrray13 said crossovers are a big plus especially when adding a subwoofer since you no longer need to rely on door speakers for bass what usually happens since your stock HU doesn't have crossovers you end up having to turn down the bass on your HU which will lower the output of your amp which in turn forces you to turn up the gain, which isnt bad but definetly not ideal its pretty easy to hack into a stock system and add a sub and amp, so try it and see if it suits you if you end up wanting better sound at least you'll already have the wiring ran for your amp
  8. for under $200 i'd get the 5900ub 4v preouts for your subs built in usb
  9. lakaiguy
    A question asked all too much.....
    RE SE under $200
  10. lakaiguy
    Audio Junkies
    WTF
  11. lakaiguy
    OH SNAP! new RE superwoofer
    i tried to stop watching but i just couldn't i really hope that set designer was fired, that was bad even for the 80's
  12. lakaiguy
    Good News Merlin = AX
    geeeeez pay court fees or buy killer amp ~ pay court fees or buy killer amp i think i'm losing my license
  13. lakaiguy
    impedance + SQ
    is there any relation? ie. would two subs showing an impedance of 4 ohms have a better chance at SQ than two subs showing 1 ohm
  14. lakaiguy
    impedance + SQ
    it sounds like you're saying it is possible but it depends on the amp which might suck for me cause i was thinking about getting the Hifonics BXi1606D and running it at 1 ohm
  15. lakaiguy
    No sound from woofer
    but when i push on the cone or surround it works again, i'm pretty sure it has something to with the spider monkey or whatever but i'm not sure thanks
  16. lakaiguy
    k well the subwoofer is a 10" infinity 1030w (fantastic SQ sub) and the amp was an MTX282 i had the gain on the amp almost maxed out so that might explain the heavy current thing the tinsel lead isnt exactly hanging by a thread or two but it is pretty wiggily how the F do you fix that, the woofer is still perfectly good right except for the tinsel thing?
  17. lakaiguy
    wait why would i check the ohmagem?
  18. lakaiguy
    ooh you're fast k nevermind it wasnt the spider monkey it was actually the tinsel leads they're still connected but the wire is kinda dark near the terminals is they're a quick fix for this?
  19. lakaiguy
    Lost screws
    they're called set screws, you can get them at any Ace hardware
  20. ive tried 3 different ones so far and ive got 3 different results using the same dimensions. all i need is .89 cu ft
  21. lakaiguy
    Please Help With questions on Q/BL
    slaterized ROTFL
  22. lakaiguy
    best online box calculator
    thats weird, the box wizard on rockfordfosgate.com and elementaldesigns.com or completely different with those dimensions, im so confused
  23. lakaiguy
    it looks like thats for ported enclosures only
  24. lakaiguy
    i'm sure that makes perfect sense, just not to me
