Quentin Jarrell
SSA Regular
    4,549
  • Days Won
    54
Everything posted by Quentin Jarrell
  1. Quentin Jarrell
    DSP's and REAL amplifiers
    Got one here still laying in its box
  2. Quentin Jarrell
    You said before that you have used a minidsp 2x4? Any features you particularly like and don't like?
  3. Quentin Jarrell
    The learning curve will be dumb enough for everyone to use. Even my 3 month old daughter can swipe open an iPhone. Dont worry about cost. Just because you think it's expensive doesn't make it expensive to manufacture. I.e. the Ethos.
  4. Quentin Jarrell
    Zero Ethos motors left.
    Due to unexpected high sales volumes I only have 35 motors avaliable for purchase. The next run will not be in until September. I will try to update as orders are placed.
  5. Quentin Jarrell
    help with air space
    That is the area as stated by the prompt. You then multiple that by the internal height of the box. Are you using inches or feet and inches
  6. Quentin Jarrell
    help with air space
    Push all the sides down and make sure the area behind the sub is selected
  7. Quentin Jarrell
    help with air space
    Right click in the floor of the box. Click selection, area. Multiply the area by the hieght of the box and you got ur volume.
  8. Quentin Jarrell
    Purely full range amps with only a gain control with the ability to purchase an outboard digital eq. You would simply plug a mic I to the processor and it'll automatically adjust the 31 bands for you. Or you can measure and adjust manually. All via a laptop.
  9. Quentin Jarrell
    I really have nothing to add to this thread I have some extra workers that needs more hours .... It's ok .. all in fun... don't get butt hurt .. geez I found my edit to be quite funny.
  10. Quentin Jarrell
    typical power. Start in the middle and work around that.
  11. Quentin Jarrell
    Welcome to the IHoP v.2
    M5 and all the other SQ snobs reply to my thread. http://www.soundsolutionsaudio.com/forum/topic/62644-dsps-and-real-amplifiers/
  12. Quentin Jarrell
    18 inch ethos
    5 cft net per driver tuned to 30 hz.
  13. Quentin Jarrell
    2010 civic sedan daily drive
    after 2 hours of screwing around with placement its starting to look like a kick panel. tried to get all drivers as close together as possible.
  14. Quentin Jarrell
    Swift's 2012 F250
    Dem poor doors
  15. I'd recommend 3,500. My team members have had success with B2 and American Bass. Check out Swifts f250 build log in the build log section. He is using a newer companies amp that also has decent pricing.
  16. Quentin Jarrell
    Swift's 2012 F250
    Better steel some springs off a 3500
  17. Quentin Jarrell
    Ethos and Trident preorder
    Nope. Waiting on a few things.
  18. Quentin Jarrell
    Swift's 2012 F250
    They better tighten up. About 40 drivers on preorder. If it keeps up I'm gonna have to make another order before the order comes in just to have enough stock.
  19. Quentin Jarrell
    dropped my router and broke the base so the baffle is a little rough but It'll be fine after all said and done.
  20. Quentin Jarrell
    Is it a coincidence that Obama is in town the same time a two mile long train full of tanks is passing through town headed west?
  21. Quentin Jarrell
  22. Quentin Jarrell
    Figured I'd do the kicks first so I can have some tunes while I hack up the doors. Three layers of 2 oz mat. Should be plenty string enough. Notice I wet out well past my expected trim line. This ensures consistent thickness at the edges and that the panel will rest nicely in the vehicle. I normally wet my mat before laying it but I'm using some cheap resin and wasn't sure of the cure rate so I did it in the vehicle while making sure I didnt over wet the mat. Too much resin can weaken the laminate. Also notice I used FULL sheets of mat. NEVER cut up your mat unless absolutely necessary.
  23. Quentin Jarrell
    That's fucked up. Like seriously fucked up. J Faith didn't fuck up those buildings. Religion did.
  24. Quentin Jarrell
    It wouldn't play as low.
