Quentin Jarrell
SSA Regular
    4,549
  • Days Won
    54
Everything posted by Quentin Jarrell
  1. Quentin Jarrell
    Thinking About Getting An AR-15? Advice?
    That's the deal with the 2nd amendment. It states that you have the right to bear arms against state and country. But doesn't go into detail about what is deemed legal or not.
  2. No, there is no difference in properly sized wire.
  3. Quentin Jarrell
    You don't need amps or speakers and might hurt yourself and others. Probably don't know how to properly calibrate them to the highest level of standards either so you shouldn't get them.Come on man, don't be so rude to people. You wouldn't want to be talked to like that would you? I am just saying what is he going to use it for and does it need to be a ar-15. Smaller calibers can do the same job.The at cones in many calibers. Even 22. AR is just the style "frame"
  4. Quentin Jarrell
    Nvm. I swore I saw that caliber listed. The only tactical grade weapons I own are made by McMillan. Im sure way above ur price point. And I don't have any Ar's as I don't have the need for a compact framed rifle. The Ar is designed for close quartered combat situations. So unless you want it bc it looks cool then it wouldn't be my cup of tea.
  5. Quentin Jarrell
    First question would be why a .223 over other rounds avaliable.
  6. Quentin Jarrell
    Welcome to the IHoP v.2
    The 50 is a pain in the ass to reload a clip. Normally we just slide a round in at the bolt. You don't want no more than about 5 rounds anyway. I'm not a target shooter and don't really hunt as much as I used to. I do collect a lot though. I've got two purdey's and a few other antique American darengers and such In all I've got around 160 rifles and pistols. 95% of them I haven't spent a round through.
  7. Quentin Jarrell
    Also use a lever action browning 30-06 now and then but I prefer the 243. 270 short mag is a good gun for 200-300 u'd range. I've found that anything under 200 and the bullet is too quick. Deer like to run. If I ever get a big gun itch I go to my dads. He's got a McMillan 50 cal.
  8. Quentin Jarrell
    My last elk (few years ago) was about 480 yards. For whitetail under 200 yards I use youth model browning 243 medallion.
  9. Quentin Jarrell
    The 300 magnum is my favorite larger rifle round. I use a McMillan Dynasty for long range mule deer and elk.
  10. Quentin Jarrell
    Review it for me: Civic install with obstacles
    If you are just adding a sub you won't need any processing. The most cost efficient method would be to use a PAC SNI-15. Before you do anything I would verify factory filtering. All you need to do this is a few test tones and a DMM. If he is not looking to add a ton of output a single 10 or 12 fiberglassed into the fender area would save the most space. Or he could just opt for a nice sealed enclosure that could be removed if he needed the whole trunk.
  11. Quentin Jarrell
    baking some crab and cornmeal stuffed boneless chicken breasts.
  12. Quentin Jarrell
    Ethos 12 and 15 pre order
    about 65 pounds
  13. Quentin Jarrell
    How does someone run so many subs??
    Like any parameters. "Recommended or optimal" air space is worthless without explaining why or for what reason or application it is optimal for.
  14. Quentin Jarrell
    You shouldn't have pissed off true concepts
  15. Quentin Jarrell
    You can't taste it. It's used as a thickening agent. It's puréed
  16. Quentin Jarrell
    Pulled pork, chicken, rice, liver, onions, garlic, bell pepper and spices stuffed in sausage casings and boiled.
  17. Quentin Jarrell
    Boilin boudin
  18. Quentin Jarrell
    Mmmmmmmm...............resin fumes.
  19. Quentin Jarrell
    Fiberglass advice
    As you said, I wouldn't waste my time on it but... Resin will adhear to the carpet but wouldn't accept mat correctly. So...the easiest way would be to remove the carpet undernieth. Now, resin will not bind to plastic. So what you would want to do is use the panel as a mold. Wrap the entire bottom with blue painters tape then apply mat/cloth and resin to build up a laminant. Once this is complete use corvette body panel adhesive to permanently adhere the laminant to the panel.
  20. Quentin Jarrell
    I don't know what an 8th gen civic is. Need to know how much output is desired. Need to know budget. Doesn't matter whatsoever if their is a limit on the factory sub. The aftermarket amp will have a gain and you will adjust accordingly. Need to know the set skill of the installer. This is going to be the biggest deciding factor.
  21. Quentin Jarrell
    help me choose an upgread
    I'd fix what's broke first.
  22. Quentin Jarrell
    Circle cutting tool for Router
    Best jig. http://www.rockler.com/m/product.cfm?page=30473&mt=more_info You can get a circle/oval jig for about $90. Rockler is the only place I buy my woodworking tools.
  23. Quentin Jarrell
    Just live where ur neighbor can't catch ur wifi signal. Problem solved.
  24. Quentin Jarrell
    Favorite Peanut butter
    It uses palm oil which naturally has a lard like consistency at room temperature vs hydrogenated soybean oil.
  25. Quentin Jarrell
    6 SSA GCON'S in 4th order on 2 Soundstream XXX 6500's
    Me dumbass!!!Well at least I know who to look out for when I go to BR.
