4,549 -
Days Won
54
Content Type
Profiles
Forums
Gallery
Everything posted by Quentin Jarrell
Ethos 12 and 15 final pricing and preorder
Quentin Jarrell replied to Quentin Jarrell's topic in Direct Sound Solutions
Talked to Pat today. Testing will begin today or tomorrow. -
Building a better box for MY vehicle
Quentin Jarrell replied to smashedz28's topic in SPL & SQ / Fabrication
Box is about as big as I can go with it and still get it in there. I thought it may have been the remaining trunk space after the box was in there was my problem. When the box is in its a tight fit all around. Passage space for air to travel to the front of the car is very little. I threw a single 12 enclosure in there and had the same problem.this is not always the case. my ethos in the same size box 3 feet tuned to 32 for the 15 has a flat response with a F3 of ~28. In the same size box tuned to 36 it gets ~3db gain from 30-50 with an f3 of ~29. going with a larger box with same tuning only results in a bigger peak at tuning frequency, not any more lower extension.Large and low tuned to get that big peak down low.. Guess you didn't understand the post. -
Box is about as big as I can go with it and still get it in there. I thought it may have been the remaining trunk space after the box was in there was my problem. When the box is in its a tight fit all around. Passage space for air to travel to the front of the car is very little. I threw a single 12 enclosure in there and had the same problem.this is not always the case. my ethos in the same size box 3 feet tuned to 32 for the 15 has a flat response with a F3 of ~28. In the same size box tuned to 36 it gets ~3db gain from 30-50 with an f3 of ~29. going with a larger box with same tuning only results in a bigger peak at tuning frequency, not any more lower extension. -
not sure about the eq on that head unit. The only way the info will be helpful is if you know the free air out put of the box. So you would first measure the enclosure out of the vehicle to get a base reading. (this is much easier to do with a sealed enclosure that has a flat response)Then come base the open space reading with the reading in the car to see how the car is affecting output. -
http://www.parts-express.com/term/dayton-emm-6?srch=Dayton+EMM-6 Those are pretty cheap units. If the RTA showed a loss in response form 30-50 then you have two choices. EQ all the ripples (peaks) down to the level of 30-50 hertz output. Or build an enclosure with an increased ripple at those areas to compensate. -
Some type of rta or db meter that will allow you to play a sound sweep to see ripples in response. -
It's obvious transfer function is affecting output. Only way to know how to work with it is measure the responses in each vehicle. -
are you concerned about voltage or current draw? Voltage will not affect current draw. Most leds are 1.5 volt and use some type of resistance to retrict current. if you attach a normal LED on a 12 volt battery it will blow. Stick a 1000 ohm resistor in line and it'll work fine.
The current draw will vary depending on how they are seriesed and or paralleled. Also the strips or controller could have resistors to limit current draw.
Uhhh... they have them. Tempur-ErgosI me http://www.tempurpedic.com/TEMPUR-Ergo-Adjustable-Bases/TEMPUR-Ergo-Adjustable-Bases.asp By they i meant J's friends who like to use the tempur as a couch. It will alleviate the back pain you described. Uhhh... they have them. Tempur-ErgosI me http://www.tempurpedic.com/TEMPUR-Ergo-Adjustable-Bases/TEMPUR-Ergo-Adjustable-Bases.asp By they i meant J's friends who like to use the tempur as a couch. It will alleviate the back pain you described. Uhhh... they have them. Tempur-ErgosI me http://www.tempurpedic.com/TEMPUR-Ergo-Adjustable-Bases/TEMPUR-Ergo-Adjustable-Bases.asp By they i meant J's friends who like to use the tempur as a couch. It will alleviate the back pain you described. I'm patenting the intellectual rights on that shit. Tempur-boy
...but you can give us a call around 2 in the morning and see what we are looking like.
Nothing like driving 1 1/2 hours to work to find out they don't know when they are going to get to your shit.
Have a total of (6) six dual two ohms. mechanically they are 10 out of 10 only a few weeks of playing time on them. cosmetically they are 9.5 out of 10 there are a few scuffs on some of the mounting gaskets that can be seen in the photos. $165 SHIPPED They will be shipped in the original shipping boxes from Incriminator.
2nd battery Help!!!
Quentin Jarrell replied to ludachris5150's topic in Amplifiers / Head Units / Processors / Electrical
If the the battery is not grounded, as I believe it's not by the way the post was written then you are only running off the rear battery. This would be a reason you aren't seeing a difference -
hhhhhhhhhhhhhhhhhhhhhhhhhhhh
Not a fan of liquor myself. But I do have a bottle of King'a castle.
Incriminator Leathal Injection 15's $165 shipped
Quentin Jarrell replied to Quentin Jarrell's topic in For Sale/Wanted
SOLD!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! -
All of that shit is like crack. The more you take the more you gotta take.
Pure audio amp
Quentin Jarrell replied to ImaSlacker's topic in Amplifiers / Head Units / Processors / Electrical
Clamp test means nothing....It depends on who you ask...I'm well aware of the reasons you made that statement though.A clamp test is not an RMS rating. Search the definition of RMS and you will understand. If it hasn't been hooked up to a Audio Precision or Power Cube analyzer then the rating means absolutely nothing. It also means nothing if the parameters at which the numbers measured are not listed. -
Changing the fluids for hurricane season. Got a little power to spare in case anyone needs to bring a camper or two over.
not bad for your first rodeo.
Found a Metra dealer price list today while cleaning while cleaning. BAD motherpucker. If you dont watch th ewhole thing skip to 3 minutes.
So do the Italians.
