Quentin Jarrell
SSA Regular
    4,549
  • Days Won
    54
Everything posted by Quentin Jarrell
  1. Quentin Jarrell
    2010 civic sedan daily drive
    beginnings of the baffles
  2. Quentin Jarrell
    Zero Ethos motors left.
    I have two 15's in a sealed test box in a 2010 civic. Waiting on my Singer alt.
  3. Quentin Jarrell
    Welcome to the IHoP v.2
    I'm waiting for it to be dropped in a grand Cherokee.
  4. Quentin Jarrell
    Here you go. You can get it up to 8 pounds per square foot. http://www.santarosaleadproducts.com/lead_sheet.htm
  5. Quentin Jarrell
    Have no need for a jig saw. The plastic is only 1/8 thick. Not cutting it on any specific angle.
  6. Quentin Jarrell
  7. Quentin Jarrell
    2 12" zcons 4-6k trunk wall
    What did the rubber glue look like? I sent some to Jon and it hardened in the bottle.
  8. Quentin Jarrell
    As always gonna be a little more involved than I wanted. The sharpie outline is where I'm gonna wind up cutting.
  9. Quentin Jarrell
    Team IAK IronMan Explorer
    Uh oh
  10. Quentin Jarrell
    2005 tahoe road to 150+ db
    She'll be on the fedex truck Friday evening
  11. put your video on the website and facebook.
  12. Quentin Jarrell
    Some type of chemical reaction in some type of fluid
  13. Somewhere around 3.5 thermally. It's got a stupid amount of BL for it's moving mass. It won't take much to get going.
  14. I personally like Focal solids. They are tiny are never had an issue with one. As long as any amp isnt being over driven youd never hear the difference.
  15. John Levreault builds some if the best amplifiers in the world for home audio And guess what he builds. Yep. D class
  16. Quentin Jarrell
    Only 4-5K, is that chump change to you guys lol?Everything is relative. Just because something is a lot if money doesn't make it expensive. You don't go to Wolfgang's and say WHOA $100 for a steak? I can go to outback and get one for $10
  17. Yea amps are easy. All I have to do is call Korea and tell them I want x watts at y volts at z ohms and they can whip them out. Everyone and their moms has amps so I'm going to add to the sub line and raw drivers. The trident comes this October. Then a few smaller subs next spring. In the mean time I am working with Morel to OEM a few of their raw drivers to my specs for car audio. And Solen may supply high quality crossover components in case a customer wants passive instead of active.
  18. They will be nearly the same. The 12's are mass loaded to get nearly the same response as the 15's. If mass wasn't added to the cone while keeping the same motor strength and suspension set up they would have fallen off about 1/2 octave higher. On paper anyhow.
  19. Quentin Jarrell
    The Ethos was designed to get a big ripple around tuning to compensate for cabin gain in the 40's and 50's range. Since the MMS is a bit heavy for the motor (it was made for the 15 Mms) Fo / vas ration is a bit off so to get ripple under 6 DB you'll want to tune between 25 and 30 hz Personal preference is 4-5 feet tuned to 25. This gives 5db ripple at 40hz, F0 at 28.5 and F3 at 24.25hz Or you could stick it in 10 feet tune to 20 with a 3db ripple at 29hz F0 at 22hz and F3 at 17.5 hz
  20. Quentin Jarrell
    your idea of only and mine are a WEE bit different.Well if you figure a quality off the shelf 3 piece will run 3-4k and a good set of custom built race rims can run up to 25k, 5 k ain't too bad for a 3 piece rim custom built with the exact offset to fit you vehicle and brake setup.
  21. Quentin Jarrell
    A nice center locking wheels would look nice.
  22. Quentin Jarrell
    http://www.forgeline.com They'll custom make any combination of whatever you can think of. A custom 3 piece will only set you back 4-5k
  23. Quentin Jarrell
    2006 Nissan Titan
    That's fine most surrounds don't have any holes at all. Use a screwdriver to clean the holes in the basket before mounting
  24. Quentin Jarrell
    Mom, sister, and ole lady all keep stub nose 38 specials.
  25. Quentin Jarrell
    Pics and videos or it didn't happen.
