talibmohamid
Members
    37
Everything posted by talibmohamid
  1. talibmohamid
    ZED an JL W7 series Combo HELP ! ! !
    hey guys......i am looking into a new sub setup.......going too take it back to JL i believe this time....first off i have 2 zed audio miniliths......the subs im interested in are the 12w7 or 13w7......... the 13w7 is a dual 1.5 vc sub and the 12w7 is a singl voice coil 3ohm sub. ............ how would u all reccomend me wiring these subs and about how much power would i be getting in you alls reccomendations......thanks and could u all map out the reccom-mended wiring for the strapping or whatever......thanks guys mini spec's: Typical Continuous Output power into1 ohm 600wx1 Typical Continuous Output Power into 2 ohm 400wx1 Typical Continuous Output Power into 4 ohm 200wx1 Continuous Output Power 2 channels bridged into 2 ohm 1,200w x 1 Continuous Output Power 2 channels bridged into 4 ohm 800w x 1 Continuous Output Power 2 channels bridged into 8 ohm 400w x 1
  2. Hey guys.....i am not sure what too do guys.....i have one IDMAX 12" dual two ohm...in which i am running 2 zed audio mini's.....think i could jus use one for the sub.....but i want a lil more bass.....and was thinking about getting rid of the one IDMAX 12" and getting 2 / 13inch JL Audio w3's.....one per Zed Audio Minilith.....I am planning on leaning toward SQ......but want too be heard "if u know what i mean".......Should i jus get another idmax 12' or change into the JL's......in both situations i would give a mini per sub....can u all tell me the benefit of getting another IDMAX or changin too the JL AUDIO's...THANKS GUYS.....have taken the POWER into consideration and all......LET ME KNOW ADD another IDMAX or Change into a pair of 13"w3v2's HELP : EXPLAIN WHY to do either...THANKS GUYS
  3. talibmohamid
    actually////// it depends on how you look at it with the power........i like too take the continuos stand point///////// Continuous Output Power into 1 ohm 600wx1 Continuous Output Power into 2 ohm 400wx1 Continuous Output Power into 4 ohm 200wx1 Typical Continuous Output power into1 ohm 650wx1 Typical Continuous Output Power into 2 ohm 480wx1 Typical Continuous Output Power into 4 ohm 260wx1 so ZEDMAN is it safe too say they prob....really do a lil more rite....
  4. talibmohamid
    Minilith SUBS?
    Please recommend a sub the minilith would like...that a single mini can power well......thanks...12 or 13" OUTSIDE of IMAGE DYNAMIC's IDMAX & JL AUDIO 12W6v2 thanks guys Going for a powerful LSQ setup GUYS....if that helps
  5. talibmohamid
    sorry yall didn't mean too say strapinh...meant bridging.....
  6. talibmohamid
    presale posibility?
    jOHN........HE WON'T DO PRESALES TOO THE EASTCOAST? "i'M ABOUT TOO CRY MAN"....WHATS UP WITH THAT
  7. talibmohamid
    Is this right? ...gain on Draconia...question
    U KNOW ...... IF ONE OF THE CHANNELS IS BLOWN THERE IS A POSSIBILITY THERE COULD BE SOMETHING ELSE SMALL WRONG ALSO.......DUDE SEND IT IN TOO ITS FATHER..."STEVE", IF HE HAS TIME...KNOW WHAT I MEAN. QUESTION: WHEN YOU CHANGED AMPS OR WHATEVER DID YOU CHANGE SPEAKERS OR ANYTHING ELSE? "NOT TOO INSULT YOU INTEL. BUT I'M JUS TRYIN TOO HELP YOU NARROW IT DOWN IF U HAVEN'T ALREADY...
  8. talibmohamid
    Zed Amps
    Spoke too him on this past thursday and he said too expect something that had never.....ever been done....said it would be a monster and very flexible........and powerful...."I CAN"T WAIT"...
  9. talibmohamid
    Bridging Minilith
    man excuse my ignorance.........i missed that big ass duece or DRACONIA......LOL, looks crazy man, keep us posted and all.....is PUTTIN OUT SOME NOTES NOW....
  10. talibmohamid
    Bridging Minilith
    man.....sick install dude.........look NASTY.......what you runnin on the highs and mids dude...
  11. talibmohamid
    Bridging Minilith
    Yeah dude that is some tricky stuff........and you would be strapping.........the two not bridging. I would reccomend you run a amp per voice coil. Don't know if the mini's will like that basically 1/2 ohm load dude........the amp is going too only see half. I tried the same set up on a dual 2 ohm VC IDMAX..........and it played but i don't think it really like it.....make sure you have really good grounds and sufficient grounds. That does not look right. you need to hook amp- to amp- then you use only the positives from each amp and connect the master amp + to speaker1 + then slave amp- to sub2- before you hook up the subs to the amps ensure you have the right impedance on the subs. I am not super familiar with your subs if they are under 2 ohms I do not think I would run it that way. you could always hook up one amp to each voice coil but they would have to be matched with output by using a dmm. Have a great day. Z
  12. talibmohamid
    3 ICON 10D2s Build log > 2006 Toyota Solara
    MAN ///// SICK BUILD........do yall think yall could have made it any sicker? Geez......looks great yall.....keep it up......I bet those ICONS are crazy
  13. talibmohamid
    2 Miniliths and Draconia are God-ly
    Man guys I finally finished my install.....got everything tuned up and its simply amazing.......people are swearin up and down I have hidden amps......my system sounds amazing .......everyone need these in there life.....CHECK these pics out.....my camera broke.....so I used my i930....camera phone....not the best picks but I think I get my point accross.......
  14. talibmohamid
    Amp draw @ 4 ohm and 2 ohm
    ONE OTHER THING DUDE,,,,,,when you hook an amplifier up if it is 600 watts......by your adjusting the gains you aren't getting anymore JUICE DUDE///// you will be adjusting that 600 watts you have if its a quality RMS amplifier.....its does the power ratings contiuously......no matter the gain...and thats a good thing
  15. talibmohamid
    Which subs to buy?
    How do you figure? The Audioque HDC3 is $239 from their site and the Fi Audio BL15 is just under $300. IDK how much the RE MX is though, but from the looks of it, I can definitely get a loud sub in that price range. If you think I should up my budget a little for something else, feel free to suggest something though. are the HDC3's even in stock??? I wish you the best of LUCK......dude...I'm no expert but what I have learned out here is . . . "U get what you pay for", and those brands you list are good stuff.....but unless you run accross a major DEAL, you gonna have too up that budget.....to get good stuff man....the install is a very important part of the sound but the quality of your equipments gonna play a part too know what I mean.......loud with not that much power........look into IMAGE DYNAMICS.....I am running a IDMAX 12" now.....it sound pretty tight, I'm not tryin too break any records or nothing but it sound good....GOOD LUCK too you man........."CAN"T REALLY BEAT ZED WHEN IT COMES TOO PRICE VS. PERFORMANCE"....
  16. talibmohamid
    4 12's or 2 18s
    heard great stuff about the ICONS.......I personally have like the sound of 12" woofers / the 18" I heard didn't sound good in the ported box I heard.......the 12" subs would prob. sound a lil better.......know what I mean...
  17. talibmohamid
    My new toy(project
    Man that is going too sound crazy...good luck too you, wish i could hear it when you finished
  18. talibmohamid
    which sub?
    Dude I would go with the Q's........heard them ported , , , and the suckers play low.....You will more than lickly love them
  19. talibmohamid
    Fi Q vs. CVX
    I am going too vote weak design.....I like the Fi Q's, I don't own either but have sold KICK,,,,,and actually had a 15" CVX........the car's I have heard with the Fi setups were nice.....maybe i haven't heard the kickers in a perfect or almost perfect environment....
  20. talibmohamid
    MAN I MISS my setup.....LOL, I am revamping this thing now.......don't have W6v2's anymore.......running image dynamics...
  21. talibmohamid
    Zed Audio Amplifiers
    MAN.....RUMOR....RUMOR>.....and more RUMOR>...LOL, man is ZED stopped......I dunno what I would do..
  22. talibmohamid
    presale posibility?
    I WOULD DEF. JUMP ON THESE i would totally jump on this band wagon
  23. talibmohamid
    (2)Mini's Strapped to W7 or (1)Deuce
    Hey guys.....how do you think (((2)Mini's Strapped to W7 or (1)Deuce))) would play out...being that the W7 is single 3 ohm sub? Wich way is going to sound better....and be most efficient....I already have the mini's and was thinking about changing those for the deuce.....OR may be some sub recommendations for the 2 MINIs....I wanted to run one moster...sub....thanks
  24. talibmohamid
    gladius owners how do you like it?
    GET THE Gladius.............its awsome....got to here one a few days ago...flexible and powerful is all i can say......clean....too
  25. talibmohamid
    Cograts Zed!!!!
    PROUD TO BE A ZED AUDIO FAN!!!! THANKS STEVE....u deserve this.....
