imhungnurnot
Members
    444
  • Days Won
    1
Everything posted by imhungnurnot
  1. imhungnurnot
    WANTED SAZ 1500D!!
    Will do!! Thanks for the feedback on the post! lol
  2. imhungnurnot
    WANTED SAZ 1500D!!
    Why not post it in both? Yes, I DO have a big truck with a dildo strapped to my BTL that you can sit on.. im thinkin 25Hz test tone will work nicely
  3. imhungnurnot
    .5 ohm load on saz 1500
    so how much will it deliver at .5 ohms?
  4. imhungnurnot
    I thought if you half the ohm load you'll gain about 3/4s of what you were already getting? ex 1500+(1500*3/4)=2625
  5. imhungnurnot
    BTL problems continue
    Try using your eyes to read the original post...
  6. noo.. like all i meant was that i don't turn my radio off before i turn my truck off.. but the radio does turn off with the key off.. only reason i said this is because it is weird that i turn my truck on and the sub amp goes into protect, but if i turn my radio off then back on once the truck is running everything works fine
  7. hmm could be.. but i have the remote wire from my HU going to my bass amp then to my highs amp. So i would assume that it wouldn't turn on the second amp on the line first (the highs amp)
  8. I recently got a nice deal on two used mm1400.1d's. Now i'm considering running them together on one BTL 12. Does it matter if one has a little more wear and tear than the other? Will it be okay as long as i check that i have the amps sending the same output wattage with a multimeter? Is it a bad idea all together?
  9. imhungnurnot
    Which Mids/Highs amp?
    You would them loose your left and right control.. which isn't bad.. but wouldn't you also lose your time alignment feature from your HU? (assuming you have that feature).. i'm really curious cause i wanna run active front stage w/ time alignment and if i could get away with using a 2 channel it would be great!!!
  10. So I found a tutorial on the MLX-100 ( ) and here they used ampfliers with a master/slave switch, but im thinking that was just a coincidence because they had both switches set to master.. so IF i'm correct.. the MLX-100 is a way to get around not having a master/slave switch.. right?PS. The device will also serve as a line driver?
  11. Alright.. I really dont remember how amps are actually strapped.. is it almost like running the outputs of the amps in series?
  12. Can any amp be strapped? I asked about strapping Autotek MM's before on this forum and I was told they could not. Yes you can, using a device called a Maxxlink: Maxxsonics Maxx-Link MLX-100 (mlx100) Equalizers Sound Processors Car Audio Car Audio, Video, & GPS Navigation - Sonic Electronix So strapping my two 1400.1s.. I should be getting 2800 watts x 1 at 2 ohms or 4 ohms?
  13. Can any amp be strapped? I asked about strapping Autotek MM's before on this forum and I was told they could not.
  14. imhungnurnot
    Orphan 8's Need a Home!
    How do the orphan compare to the rli 8 considering SQ and SPL? As far as I understand they each work well in the same size enclosures.
  15. imhungnurnot
    I need a 15" sub
    What do you want? More SPL or SQ? I mean any Fi sub is going to sound good and be loud. I mean even the SQ sub (the Q) is loud and will make shit vibrate in your vehicle unless it is properly matted.. but you'll probably still have rattles.. so the question is how loud do you want to be and what are the parameters of that box? (assuming you will use that one) unless you're planning on building another? But, for that amp you should be fine running any Fi woofer. But the BTL will be underpowered.. Id go with a Dual 2 ohm sub running it at 1 ohm getting 1500 watts RMS.. For being loud, i'd say the BL (with options to increase RMS) or the Q to still be loud but to be more musical with amp gain set accordingly.
  16. I need to get more footage and create another video.. I was in a rush this time and everything that i filmed didn't come out very good but this reaction is pretty funny. Fi fans will enjoy!
  17. haha its cool, it would be difficult to construct it the way you were thinking and it would be a bitch getting it in an out of the truck.. and it would make it harder to bolt the seats down.. i actually have my seats mounted to my seat belt post on one side with custom mounts.. I originally had a bench with that same wedge box behind it.. so i added the buckets with two more subs and i had to mount the bucket seats some kind of way.. i need to find a decent price to get those seats wrapped.. i'd like the original chevy red with the original pattern so it matches my interior..
  18. Thank you! I had to sacrifice a little leg room, but the subs dont hit the back of the seats due to the angle of the front of the box / angle of the back of the seat. In addition, the subs are recessed 3/4in on the box behind the seat.
  19. No dude, thats my port..
  20. Sorry, this will clear a few things up.. Also, my signature is not updated, I am now running a MM1400.1D @ 2 ohms which its rated at 1000 watts but I have stock electrical and 4 gauge wire so i may only be getting about 750-800 watts total and both boxes are sealed.. I metered it the other day and did a 143.4 on the passenger floor, its not very loud but it would be very clean without all the rattles..
  21. So I designed and built my first ported box on my own, and it does not sound like i anticipated. I believe you all can help. The box is for a single 12'' Fi X with 1.6 cuft @ 31.00 Hz. The sub has a 0.1 cuft displacement, and the Fs is 25.7 Hz. I was told to tune a little higher than the Fs. The O.D. of the box is 16 x 14.75 x 21.625 The port is 8 x 2.25 x 27.875. I used WinISD to design the port. I used 11.25 sqft of port area. I was hoping for it to be musical and be able to go from high freq. to low freq. without problems, but it bottoms out easily on the lows and makes mechanical noise on the highs even with my active cross over set to 35 Hz with a 18 DB slope. I was thinking that i may have too much port area because it seems like the speaker does not have enough back pressure to control its movement. What do you all think?
  22. What are the differences between the alignments QB3 Quasi-butterworth, BB4/SBB4 (Super-)boom box, C4/SC4 (Sub-)Chebyshev, EBS3 extended bass shelf -3 dB, and EBS6 extended bass shelf -6dB when using WinISD?
  23. So if i flare one end, and choose one flanged end in WinISD. It deducts length off of the port length.. would i still have to deduct half of the height of the port from the port length when using one side of the box as one side of the port?
