444 -
Days Won
1
Content Type
Profiles
Forums
Gallery
Everything posted by imhungnurnot
BUMP
help please..
DD post their excursions in "suspension". Does this mean the total distance the sub can travel as opposed to xmax which means the greatest travel in one direction? For example, their 9500 series has suspension of 80mm... it doesn't seem like this can be xmax.. so would the xmax be 40mm ??(half of the total distance traveled)
So there must be some type of conversion to determine xmax?
what is a epicenter? i've heard of this when graphing ellipses in high school.. but nothing related to car audio
How can one calculate the box rise and how does the shape of the box, etc. affect box rise? I am interested because I want to wire my subs down to .5 ohms, and I hear that it probably wont be an issue because of "box rise."
I see! So if i wire up the subs to .5 ohms.. it wont go below that.. but I can measure the difference of impedance with a ohm meter playing differnt frequencies to see how much of the time it is close to .5 ohms.. if it doesn't hover around .5 ohms for too many frequencies than it should be fine, especially with the sundown! Thanks! Great post!
Oh okay, i see!
Amplifier keeps going into protect?
imhungnurnot replied to imhungnurnot's topic in Amplifiers / Head Units / Processors / Electrical
Ah! Thanks, that is a good way to isolate the problem! -
imhungnurnot posted a topic in Amplifiers / Head Units / Processors / Electrical
I have a Autotek MM1400.1D and Autotek MM75.4 in my truck. I leave my truck parked for a few days at a time at school. The 1400 goes into protect mode when I turn my truck on after its been sitting for a few days (I leave the radio on all the time), but when I turn my radio off then on again everything is okay. I can turn the truck off and on after the amplifier is off of protect, and it turns on like normal. What could be the cause of this? -
Okay, thats what I was wondering.. People were telling me that their box's made a 4x or 3x affect on the impedance, but I know it fluctuates. Think they were talking about on average?
A guy on here broke a few records with a ridiculous amount of port area just with two tens. I think if you have about 20-24 sqinch per cube tuned reasonably high maybe 37-39 Hz it'll do well.. but this is only my option.. I don't have very much experience with SPL. So we'll see what everyone else has to say about my info
So I used my truck today but when I turned started it I looked at the amps. Well they both started off in protect mode like all amps do, then the bass amp went to green then back to protect very quickly. I have more investigating to do with the volt meter, but do you think something is possibly wrong with my amp? -
I know this has probably been answered before, but the search bar is pretty much useless on this forum. So if I can keep my electrical system from dropping below 13.0-13.5 volts, how will the saz take the .5 ohm load?
Well I never thought to check the voltage because the starter spun the motor over quickly on start up. No lag whatsoever. But I did just install some bucket seats, and I wired the power to the back of my bass amp.. I disconnect the power seat so now im waiting a few days to go check it out.. This may be the problem. -
Hooking up two amps to one sub
Its the DD 9512g, thermal limits? who cares.. lol i know what VC smells like when you get it hot, just turn down the volume.. Just because an amp on each sub I don't need to have 1000 watts on each coil.. gains are adjustable.. and I think it'll sound cleaner running both amps at 2 ohms anyway... plus i already have the amps from awhile back. why not use them? Also, how can one calculate the box rise and how does the shape of the box, etc. affect box rise? -
I have a Dual 2 ohm sub 1500 wRMS.. so it can be wired at 1 ohm or 4 ohms. I have two 1 ohm stable Autotek 1400s.. They can be linked using the MXL-100 but then I can only put a 2 ohm load on the "strapped" amp set up.. so if I run the sub on the strapped setup at with the sub at 4 ohms ill only be getting 1400 watts. Which is what I would get if I run a single amp on the sub at . Think I could run a amp to each coil if I set the outputs of the amps with a DMM? Would this cause problems? Thus giving me 1000 watts per coil and 2000 watts for the sub all together.. -
Interested in a used SAZ 1500D in good condition. PM or email ([email protected]).
its a DD (digital designs) 9512.. why would the sub matter? -
I did it just for you.. I figured you would be the man for the job to test the rig.. I'll even give you a deal on the sub so you can mount it in your bedroom so your wife can get some real pleasure!
