shizzzon
SSA Regular-
7,785 -
Days Won
24
Content Type
Profiles
Forums
Gallery
Everything posted by shizzzon
Please note- Just because you have a dvd player in your car, that doesn't mean it supports DVD-MP3! To burn mp3s on dvd disc, you simply burn as data ISO. There is no such thing is dvd-mp3 format... It's simply data format, ISO. If it doesn't work, either it doesn't support it, or the media is unsupported... Burn a copy of a dvd on that media and see if it plays. If it does, then it's not the media! DVD players, when it sees dvd disc, will immediately assume it's a move and looks for the VIDEO_TS folder. If the HU doesn't support DVD-MP3s, then when the folder is missing(obviously it would be) then it fails to read disc... IF you find out it's not your media, go online and try and see if anyone has been able to get DVD-MP3 discs to work on this HU. "MAYBE" there is a way to flash the firmware inside which could support it... But you'd have to do research on that to find out.
The Official SPL-Labs SPL Meter Group Buy Thread
shizzzon replied to shizzzon's topic in SPL & SQ / Fabrication
Someone asked me this and I noticed it wasn't posted here so here it is- EVERY Meter that is purchased through SPL-Lab USA, including this group buy, carries a 1yr warranty period. I will start the warranty period for group buys approximately 1 week after your order has been shipped out for delivery. -
front battery voltage no matching to battery bank
shizzzon replied to knockinthastreetzof608's topic in Amplifiers / Head Units / Processors / Electrical
no no no.. I'm trying to help you sync your voltage up from front to back as you have stated is not in sync. When you have a load, you will have higher voltage(then will be compensated at the same time and drop due to current demand) Your vehicle isn't "stupid", you are just wanting a higher voltage when there is no high load and it's not necessary all the time... HOWEVER, this could lead to not keeping the batts maintained... And since you have stated just 2 D3100s drop below 12v, i believe it's already happening! So, you need something to force the vehicle to charge higher. You need to be charging between 14.4-14.9v in the back! So, you will need these cable runs REGARDLESS! Then, contact DC Power or Mechman for a voltage increase solution. -
13.8 is typical for economy use. Voltage being higher after load, sounds like computer controlled regulator. From what i understand, there is no way around it in terms of keeping voltage high all the time even when there is no load. -
Here is another video showing SPL-Lab software capabilities currently in more detail. (Yes, there is 30sec averaging built into the software but I didn't want to record 30sec straight to show it) REMEMBER! Group Buy ENDS OCT 10th, 2011. Please do not forget! -
if u currently drop below 12v with 2 d3100s, then you are about to kill them... They need to be charged separately. -
just add that one run of ground right now and see how that goes. You don't need imo 4 d3100s for 7kw, 2 is plenty. -
all you need is ONE run and that's it. The ground we all use "works" already, it just needs a helper to keep the voltage up, that's what the cable is for. If you have a long run of wire already or a set of jumper cables, u can temporarily connect it to the alt and battery bank and see for yourself. -
this is no question about it man.. It's the ground, trust me. Think about it.. IF you had a bank of batteries in the back and you wanted to make a buss bar for them, what material would you choose- Copper Aluminum or... Steel... Sure as hell wouldn't choose steel.. But that's what you and everyone else is using for conductive grounds in their vehicles. -
this is why it's almost necessary to run a ground cable from the alt's casing or from the ground of the batt up front to the rear ground post on battery bank. IF you run from batt to batt, the alt needs to be grounded directly to starting battery for best effectiveness. -
HU usb port just stopped working.
shizzzon replied to srd150's topic in Amplifiers / Head Units / Processors / Electrical
find and reset the headunit. If that doesn't work, go back into settings after you reset it and make sure the USB output is turned on still after the reset. Otherwise.. try and get it warrantied. -
the mid 140s is when you start feeling it putting decent pressure on your ears.. then the higher you go, it starts to focus on your head and your breathing, hehe.
lol, why does everybody say that? My amps aren't even turned up all the way....
if he could even break a 150, he would have let you get in it and feel the pressure...
Here is a video of the software in use. This is showing VERY basic usage of the software. Realtime, Peak Hold and 30sec averaging. -
lol, you remind me of... ME... Before DC Power came out with the XP line, i was talking to them about this very device, the Quicktifier i think is what it's called. They told me then don't worry about it because the XP line will already have dual rectifiers and stronger ones than what that thing has. I'm tellin ya.. XP XP XP..
From what DC Power has told me before- We GUARANTEE that you will NOT be able to burn up an XP line alternator... They already have dual rectifiers built in, along with awesome cooling... And let's not forget temperature sensor... If the alt gets too hot, it is designed to cut maximum current output back by up to 50%. They are pretty indestructible... This is why, in my opinion, they are so popular.
Ok guys.. Who is ready for another GROUP BUY!!!!!!!!!!!!!! SPL-Lab is about to come out with their SEVENTH pressure sensor... Yes, SPL-Lab now has 7 different pressure sensors now... SPL-Lab has spent a LOT of money in production of this new device and in about 45-70days from now, SPL-Lab will then be ready to ship out the orders to the USA. So, what is this new meter? It is the first one of it's kind! You will not find this anywhere else on the planet.... A pressure sensor that is accurately calibrated from 130-180dB, completely wireless! Bluetooth controlled! Range = OVER 300FT! (direct line) Plenty of transmission strength to prevent drop off signal. Internal battery, Li-ion 800maH. 3hrs of continuous play time. Can be charged back up via usb cable... Meter can STILL be used while charging via usb cable. How can you access this meter? This is where the fun begins From a PC\Laptop From your Android TABLET! From your Android CELL PHONE! SPL-Lab has already written it's software for the Android market, completely free to download and free updates for life! Here are some pictures of the meter- And i know you guys want to see this.... Comparison of SPL-Lab Wireless Bluetooth meter VS Termlab- So.. we know all about the meter now, so what's the price? It just gets better The Termlab goes for $649 + shipping... IT's wired and requires multi external hardware units to operate... This device is wireless, calibrated to the accuracy of the Termlab(and all of SPL-Lab's meters are as well), and our software that is used for this wireless meter on BOTH PC AND Tablet\ Cell Phone will be able to control up to 2 wireless meters at once! The software is very visual, nice vivid colors and a ton of user capabilities along with a new update coming soon that will make you faint... (i hope not but possible). RETAIL Pricing of this meter = $599 MAP Pricing of this meter = $469 (this is the pricing it will always be sold directly through SPL-Lab USA) Group Buy Pricing = $250 NOW, $159 once products have been shipped into the USA and inspected and tested. Total Group Buy price- $409 per person! All Group Buy customers NEED to have their upfront cost of $250 sent to ME by no later than Oct.10th, 2011! Again, to be a part of this group buy, Send $250 between now and Oct.10, 2011 to ME. After that, we will request the other $159 once your product has passed inspection and will be delivered within the US 2-4 transit days. Paypal address - [email protected] DO NOT PAY AS A GIFT! You are making a business deal and paying as a gift is ILLEGAL and unsafe for transactions that involve materialistic items. If you have ANY questions, please feel free to ask.. -
they are being uploaded now, within 5 minutes, the 2 icp links on the bottom of first post will work again... Murder Go Round's peaks shifted some.. Now it peaks at 39hz, 31hz and anything else in the mid to high 20 range.
- 90 replies
-1
hold on guys.. my dumb ass isn't done with these 2 songs...
Added 2 more songs... ICP only- ICP - Murder Go Round - 24,31,41hz ICP - My Fun House - 29-60hz
I used to listen to them a LOT back in the day. Now, i'm more after listening to music a LONG time ago because 105% of today's stuff is pure crap. It's funny you asked that because i still have some more of their songs finished that i haven't uploaded yet.
Added another song- BE WARNED, there is only 1 bassline.... 20HZ This song is kinda creepy so don't play in the dark Plavalaguna - original speed, 20hz only.. beware! http://www.box.net/shared/i6rm0zapvhrmod9o79af
Added another song- Mondoshawan - Peaks at 28hz... and idles lower than that.. below 20hz.. Original speed, not slowed! http://www.box.net/shared/cv4bv4snufdnqd3n665g
Twiztid - Ha Ha Ha Ha Ha I've made some demos with that song. Peaks at 50hz. here is a video i did of one of the demos back when cell phones were in black n white... The note hits around 1:05 http://s303.photobucket.com/albums/nn147/shizzzon/?action=view¤t=VIDEO0024.mp4
