carguy6702
Members
    73
Everything posted by carguy6702
  1. carguy6702
    sundown sa-8 vs SS rl-i8
    what do you guys think about these two subs? im looking to get a pair. of either i like both sealed and ported boxes. which is a more all around sub lows and highs. which can give better hitting lows? and can take a beating. i have a saz 1500d that ill be using at 2ohms
  2. carguy6702
    Space is limited. I have a reg cab truck subs would go behind seats.
  3. carguy6702
    Using Router
    i have a router but dont know how to make the circle cutouts and do curves on wood. can i get some help? thanx
  4. carguy6702
    Lower Hz songs
    what songs do u recommend listening to with lower hz?
  5. carguy6702
    Q 12D2 power handling
    I have a 12 Q D2 w/BP power. and just got a SAZ1500D. how much rms can a stock Q take daily. how about w/BP Power. i know Fi recommends 1000. just think it can take more. just want to see how much it can take to adjust the amp properly.
  6. carguy6702
    Using Router
    thanx for the info guys. this weekend I'm going to try something on spare wood.
  7. carguy6702
    so a larger ported box is like a sealed box, that they both need less power to push the sub,and pushing it any more will cause damage??
  8. carguy6702
    what do you mean by "mechanically depends on box"?
  9. carguy6702
    vc resistance on Q 12D2
  10. carguy6702
    what should the resistance be on the D2 models? i tested mine to day and i got 1.4ohms per vc.?is this right
  11. carguy6702
    Lower Hz songs
    doesn't have to be just rap could be anything
  12. which would you get?why? RF T10001db or Sundown 1500D for a 12 Fi Q w/BP power
  13. carguy6702
    RF or Sundown
    i like both also about the same output at 1ohm and with sundown's sale bout same price also which is cleaner in watts?
  14. carguy6702
    12 Q with JL 500/1 clipping
    I just got a 12 Q D2 with BP power hooked up with a JL 500/1. in a sealed 1.5(20*13*15.5) after sub displacement. is the amp to little for the sub? i set the amp to JL specs. and then i get clipping. i've used the same amp on others subs and get better sound and more power out of it. but with ported boxes using the same JL specs. how should i set it with a sealed box?
  15. carguy6702
    ok i got it. so i had it at 1 ohm decided to try 4ohms. then used the dvm and test tone to adjust it, now it dont clip. sounds good. all i need is a new amp to give it 1000rms
  16. carguy6702
    I AM A go readjust now with DVM and 50 hz test tones and see what happens
  17. carguy6702
    Box Building
    what did you guys you to build your ported box? i mean how did you figure out port length and tuning? what programs did you use or equations.
  18. carguy6702
    Box Building
    i have built boxes before,but not from scratch, i've used blue prints from CA.com and others but, i want to build one from scratch, do all the calculations and stuff, just to know how to do it.
  19. carguy6702
    Silverado Blow Through - Videos!!!!!!!&#33
    great job, like the box, and nice truck
  20. carguy6702
    Icon and SSD
    looking for a new sub for now want to a 12. which would you go for? both handle same RMS and bout same price w/options on SSD.
  21. carguy6702
    Icon and SSD
    thanx for the input
  22. carguy6702
    RL-i 10 box size?
    whats the max box size for the 10? i was thinking 1-1.5@30 is it the same for the 8?
  23. carguy6702
    BTL an lows.
    after seeing the vid i dont think its cause the truck is old its def. the sub
  24. carguy6702
    BTL an lows.
    being that the BTL is more spl oriented<<--- or does it matter if a sub is spl oriented? how does it handle the lows?
