frogcase2002
SSA Regular
    2,134
  • Days Won
    52
Everything posted by frogcase2002
  1. frogcase2002
    2 12" zcons 4-6k trunk wall
    If you get time you can swing by where I work and you can use a good meter.. But idk if that's the problem or notI hope thats the problem but I dont know why one would read somthing and the other coil nothing at all
  2. frogcase2002
    Going to have to wait on some recones for the big build to be playing. It does suck the zcon recone went from 115 to 160
  3. frogcase2002
    One of the zcons I pulled out of the car reads like 14 ohms on one coil and nothing on the other for some reason. Im hoping its just my cheap meter I have cause the sub only had a few hour play time on it. . Anyone have an idea why this would happen?
  4. What are the specs of your enclosure?
  5. frogcase2002
    is this the sp4 era?
    I want a musical sub that can dig deep. I listen to mostly rap. Not really worried about numbers but it will be a plus if the subs can do pretty good on the meter..that's why I narrowed my options to three subs...Ethos, tantric hdd, and sp4 of courseNo zcon or evil? X2
  6. frogcase2002
    Team IAK Explorer
    Keep the pictures and videos coming!
  7. frogcase2002
    (2) 12" RE XXX XBL^2 04-05 build
    I should be going to some of them once my van is playingright on. you sticking with zcons?Yea got 4 right now
  8. frogcase2002
  9. frogcase2002
    Will have to wait for all the details but 4 zcons in a wall on over 10k should be coming soon
  10. frogcase2002
    Forsure want to hear this when its done!
  11. frogcase2002
    The trunk build is over with but there is an up side
  12. frogcase2002
    It's been awhile, I'm back! Few questions
    Good to see you on here again man
  13. Alright, ill try to say everything that is happening. One thing is that every once in a while my temp gauge goes all the way up and makes my car say to check engine temp then if I speed up or slow down or sometimes do nothing it just goes right back to normal. It happens almost everyday. Also almost everytime I turn the car on all the lights on the dash stay on like the brake light and check engine and stuff but if I turn the car off and back on its fine and dash is like normal. Another thing is that when I turn the heat on it takes longer than it used to to heat up . Then it will get cold and back hot randomly I don't know if any of this is related. Just trying to figure this stuff out. Any help will be appreciated By the way it is a 2005 mercury sable ohv
  14. frogcase2002
    trying to figure out some problems with my car
    Where would they be able to test it? Should I just get an ecu from a junk yard and try it out?
  15. frogcase2002
    Hello to all
    Good to have you!
  16. frogcase2002
    Hello All!
    Welcome!
  17. frogcase2002
    Yea there is a really good amount of flex from the system in the car so I guess that could be it. Should I just start taking apart the dash and checking wires?
  18. frogcase2002
    I guess I'm not 100% but iv had cars over heat and know how they would usually do and smell and stuff. . And the gauge just goes all the way up in a split second and go back down the same way. So I wouldn't think a motor can heat that much and back down that quick. . And it has happened pretty much right when I start the car for the first time in a day but then sometimes it wont happen at all durring a day
  19. frogcase2002
    I was thinking some kind of thermostats. Figured that's what was messing with the engine temp. Gauge because I know its not getting hot but the gauge keeps saying it is
  20. frogcase2002
    Why did you take the time to type this?
  21. frogcase2002
    AccuWave Pressure Meter teasers
    Pretty badass!
  22. frogcase2002
    XCON 12" - New spruced up box concern
    Looks like your "Kinda" turning it into a 6th order bandpass .. why not have a 4th or 6th order bandpass designed for it if your wanting to fire it into the cabin?
  23. frogcase2002
    DSS Tridents and Twisted Sounds S-10. Road to 166dBs
    Hell yea man!!
  24. frogcase2002
    ? I don't get it
