Jason Witt
Members
    607
Everything posted by Jason Witt
  1. Having a secondary battery adds reserve and delivers large amounts of current upon demand. I would never advise blasting your gear without the engine running for daily use. As for clipping lights, the ear is a much better device to detect clipping in your subs IMO.
  2. The amplifier would be drawing around 150A running at full power. I would suggest a secondary battery.
  3. Jason Witt
    Problem with C1100.4 highpitched noise.
    Also if your signal wires are ran along side the power wire you will sometimes get excessive noise through rca's. I agree with Julian to check your grounds as well.
  4. Jason Witt
    will my system be getting enough power?
    Here is how you figure out if you have enough power. Ohm's law is very simple to understand and apply. For the amount of current you will be drawing for any application you divide your total wattage by your idle voltage. For instance for the 500 watt amp, take 500/13.5=37 amps. That is assuming 13.5 is idle voltage, to figure out exactly what yours is, use a DMM to test voltage with rpm's at idle directly at your battery. Hope this helps you to find solutions on your own and gain just a little knowledge while you're at it. Study and review ohm's law so you can find solutions to just about any electrical dilemma.
  5. Jason Witt
    My First "Real" Jeep Build
    Can't wait to see it finished. Very nice.
  6. Jason Witt
    demoing at the bassheads meet 13'
    Looks loud!
  7. It will take no time at all to burn up your stock alternator or seriously damage an amplifier or something of that nature. I gave him the amount of current draw with the t1500 in his electrical thread and suggested a larger alternator either way.
  8. Jason Witt
    36 or 37 amps worth? I would just go with the t1500 because you are still going to have to upgrade your electrical either way.
  9. Jason Witt
    With the t1500 and the t400.4 your current draw @13.5v would be around 140 amps. That doesn't include any stock components. I would go with a larger alternator if it were me.
  10. Jason Witt
    Re-cone help
    The difference in excursion may be due to different spiders as well.
  11. Jason Witt
    Oh hello there
  12. Jason Witt
    Voltage Dropping
    You have more than enough reserve for your current draw. It does sound like a charging issue. If it were me, i'd test the alternator to see how many amps it is producing with your gear on at normal listening volume.
  13. Jason Witt
    Voltage Dropping
    Check all of your connections to make sure they are solid, especially your grounds. If you suspect your alternator is at fault, test it to determine if it is the source of your issue.
  14. Jason Witt
    lets see the king cab builds ,
    Read and follow forum rules Educate yourself before insulting our intelligence Saying dumb shit will get you nowhere Pay attention to what they are trying to tell you Everyone is here to help Continue your arrogance and childish ways Time to hit the door Hope this helps get you the ideas you are looking for.
  15. A basic 4 gauge wire kit will suffice. A distribution block will work just fine for your two channel amp.
  16. I sure hope this gets resolved for you man. I am in the process of choosing different subs for the wall i'm doing, and the Death Penalties were on my list. I would also be very disappointed if they don't make this right somehow. It really does make folks hesitant to buy their products. I know I am now.
  17. Jason Witt
    allow me to introduce myself
  18. Jason Witt
    Air line insulation?
    You could try out some sort of heat tape. I don't know what else you could do. Have to make heat to keep the line temperature above ambient.
  19. Jason Witt
    Fi Audio Sub
    Make sure your grounds are clean and solid. Lots of people overlook a bad ground.
  20. Jason Witt
    Half of the port covered up?
    You'll know for sure when you get your amp and try it out. Try some test tones with and without the "cover."
  21. Jason Witt
    subwoofer decisions !!!!!!
    I like my AA Mayhem's. I have reconed them with BTL parts, they are basically the same I think. They are 12's and pound and get nasty low on 5k.
  22. Jason Witt
    Welcome to the IHoP
    I bet she likes bass.
  23. Jason Witt
    Bouncing bottles
    Sorry for the dirty car.
