Jason Witt
Members
    607
Everything posted by Jason Witt
  1. Jason Witt
    Anyone getting Dec. orders yet?
    It will get there and the wait is well worth it.
  2. I have seen several instances where peoples rca's get pinched, sheathing cut, the ends short out. Out of this whole thread the SIGNALING seems to be the issue. It is very possible one of the above scenarios quite possibly could have happened to you. It could be a loose wire somewhere at the subs, but I doubt it.
  3. Then it should read right around 2v then.
  4. What is the preout signal voltage rated for on your head unit? That's where it should measure at.
  5. Try an MP3 player for a different source, or a dmm to check the voltage in the rca's ran from your head unit.
  6. Run a different signal source to your amp to see if it's your head unit failing.
  7. Mitek owns MTX and they are out of Wisconsin.
  8. And then.... lol And then I used it for a couple years and sold it. I don't think it had much longer left to live.
  9. I have had a few MTX amps and they always did a pretty good job.
  10. Jason Witt
    New to SSA
  11. Jason Witt
    2007 Ford Escape build...
    That's awesome man. My daughter loves to help out too.
  12. Did you purchase this new or used?
  13. Jason Witt
    Amp(s) for 6 Lethals
    There are three loads to choose from with these subs. Half ohm, two ohm, or eight ohms. (If you have all six subs.)
  14. Jason Witt
    J-roadtatts DCON enclosure build!
    I can't view them either.
  15. Jason Witt
    Question about JL W7 Ohms
    That amp will be fine for that sub. I'm not a big fan of JL, so I have never owned one to give you any further information.
  16. Jason Witt
    1 SSA ZCON on 1 BC5500
    Great excursion!
  17. Jason Witt
    '05 f250 new pics thread
    That is one slick looking truck man!
  18. Jason Witt
    How do you apply the sundown audio sticker?
    I think your sticker is ruined. Was the glass cold, did you press each letter on firmly?
  19. Jason Witt
    Clean the glass really well peel the backing and apply like any other vinyl sticker.
  20. Jason Witt
    Noob with wire gauge problem
    i was thinking about getting a volt meter for that reason. Is that a good idea or a waist of time? volt meter for what? well a lot of people hook them up to THE amp so they no for sure the volts arnt dropping Volt meters should be connected to the battery with a fused lead and chassis ground. They are a waste of time and money unless you are running large amounts of power IMO.
  21. Jason Witt
    Amplifier Noise Issue
    I had a similar issue once. I switched my grounding location and it solved my mysterious noise problem.
  22. Jason Witt
    feels good to be back yall :) check her out!
    The truck looks nice!
