357 -
Days Won
1
Content Type
Profiles
Forums
Gallery
Everything posted by no_username
Wanted to point something out with the DCON Dia
no_username replied to no_username's topic in General Audio
I just bought some rough grit sandpaper sponge. Went pretty quick and got as even as i could Also the rubber on the subs cause forba wider dia also Got a good tight fit though:) -
But i thought they could handle it
So i need to set my gain to 24.49v My multimeter is in AC volts mode and its only reading like .200v... Ugh???
270amp alt in a 99 Dodge Dakota
no_username replied to kjmass21's topic in Mechman High Output Alternators
Only ricers wash their engines -
I didnt have gain turned up enough for the decimal point to move over God im an idiot LOL
Nvm i got it. I over complicate things
Wall socket voltage reads 124.4
i cant set the range. Its ranged for 500v
http://www.extech.com/instruments/product.asp?catid=49&prodid=291 idk if its scewed up but its shows DC with the 00.00 then if i select AC it goes to 0.000
Yeah battery is good as its new Gain is at lowest right now. However even when i turn to ac volts it starts off as 0.000 instead of 00.00 im using volume 25/35 yes 50hz 0db
Well sanding my hand is a pain in the ol geezer. Hitting up lowes tomorrow for a sanding block and some rough grit paper. Good idea, kind of what i was thinking phi -
do i have to disconnect speakers on a mono amp to set gain
no_username posted a topic in General Audio
I hope not -
I am as we speak. Have to do it by hand, dont have a sanding block Pics when im done -
Yeah i was thinking about sanding, all i have is emery cloth. Will shall see how that works ;-) Is the dia on the xcon 9.25? -
Here is a well written guide on setting gain http://slumz.boxden.com/f359/guide-tuning-amp-916831/ Sticky? -
My speakers arnt even connected to my amp -
Thanks for helping me pm! Truly appreciate it
I have everything connected up but amp wont start up!!!??? Any advice...? Im going to sand the ground more see if that could be it and check the remote wires also. Thanks
Got everything all working!!! They sound mmmm mazing!!!! Wish i had got 12s though time to fine tune the amp But boy o boy im happy!!"
Going to be the AQ750 and 2 10" DVC SSA DCON Custom built box by DC CREATIONS 1cube per chamber So heres what i have so far, tomorrow i will upload more as im going to be installing the amp wires and i will post up my car.
Well the 9v test passed as the cones moved Going to buy more wire and do a better wiring job. Have a feeling some wires werent making contact
Ok so i checked the ohms One vc reads 3.6 The other only reads 2.9-3.1 Faulty sub?
Ok so i got it wired up. Now only one sub is working <.> God dangit this just cant be easy can it its the alpine cde122
I take that back. Plugged my hu rca back in and the bass is going at 2 ohms. Time to hook it all back up!!! Pm youve been a been help. Thanks a ton!!! Report back after im done
Sub setting is on. Eq at flat Plugged in my rca and no sound. So eithet faulty rca or bad rca jacks on hu. Any way to test it?
