2,847 -
Days Won
10
Content Type
Profiles
Forums
Gallery
Everything posted by EPerez
subs not playing right, sound hollow
EPerez replied to EPerez's topic in Amplifiers / Head Units / Processors / Electrical
My head unit is only 2 months old. My second batt is grounded to the same place as my amp. Is that bad? I'm not sure how ur saying plug my 3.5mm cord into long run of rca? -
I have a pioneer aftermarket radio and I've been reading about a ground loop. Could that be a problem even tho the subs work fine when using 3.5mm and phone? -
Well i tried different rcas and a different amp and the problem still exist. When subs aren't even playing they are making a high humming noise which gets louder when I step on gas and rpms go up. I'm not sure what else to check!! -
which one would you choose?
EPerez replied to tkev77's topic in Amplifiers / Head Units / Processors / Electrical
I had an audiopipe before my crescendo bc2000 and i didnt like it. How much do u have to spend? -
2000 rms? amps
EPerez replied to hustle313's topic in Amplifiers / Head Units / Processors / Electrical
I've heard those were pretty good. -
2000 rms? amps
I thought the audiopipes got real hot too like realfish said. I bought a crescendo bc2000 and I love it. It stays cools and it seems pretty effiecient. I think bc2k would be perfect for you. -
Pretty sure he's talking about something like this. http://www.radioshack.com/product/index.jsp?productId=3449316 Plug I pod into the stereo cable and then plug the rca's in the amp, then play using the ipod, not headunit. I realized what he meant just before you sent that haha but yea i tried that and the bass hit like it supposed too! So is there something wrong with the rcas? -
What do you mean? -
If my rcas are bad will I hear any bass or will no bass be heard? -
I dont think i have that? -
Disconnect rcas from amp? and also how would I run something else? How do i hook it up? -
Sounds the same even with one. -
Which connections? Wiring from amp to subs/box? -
DC POWER or MECHMAN
EPerez replied to CHRIS 323's topic in Amplifiers / Head Units / Processors / Electrical
Have you checked out singer alts from mike singer? Prices are less expesive than both and are great from what I've HEARD. I haven't used any of the 3 but I will most likely be getting a singer alt for my trailblazer. He has lifetime warranty. -
Yea the comps r in a ported box and the jls are in a sealed. The jls worked before but when I put both in the same sound is with both boxes and subs. -
Buy another bc2k or buy 2 saz1500s?
I'll jus buy another bc2k then and strap it at 2 ohms. I know I dont have the electrical for .5 ohms strapped lol. Thanks for the help guys! -
EPerez posted a topic in Amplifiers / Head Units / Processors / Electrical
I recently bought a warden 21 and its a d1 so I would have to wire my crescendo bc2k to 2 ohms or .5 ohm. Itd be ridiculous to put 1100 rms to a warden haha but also I don't wanna run my amp at .5. So what I was thinkin is buying 2 amps and strapping them at 2 ohms. Should I buy another bc2k or sell mine and buy 2 used sundown saz1500s? Do you think theres a big difference between the two? My electric consist of big 3, deka 9a31 as second batt with all 0 gauge. I know I don't have the electrical for it full tilt but its a safer option so I would be running at at least 2500 rms I'm also in the process of getting a HO alt, possibly from singer. Please explain why you would choose whatever you would do. Thank you very much.. -
Good luck buying it! Mr. Bojangles is great to deal with. I should be receiving it on tuesday. I Cant wait to have the beast.
Is there anyone that will do them for free?
You need to measure out ur trunks dimensions. Find out the opening of trunk and see how big of a box you can fit thru there. Reply with info on what your system consist of and the dimesions in height, width and depth. Explain your listening goals, types of music and what type of box. This info will allow someone to help you design the right box.
different vechiles and planel flex and vibrations...
EPerez replied to JohnHinerman's topic in General Audio
I noticed this too when i switched my 15 hdc3 to my trailblazer from my 300m. My 300ms windshield, mirror and the my roof towards the front would flex like crazy bit in my tb they would barely move. I even have more power on it in my tb. This is y I laugh when people say shyt sucks because it doesn't flex everything. -
Um aren't the ssds 600 rms? I know they will take a little more power but a 2400 per ssd I don't think is too smart. Why not get 2 btls if you plan on doing that? Unless you have a budget but still a brz2400 would be good for the pair. Nope 1000rms each. He also needs to get dual 1 ohm voice coils if you want to stay with one amp. What is this going in? Oh I didn't know that but yea dual 1s for 1 amp. That will give you 1200rms each.They will be loud depending on the box and type of vehicle. Correct but the OP said he wanted to add another brz2400 and I don't think he needs that.
the clipping indicator is bullshit. no one should be relying on it. OP, if you want to save some cash then buy used. How is it bullshit? Does it not read accurately? And I don't rely on just that.
