cloud77
Members
    972
Everything posted by cloud77
  1. cloud77
    Torn Q12 surround help
    How did you tear it? Is it separated from the cone?
  2. cloud77
    Help me ID this Fi 18 I bought
    Almost looks like a chaos with Fi parts
  3. what kind of amp? electrical? Voltage monitoring?
  4. cloud77
    sp4 gen cut sheet
    You shouldn't go by BTL cut sheets..
  5. The box I built for a HTQS pre-09 SSD 12" was 1 cu. ft. so definitely go larger.
  6. Item for sale: PSI Platform 3 motor and basket Description directly from PSI: The Platform 3 series is a massive subwoofer, designed for massive amounts of output! The standard version of the Platform 3 is geared towards very loud, but still very musical systems. It is designed to deliver everything from low octave, window flexing bass to throat tickling upper range bass frequencies. These subs deliver very good sound at very high SPL levels! Power Handling Ratings: Standard RMS Power Handling - 2500 watts Hi Performance RMS Power Handling - 3000 watts Peak Power Handling - 6000 watts SPL Burp Power - 8000 I have original 8 spoke aluminum cast basket without terminals, or I can include a 12 spoke aluminum. Recones can be obtained from PSI's site or car audio classifieds. I was quoted 165 shipped with direct leads, sewn lead wires, CF cap, an glue included. Price: 200 plus shipping anywhere in continental US States or Best Offer. Shipping: US only. Will be properly packed and insured. Coil gap is already stuffed with shop towels to prevent pole shifting. Pictures:
  7. cloud77
    Sub Selection for 500 watts RMS in Sealed Enclosure
    I think sonic is trying to get rid of their old stock type Rs for 100 a pop
  8. cloud77
    thoughts on subs
    get your sp4 set up correct. this time around.
  9. its worth a try. You can build a sealed box in a flash
  10. cloud77
    needing altenator for 03 blazer
    You should be able to big 3, good wire, and batteries to maintain. You really don't want to go cheap on an alt.
  11. The box Fi provides cut sheets for is 1.25 cubes. I would do that. You should have a noticeable difference with a larger sealed box. even if its less than .5 cubes
  12. 1 cu. ft is what they recommend for the SSD. For the Q, you will need about 1.5-1.8
  13. cloud77
    SP4 Quad Box question
    I normally like to hear my music.
  14. cloud77
    The term lab is the worst thing that ever happened to car audio
  15. cloud77
    No problem. Sounds like you're ready to get crazy. Thumbs up!
  16. cloud77
    16 should be good. A little bigger wouldn't hurt. I would shoot for 4-4.3 cu each. I would say about 14-18 sq inches of port per cu foot.
  17. cloud77
    so you're @ 13 cubes with 3 woofers? What are you wired to now?
  18. cloud77
    I agree. People could have been more helpful here..
  19. cloud77
    thoughts on subs
    I have 2 Q drivers I'll be saving for a summer bump down.
  20. cloud77
    BTL UFO single slug spacer
    Finally got my hands back on some straight street jam material. AKA: Qs and a BTL UFO I've seen some UFO BTLs have a spacer in between basket and the motor. Is this just an adapter for basket patterns or is it a beneficial option to the sub? Excited for my new Fi experience and so is the wife =]
  21. cloud77
    I still am seeing spacers on these. I ordered a recone with HiXmcoil, so I think I will need one to prevent the coil from slamming the raised motor lip.
  22. cloud77
    FS: DSS Magnetar
    That motor structure looks crazy.
  23. cloud77
    FI Q12 sounds horrible
    No. High Qts only makes the coil gap a bit larger to take away some motor force away from the driver and helps with maintaining its linearity at high excursion levels. A sub without the HQTS option will still perform well in reasonable volumes of a sealed enclosure with good output.
  24. cloud77
    Got the motor in and its in really good condition. Ready to recone. With the longer coil would I need a spacer or use washers? anyone?
