972 -
Content Type
Profiles
Forums
Gallery
Everything posted by cloud77
You can get it repaired, don't go to PSI. But I've never heard anything like this...I have the same pre-09 motor and I beat on it from recone to recone.
=\ Its getting too warm for my comfort
Thanks for saying that, it will be my future home theatre sub. I was actually thinking crazy to sell it, but comments like these will keep it around a long time. I'm surprised you didn't build an 18. *Currently looking for a motor* Everything is looking and sounding good in my ride, but I am pushing too much power to the XXX =[. She's getting warm, and I may consider selling it or putting it on the shelf for a HT project.
to who =\
So the compression plug does a great deal of cooling? Could you possibly machine a couple of these for my Qs?
showtimeSPL says there was a problem with the cones, at least on the Brahmas xtreme
Dc audio never ceases to amaze me (sarcasm alert)
cloud77 replied to mlcantin's topic in Subwoofers / Speakers
he's hooked up at 1 or 4, maybe he thinks if hes hooked up at 4 ohm and turns the gain all the way up hes getting 500 x2 =/ -
New Q 12 barely plays and bottoms out on low volume
cloud77 replied to Chris Duncan's topic in Fi Technical
Why didn't you get internal leads? Definitely an option that you should get especially when running sealed IMO. Sounds like you need to do some troubleshooting. Check the subsonic on the amp bass eq, exc, check your voltage to amp and voltage while playing. Your voltage may be the reason for low power and your low power may be the reason for the sub getting hot. Spend more time on the forum and learn to troubleshoot this on your own instead of bothering the local shop with equipment you didn't buy from them. They will only send you astray from the truth behind your problems if you don't know what you're doing -
Pre-09 motors have a power rating of 1000 rms and is a different motor than the 2 models they made after that. All the different motor types take the same recone.
That recone may be short lived
Does the Brahma have the same motor as the XXX v3?
Hard to believe the magnet cracked if it was in the box the whole time
Can someone from Fi Please respond to me so i can know whats going on
cloud77 replied to Pink Noise's topic in General Fi
Shawn supposedly took care of a correction to an order I placed, so I need to come in contact with Fi as well =[ -
You wouldn't want the enclosures to be the same size
Precision Power PPI BK1800.1D RMS Power Rating: 4 ohms: 700 watts x 1 chan.2 ohms: 1100 watts x 1 chan.1 ohms: 1800 watts x 1 chan. -
If you reconed it it would probably be closer to 1000 rms
advice on on 18inch subs that will handle 6k whatts need new ones
cloud77 replied to toxicmods's topic in Newbie Sign IN
Lol @ I saw someone selling some of those on classifieds -
Since you have not built yet you can make it smaller.
Simple solution is that you can drill a tiny hole in between chambers and wire them all to one terminal cup, being that you probably won't be feeding 8 gauge wire between them.
Confused with ohms
cloud77 replied to Doug McCambridge's topic in Amplifiers / Head Units / Processors / Electrical
If you can't gain any info on that, its probably time to take the subs out and just wire through the port or drill a hole. -
Confused with ohms
wrap a smaller wire like 14 gauge around the nuts and duplicate the wiring. Try and see if you get the same nominal or different in any way. The bolts may be too close to each other maybe. -
You may have time to cancel and get you a true American Made woofer
How are you stuffing 2 18's in a zx3? -
Confused with ohms
does each bolt outside the box read correct? I would start there before you pull the subs out.
