cloud77
Members
    972
Everything posted by cloud77
  1. cloud77
    Fi Sp4 15" on 3k. enclosure?
    So I'll be running my SSA Zcon 12" on 3k for now until I get around to purchasing a recone for an sp4 motor I got in a trade. My problem is..I have a trunk car and limitations on box sizes. Depth and height are a problem for me. I have come to the conclusion that the biggest I can fit is an L port enclosure about 3.9-4 cubes. If I give it about 4 inches of port and still have net, will this enclosure server well to the sp4? I'll be running 3k @ the sp4. If not recommend what you all have experimented with.
  2. cloud77
    sealed box sp4
    how big was your sealed?
  3. cloud77
    Name off some POS amplifiers
    If you're going to run sleeper, just run amps that people don't normally have. Thieves normally steal your stuff after they hear how loud you were rockin down the road.
  4. cloud77
    Design questions for 15" or 18" SSA Xcon
    If you strictly want to run sealed, look into an Fi Q series. They sound hella sexy in sealed and have a high QTS option which makes the coil gap larger to take away from the motor force, thus better sound quality in a sealed application
  5. cloud77
    PHATBOi's Sundown X12 Build
    I was 2 beers away from buying a SHKAMP 2500D on ebay for 99$ this weekend.. Let us know what it sound like! Keep us posted!
  6. cloud77
    ZCON recone D1 to D2 ????
    coil gap is universal
  7. http://www.ebay.com/itm/Mmats-D2100-5-D-class-mono-amplifier-/290975856571?pt=Car_Amplifiers&hash=item43bf8337bb http://www.ebay.com/itm/MMATS-PRO-AUDIO-CLASS-D-POWER-AMPLIFIER-DHC1400-2-/130989962390?pt=Car_Amplifiers&hash=item1e7f9c3496 I sold my d300hc for 225, so I'm sure you can find one for this price is good shape. Quality amps, quality service.
  8. cloud77
    I might have to get one of those amps, for the price, why not. I saw you chime in on ****.
  9. Its a Dual 1? Consider running @ .5 with a MMATS amp. d2000.05 would be suitable or d300hc to run @ 2 ohm. or d100hc to run at .5
  10. are you going to run the xcon sealed?
  11. cloud77
    Are Planet Audio Amps good
    If you are looking to power a true 1500 rms look into MMATS, Audioque, sundown, incriminator, DD, exc. Everything in the SSA store is NOT garbage. Theres a fine line between a SAZ1500.1d and a hifonics brutus 1500bx or whatever you want to compare to. I personally will run MMATS amps for the rest of my times on this earth, because they create overwhelming results for the small footprint they create. Look into older MMATS dhc amps. If you can find one in good condition its a flawless choice for powering 1-2k subs
  12. cloud77
    Car Audio Subwoofers For Live Audio
    acquiring knowledge requires a bit of work. Read up on stuff. experiment. then ask others on how your experience could have been better
  13. cloud77
    I'm sure you can find a better way to power that woofer, even if you wanted to add another in the future. Planet Audio sucks IMO
  14. cloud77
    How Long Will Fi Car Audio last
    I hope so. Recones too
  15. shipping goes both ways, I am needing to sell my 15" zcon or trade for a 12" . I have no space for a 15" anymore because boxes are getting bigger =[
  16. cloud77
    fi sp4 recone?
    the screw driver and hammer is just to get things off. you will still have to dremel/sand down things clean. That should be good.
  17. cloud77
    fi sp4 recone?
    looks a little over done, you shouldn't grind down the metal so much, but should be okay. Just make sure the coil gap is clean with compressed air and duck tape folded to probe.
  18. cloud77
    I almost feel guilty
    you're not going to get any results from a dmm unless you clamp amperage compared to other channels. If its blown. You'll know by experimentation.
  19. cloud77
    I've had some sick door flexes with single sub setups so far.
  20. cloud77
    Not at first, you really have to train your ear. The extra vibrations on my door panels and front window were the kicker.
  21. cloud77
    Sub Spiders
    country of manufacture
  22. cloud77
    db-r I think is the only good one. But there are others. Be careful and read reviews of places before you use them. I have an '04 GT and I love it as well. I just used GT liquid-damp on the whole trunk and spray painted it gun metal gray to match the car. The liquid sound dampener really conforms with that trunk well. Plus I hate using mats and asphalt based deadeners. I had a 16" tall box that I recently had to destroy inside the trunk because it swelled from the humidity.
  23. cloud77
    of course hes going to say that. you already made the deal right? If its not putting out sound at all, or its distorting/cutting out its probably bad. You should have bought the zcon for sure because the motor weight is worth 200 alone.
