bigjae1976
Members-
584 -
Content Type
Profiles
Forums
Gallery
Everything posted by bigjae1976
4 18's? How much SQ are you looking for? I think the 2 BTLs at max power would beat out the Q's.
Some more info.... To be honest, I was kind of weary about getting the Q and probably had the same apprehensions that all of you have. Here is another comparison. I have had a couple of opportunities to listen to an IDMax and W7 in both manufacturer spec sealed and ported enclosures. I can say that the Q outperformed them box in either alignment as far as SQ and SPL. The big 12" sub test confirmed this as far as the W7. The Q can not be touched as far as value. If you are on the fence about this sub, there really is no good reason that I can think of. The only question I can't answer is what advantage does the Q have over the SSD.
I have a 2004 BMW 330Ci. Here is a list of what I have: Eclipse AVN-5435 Audiocontrol Overdrive, ESP-2, DQX, and DDC US Amps USA 200x - tweeters (50x2) US Amps USA-400x - midrange (100x2) US Amps USA-2000x - sub (2000x1) OZ Audio CS-180 (old school superman logo) 1 Fi Audio Q12 D2 in a 2.0 cu ft box tuned to 33 hz with 24 in of port area (small, I know). I just purchased an 06 RE XXX 12 to replace my 05 XXX 12. Then I heard about Fi so I bought a Q12 just to try it out. The customer service was excellent and the sub was rushed to me in time for Heatwave in San Antonio (USACI). I got the box which was similar to RE's packaging. The box was ravaged but the sub was okay. Not sure if I can really blame Fi for this. I installed the Q12 into a 1.0 cu ft sealed box just to check it out. I was so shocked at how light the sub was. ~27 lbs was the shipping weight I think. Much lighter than both of the XXXs which is a good thing. Connected it to my US Amps USA-2000x with the coils wired in series so the rated output was 2000 watts, 200% of the rated output. WOW! This thing got amazingly loud and very accurate. I use "Operation Spirit" by Live and the USACI focal disc to test SQ. The low end is controlled and quick, fast bass lines don't drag and are very distinct. This sub also has great output in across the 3 lowest octaves, a weakness of the 05 XXX 12. Played some Red Hot Chili Peppers and Bass Mekanik. Output continues to be astonishing. The sub has less than 45 minutes of play time and is pretty stiff. So I dropped the Q12 into a 2.0 cu ft box tuned to 33 hz with a slot port (24 sq in). Got some port noise but I have limited space and the trunk masks the noise so its not an issue from the driver's seat. No significant loss in SQ in the ported box. Bass notes are still tight, quick, and distinct. Output...even more astonishing. Seemed to be louder than the XXX across the board. This also kicked the crap out of my 3 10" IDQs in SPL and SQ. With the 2000 watts, I did get a burning smell after 1.5 hours with 2000 watts. I was going pretty hard on the Q and it took it. My guess is that the Q can handle 1500 watts and maybe up to 1700/1800 watts with a responsible adult. Only at the highest volume level did I notice a loss in linearity. But no nasty suspension or banging noises. At this point I'm sold. Next day, both of my 05 XXX 12s are for sale and the 06 XXX 12 is being stored in my closet for home stereo duty in the future. I went to the comp. Sub is still STIFF! REALLY STIFF! Along with a 1st place in SQ, I scored a 136.X (forgot the exact number). Not a great number but keep this in mind: I forgot to put my back seat down My car is a HORRIBLE SPL car I didn't have time/forgot to setup my EQ for SPL testing With that, 136 is a damned good score. I scored a 137.8 with the 05 RE XXX 12 in a well tuned setup with the back seat down. I have no doubt that the Fi Q can top that. I was addicted to this sub for the next 30 days and then I deployed to Iraq. I got a noticeable increase in SPL and SQ as the suspension loosened up. I don't think that I ever really broke the sub in so I'm very excited to get back to the US. This sub is similar to the XXXs without the weaknesses of weight and lack of upper bass output. For the price? Its a no brainer. I tell people that this is the BEST deal in car audio. If anyone knows of a better one, please tell me.
Thanks for the compliments. I hope this helps. To be honest, I was kind of weary about getting the Q and probably had the same apprehensions that all of you have. Here is another comparison. I have had a couple of opportunities to listen to an IDMax and W7 in both manufacturer spec sealed and ported enclosures. I can say that the Q outperformed them box in either alignment as far as SQ and SPL. The big 12" sub test confirmed this as far as the W7. The Q can not be touched as far as value. If you are on the fence about this sub, there really is no good reason that I can think of. The only question I can't answer is what advantage does the Q have over the SSD. Done. My car is SQ oriented.
I just purchased an 06 RE XXX 12 to replace my 05 XXX 12. Then I heard about Fi so I bought a Q12 just to try it out. The customer service was excellent and the sub was rushed to me in time for Heatwave in San Antonio (USACI). I got the box which was similar to RE's packaging. The box was ravaged but the sub was okay. Not sure if I can really blame Fi for this. I installed the Q12 into a 1.0 cu ft sealed box just to check it out. I was so shocked at how light the sub was. ~27 lbs was the shipping weight I think. Much lighter than both of the XXXs which is a good thing. Connected it to my US Amps USA-2000x with the coils wired in series so the rated output was 2000 watts, 200% of the rated output. WOW! This thing got amazingly loud and very accurate. I use "Operation Spirit" by Live and the USACI focal disc to test SQ. The low end is controlled and quick, fast bass lines don't drag and are very distinct. This sub also has great output in across the 3 lowest octaves, a weakness of the 05 XXX 12. Played some Red Hot Chili Peppers and Bass Mekanik. Output continues to be astonishing. The sub has less than 45 minutes of play time and is pretty stiff. So I dropped the Q12 into a 2.0 cu ft box tuned to 33 hz with a slot port (24 sq in). Got some port noise but I have limited space and the trunk masks the noise so its not an issue from the driver's seat. No significant loss in SQ in the ported box. Bass notes are still tight, quick, and distinct. Output...even more astonishing. Seemed to be louder than the XXX across the board. This also kicked the crap out of my 3 10" IDQs in SPL and SQ. With the 2000 watts, I did get a burning smell after 1.5 hours with 2000 watts. I was going pretty hard on the Q and it took it. My guess is that the Q can handle 1500 watts and maybe up to 1700/1800 watts with a responsible adult. Only at the highest volume level did I notice a loss in linearity. But no nasty suspension or banging noises. At this point I'm sold. Next day, both of my 05 XXX 12s are for sale and the 06 XXX 12 is being stored in my closet for home stereo duty in the future. I went to the comp. Sub is still STIFF! REALLY STIFF! Along with a 1st place in SQ, I scored a 136.X (forgot the exact number). Not a great number but keep this in mind: I forgot to put my back seat down My car is a HORRIBLE SPL car I didn't have time/forgot to setup my EQ for SPL testing With that, 136 is a damned good score. I scored a 137.8 with the 05 RE XXX 12 in a well tuned setup with the back seat down. I have no doubt that the Fi Q can top that. I was addicted to this sub for the next 30 days and then I deployed to Iraq. I got a noticeable increase in SPL and SQ as the suspension loosened up. I don't think that I ever really broke the sub in so I'm very excited to get back to the US. This sub is similar to the XXXs without the weaknesses of weight and lack of upper bass output. For the price? Its a no brainer. I tell people that this is the BEST deal in car audio. If anyone knows of a better one, please tell me. Plan to do 2 Q12s sealed when I get back from Iraq.
I would have done this for free but definitely for a T-shirt. BTW, I just pee'd and I liked it. haha
SPL test, 2 1500d and 16v, mic at headrest
bigjae1976 replied to funkindatrunk's topic in Sundown Audio
What's the number? I can't open photobucket from my computer...it's a government thang! -
I think I found them last Aug on the old RE Audio forum. I had just bought a new 06 XXX 12 (got it pretty cheap) and then I saw Fi mentioned. I couldn't resist the $260 price tag for a Q12 so I gave it a try. Never looked back...06 XXX 12 sitting in closet collecting dust, sold my 2 05 XXX 12s.
I PM'd you my address.
Can someone repost the info and pics?
Wasn't there an Fi fashion line as well?
Someone probably misunderstood what Fi told them.
Nick, I'm in Iraq and they don't sell stamps here. Can you just send a couple over here?
Impressive! And the Q's are supposed to be an "SQ" sub. I tell everyone there is not a better deal in car audio. If someone knows of one, let me know.
Dumb noob question? What kind of screws to screw down my sub?
bigjae1976 replied to Z1truth's topic in General Fi
Okay Seriously, it sucks when the T-nut comes out when you are screwing the sub down. What a PIA! Coarse wood screws FTW! -
AGREED! My US Amps USA-2000 (pre-move to CA version) has 4 small screw terminals each for the power and ground. Good luck jamming anything larger than 8 ga along with everything else. A single large screw terminal anyone? I love that amp but I sure do hate wiring it up.
Screw terminals FTW!
True. But if that's my only beef, then Fi is doing REALLY well.
500-watt Class-D IS in the works as well SAZ-3000D has no firm ETA... although I am shooting for 6 months. 6 Mos? Cool...that's right when I'll be coming back from Iraq.
Maybe the data loss was a good thing...the stickies are a lot better now.
Great review. I would have said the same thing if I were writing the review. Definitely needs about 24 hours of hard use to break them in. I did get a good gain in the 70-150 hz region as the sub got looser. Here is my $.02...since mine got deleted. I went from an RE XXX 12 (XBL2 version). The Q12 is louder. "Operation Spirit" by Live has a really fast kick drum beat in the beginning. There is the slightest lag only noticable in the really quick bass notes. The XXX 12 played them a tad sharper. But if I were going to the Q12 from any other driver, I probably woudn't be saying this. The Q does everything that the XXX did while fixing the XXX's weaknesses. The Q is lighter, cheaper, louder, and more linear. The only edge that the XXX has is power handling which is a moot point since the Q seems to get louder. These subs can handle more than 1000 watts. I have a US Amps USA-2000 powering 1 Q12. The Q complains when I start really wailing on it for awhile. Otherwise, I estimate that it can handle 1200-1500 watts in the hands of a responsible adult. My only complaint was the packaging which was pretty messed up when I got the box. Not sure if Fedex was unusually rough with my stuff or the packaging sucked. Scott assured me that he uses pretty strong packaging so I'll blame Fedex. But I went to a USACI sanctioned event 3 days after I got the sub. Scored in the 136s. Considering that my BMW's trunk eats up a lot of db's and the sub was extremely stiff, that's a pretty damned good score.
Would like to see an entry level 500 watt class D amp.... Also, any timeline on the 3000 watt SAZ?
Excellent review. I'm thinking about doing a trio of SSD10s in my next car. My only complaint (a minor one) about my whole experience with my Q12 was the packaging. Maybe the UPS guys played rugby with it or something but the box was beat up when the sub arrived.
