738 -
Content Type
Profiles
Forums
Gallery
Everything posted by emperorjj1
second skin is straight up damp and damp pro... pro is thicker and more expensive
Is there anything you have to do to add more layers of Damp..... like squeeze out all air pockets or anything? you should squeeze the air pockets out anyway
well damp pro is thicker... its up to you (i have the pro version but i didnt order the regular so i cant compare)
After my 1 day spl build with a loaned RE MT i have to have bass so im going to be getting 2 of these subs soon. so im just wondering the differences between the old XXX and the Q? which would handle more power which would sound the best and which would be the loudest (theoreticlly) my amp is a T30001bd with a birthsheet of 3688w
cool thanks for letting me know... just wondering thou u got your q before the cooling option right?
oh lol i got it confused with the rd audio spl driver (i think the initials are similar). Id honestly love the efficency but it sounds like its a spl driver.... now id love a fi q with a btl motor, quad coil, and the honeycom cone (think scott could build me one)
from rd audio? hey let me know how those sound.
We now have available a SPL package option for the WMD 15's. They feature a glass/cabon fiber honeycomb cone with a tall high excursion foam surround. The lighter honeycomb cones increases effeincy by 3 db over the standard WMD pressed paper cone and add 14 sqaure inches of cone area by incorperating the tall surround. T/S parameters: REVC: 4 ohms FS: 34hz QES: .97 QMS: 7.2 QTS: .86 VAS: 3.6 BL: 14 MMS: 241g Sens:[email protected] nice how do those woofers sound?
Im having a hard time weeding thru everything to find the best of the best woofer for my application. It seems as if i get a different answer from everyplace... So ive decided to ask seperate questions and be more specific in my application goals (and poll as many peeps as possible). Box will be ported using 6" areos. I want a pair of 15s that can accuratly reproduce all bass (especially the lows) @ a 4 ohm load on my amp. At that power i want to be able to go to an sq comp and win. But i want to be able to take it down to 1 ohm and run like meade... subs must be able to handle the power at 1 ohm and sound as good as possible. Daily is where im mainly concerned with but im not sure on how much power i will run for daily (1ohm or 4 ohm) but if i get a quad coil woofer i may just run it at 2ohm but im not sure. below is the sites for the woofers in question http://www.rdaudio.net/woofers/alpha.php http://www.ddaudio.com/dd/caraudio/woofers.asp?series=9500g https://ssl.perfora.net/www.ficaraudio.com/...view.shopscript http://www.stereointegrity.com/Magnum12.html
looks like the SI mag is out due to D2 only that makes it a lil easier but not really... so should i try rd audio and see what there worth? go with the Q for sq reasons? take the DD and just have sq on the back burner? or try and find a pair of re XXX's which probably wont happen
true but it would be nice if i could... btw is the new proto going to be d2 only?
im interested in trying one especially since im still so confused on what woofer i want but my amp is rated at 3kw with a 3688 birthsheet @ 14.4 i know i wont see birthsheet power for a while (planning tons of electrical mods) but i dont want to kill the woofer
ic... i thought the 3rd slug might add some more power handling
any idea on aprox power handling?
damn i was wondering wtf went on... oh well. Thanks for getting us that info again Nick
