emperorjj1
Members
    738
Everything posted by emperorjj1
  1. emperorjj1
    Emp dual alt pics
    and 8 months later the beast actually works.... Took a few pics of the finished work. Due to not being able to find the correct sized belt we had to add 2 idler pulleys to take up some slack.... Unfortunately that left only 2 options on routing of the belt around those pulleys. Going under the first pulley would have allowed more belt area on the AC but the belt would end up hitting the metal support... Going under the first pulley ultimately reduced the belt coverage on the AC even more but cleared everything up top. We tested the AC running and there really isn't any slippage. Mind you this is still "freshly finished" so the next few weeks will be keeping it slow and popping the hood often. And with that hopefully ill be lucky and be issue free for a long time.
  2. i personally think copper clad wire is a waste of time
  3. emperorjj1
    Custom bracket
    In the end an alt is the best way to get power but not the only way. Working at a stereo shop We've done systems as big as 8kw rms and other then me (in progress) only one person has a second/upgraded alt and that one person doesnt have the 8k system Since it seems like your going to add the batteries regardless and your doing 2 of the big 3... Just do that and see how much voltage loss you get. You can always add an alt later. Also remember your not going to be able to use the entire stock alt amperage for your system. Only ~30% is extra for accessories. the rest is "needed" for all your car electronics.
  4. emperorjj1
    In Dash DVD head unit
    im pretty sure the answer is yes
  5. emperorjj1
    My box still smells
    ya after having a non carpeted box for forever (multiples) the smell is one that stays for a while. Gets bad in the sun too
  6. emperorjj1
    watts vs. true watts
    i can sometimes hear a difference in some amps. Crossovers/slopes do alot along with distortion and voltage ratings BUT 90% of amps sound exactly the same. So to answer ur question theres a million variables within the 12v industry. Until you have more accurate testing devices its free game.
  7. emperorjj1
    pioneer 5k is actually pretty nice. havent messed with any new pioneer flips other then that one
  8. emperorjj1
    The easiest way to get over that obsession is to look at a DNX-8120. You'll forget all about that DDX. actually i found out the DDX is the same unit as the DNX - navigation. EXACTLY.
  9. emperorjj1
    im now obsessed with the kenwood ddx812
  10. emperorjj1
    16 volt setup question
    hey what up audiolife? didnt know u were on this forum
  11. emperorjj1
    Custom bracket
    nope im just an enthusiast thats been thru hell and back to attempt to add an alternator on my car. Stock wires i honestly dont know. aftermarket alts are usually one wire or use a relay to hook up (very simple) but stock on my car atleast have a 4 wire plug. Unless u know what wires are what its basically useless. There's plenty you can get and be fine but if your going to add an alt i would try getting the biggest one you can. something like 200a. When thinking of how much current you need alt wise just get the amps fuse rating and divide in half (for music) That's a good reference for the minimum your going to want but there's several variables you can use to guesstimate that number (power avail from ur stock alt, average alt power, avail batt power ect ect)
  12. emperorjj1
    Gain Reduction Knob
    anyone know where i can get the gain reduction knob for a 3k? and how much it would cost?
  13. emperorjj1
    no its a module that provides 12v for the rest of ur car. you can also do something like the kinetik hc16v but using both teminals daily is harder on the battery. Id trust it a million times more then the step down module thou
  14. emperorjj1
    Gain Reduction Knob
    got the knob in today. thanks jacob hopefully it does reduce the gain instead of increase it but ill see soon enough
  15. emperorjj1
    BTL power?
    T30001bd
  16. emperorjj1
    Custom bracket
    depends on the oem alt and what hook ups it has
  17. emperorjj1
    Custom bracket
    as long as the second alt is 14.4v it should be compatible. the main part and concern is getting the second alt mounted and getting a belt running around it. Also remember the alt must be mounted to the engine only nothing connected to the chassis. and hopefully the person your talking about is local because if the bracket is just off the slightest bit your going to run into issues
  18. emperorjj1
    voice coils needed
    isnt tc sounds no more thou?
  19. emperorjj1
    RE SX
    done alot with them at the shop and its very vehicle dependent. Sadly no one with a single SX has been on the meter but one girl with 2 sx 12s in a cavi did 146._ i forget her other scores but shes done quite a bit before she sold the car
  20. if its the style im thinking of getting the double din to fit shouldnt be too bad
  21. emperorjj1
    recone glue
    interesting ive always used CA glue when reconing.... just pointing out any extra options
  22. emperorjj1
    Custom bracket
    Well you need to think about where you can fit it where it would hit the belt.... and think about mounting is it possible? and lastly think of if you can get someone to do it
  23. ^^^ that should be good. what vehicle are you doing it in?
  24. emperorjj1
    recone glue
    CA glue is what they use at the factory
  25. emperorjj1
    Run the 3000D at .5 or at 2ohms?
    one customer we have has an MT 15 running off a fosgate 1001bd and its loud so u should be fine on a 3k running half power
