dopey
Members
    687
Everything posted by dopey
  1. dopey
    Measuring for resinate Freq:
    http://www.ozaudio.com/docs/SPL_Theories_and_Tips.pdf reading is a great tool opps i let the secret out LB...would you like me to point out the flaws with the math in the second part of that, or can I just they're wrong?
  2. LP's were LOUD! I had a pair of OA's in a sealed box. They were pretty loud too. Not like the LP's though.
  3. dopey
    Push Terminals
    How much is a set? I'd say you may just need a backup, oh wise one.
  4. dopey
    t20001bd
    Just below audible clipping. The voltage will be determined by the HU. And unless you have an O-scope (dont make me spell it...and if you don't know what I'm talking about, don't bother)...use your ears instead.
  5. If it's going up front(engine compartment), the one that FITS is best. And bigger is better. If you want to see sizes for ALOT of different batterys and manufacturers... Batteryweb.com has good info.
  6. dopey
    few pics of my beat
    Why don't you put the Fi in? What kinda sub is that?
  7. dopey
    What Sub
    It'll be fine as long as you aren't stupid with it.
  8. dopey
    FI Q Recone
    Unless you cruise around with a MM on the leads, you wouldn't know. Sorry to interrupt.
  9. dopey
    SSD 15" 2, 4, or 6?
    I don't think more subs are the answer. You aren't going to get an open top vehicle loud. I personally think that sealed sounds louder in the open, but SSD's aren't boomy, so they might not be what you're after. ? You need a new car for SPL.
  10. dopey
    my btl blew
    Normal members that don't want anyone to know they fudged up?
  11. dopey
    Where did you learn to do that?
  12. dopey
    Will this hurt a class d amp?
    For any of you geetar players out there... NEVER I repeat NEVER, UNDER ANY CIRCUMSTANCES, so much as turn a tube amp on, without it seeing an active load. Tube amps are VERY finicky about that...and you will blow an output tranny so fast it'll make your head spin. When I say tube amps, I mean amps with tube OUTPUT stages...USAmps TU series doesn't qualify. But they may blow with no load too. (Some think they blow nowadays anyway)
  13. dopey
    Lookin at SSD's with copper coil
    Tune higher? Going sealed will PROBABLY not bring the peak up...it will probably make the peak point seem lower. edit: Try a BTL? Mine SLAMS NUTS between 40-70.
  14. dopey
    Hows this sound ?
    If those amps ARE NOT 1 ohm stable...I would not get dual 2ohm subs...instead I'd get dual 1ohm subs and wire them in parallel for a 2ohm load per amp. Q's are AWESOME subs. They should hold their own against w7's...but I'd look at going ported for great SQ and TONS of punch.
  15. I've got 2. It's supposed to rluz hardco....but I haven't the alternator for them yet. *waits patiently for July 9th*
  16. dopey
    Found this on DIYMA nice testing cd
    D/Ling full CD right now. THANKS!!!!!!!!!!!!!!!!!
  17. dopey
    Scott Help BTL Competition Box
    Hey Nick, I know you have mucho experience in the SPL field, would you mind talking a little about how volume, port area, and depth play into overall SPL? You are a good resource for us. Thanks
  18. dopey
    What would you do (or have)
    I vote 15"BTL ported. Or 18" if you have the CUFT. Loud and willing to take more if you ever decide to upgrade amps.
  19. dopey
    Put your q into a ported box and see if that's not what youre after. Porting will raise the levels of 40-60hz, but you lose alot of the sub-25hz (not real important, to me at least). And ported boxes get louder. And are easy to build...and and and.. Really, the only con is that they are a little larger.
  20. The Yellowtop Optimas are good, as are the Kinetiks. Look around, you can find batteries that are just as good for less$. Powersonic, Odyssey...are a few that come to mind. Look in the yellow pages for Battery, and talk to them about Group 31 AGM (absorptive glass mat), and SLA (sealed lead acid). You want >100Ah...and >1000CCA. Good luck!
  21. dopey
    more spl
    I lay the back seats down.
  22. dopey
    What Subs
    ? I'm we Todd did, and you? BTL's get loud.....VERY loud. Just drinkin and goofin with the "retarded" comment. All in good fun, and with utmost respect...or at least something resembling utmost respect.
  23. Does this clear it all up?
