mlstrass
Members
    350
Everything posted by mlstrass
  1. mlstrass
    New Home For RL-P's
    Looks like Image Shack is having some issues. I'll see if I can get them fixed. Will eventually stain them, but for now "naked" is fine.
  2. mlstrass
    Looking to go IB which drivers?
    Plan on twice the drivers you'd normally use if going IB, or you probably won't have the output you desire. I had 4 15" Tempests IB for a while, but output wasn't enough. Sounded very accurate when playing music, but didn't have that "slam" that I like. Just got my 2 15" RL-P's in the house today. 10^3 @19Hz each and I'm quite happy so far.
  3. mlstrass
    Two Rl-p 12's installed
    Box looks nice and I bet it's loud. How close is the port to the rear of the car? Seems very close and you might gain a little more if you could move the box forward a few inches...
  4. mlstrass
    need some help, cant figure these problems out
    Yep I'd check for loose connections. Also alt could be dying on you...
  5. mlstrass
    1500D .75ohm Daily
    Going to be installing a HD315 that's dual 1.5ohm VC's. Getting it for a good price, otherwise if buying new I'd just have gotten a dual 2 ohm. I have a 200a alt, SVR batt up front, Deka Intimidator in back, BIG 3 in 1/0, amp wiring is 1/0, gain set with DMM. Is there anything else I need or need to know as I've never run an amp below 1ohm. It's a daily driver and 99% of the time I listen at moderate levels, meaning you can talk in the car with the stereo playing, but once in a while I plan on leaning on it pretty hard when playing music, NO burps, just cranking some tunes to unwind after work. What's considered safe: 5 minutes, 20 minutes, doesn't matter??? I just don't want to damage the amp, even though I have the warranty down to .5ohm, I'd like to never have to use it by doing things right in the first place. TIA....Mike
  6. mlstrass
    1500D .75ohm Daily
    I'll be sure to take some pics of the build. Last few boxes I've done I didn't take any pics as I just needed them finished, so they could be picked up.
  7. mlstrass
    1500D .75ohm Daily
    Jacob...good to know. Thanks for the responses guys. Will be building the box this weekend and firing it up late next week I'm hoping.
  8. mlstrass
    AA Assassin 8" specs?
    Same here. Had 2 of them in 1.2^3 @40Hz getting 800watts and they sounded excellent and hit pretty hard. Solid little subs for sure.
  9. mlstrass
    Box Question for Q15's
    Can you do them each in a separate ported box? Might be easier to make that fit...
  10. mlstrass
    Smallest volume for RL-p 15 ported?
    I've done 2.5^3 @ 30Hz and am now doing 2.9^3 @32Hz. Virtually the same size box for either set up. I liked them at 30Hz and love them at 32Hz. I think you'll be very happy going ported...
  11. mlstrass
    second battery wiring question
    Any reason you're not grounding the batteries to the same spot?
  12. mlstrass
    Difference in batteries.
    I put in a Deka a few months back and have been very happy with it. Had to send in my HO alt, so I put the stocker back on. NO dimming at all on a 2200watt system.
  13. mlstrass
    Sundown Dream System
    Nick....just stick to your plan and you'll be happy. I'm one of the minority who enjoys rear fill, or sound enhancers as I call them. Stage is still up front, but gets louder and at times that's what I like. And NO I'm not spending a ton on a bigger amp/comps for the front. I'm VERY happy with what I have....
  14. I put a Deka Intimidator in the trunk a few months ago and have been very happy with it. G31...BIG battery.
  15. mlstrass
    Might want to consider the Deka Intimidators also, group 31's...
  16. mlstrass
    Enclosure finish... anyone know what this is?
    I have experience with an IB sub. 4 15" Tempests receiving 200watts each. For music it was INCREDIBLE: not heavy or bloated, just amazingly detailed and a pleasure to listen to. Unfortunately I'm more like 75% HT, and it seemed to lack the punch/impact over the 2 Tempest ported sonosub it replaced. If going for music with the Maggies I can all but assure you that you won't be dissappointed with an IB sub. Although you might want 2 of those 25" monsters, seriously. The "norm" seems to be to run double the amount of subs you normally would. Good luck on the decision and box if you decided to go that route...
  17. mlstrass
    15" Q Build Log
    Thanks. Wonder which sticker you like
  18. mlstrass
    15" Q Build Log
    Picked up the Baltic Birch and stain today. Will start cutting tomorrow and taking pics. Specs will be: 3.2^3 @ 31Hz with 42^2 port, double front bafflor or possibly triple front baffle with recessed driver. Finished box will have a "different" look to it as I have a few ideas I might try out. Only issue so far is that I can only go 15 3/4" tall as that's THE biggest I can fit through the rear seat opening as trunk opening is even smaller. Specs say cutout is 15 5/8", so it's going to be a tight fit top/bottom. GF is VERY excited to hear her new sub and has already requested some front comps to replace the coax's. YES she's a keeper Sub should arrive Wednesday.
  19. mlstrass
    15" Q Build Log
    YES she is and in a few years I'll make an "honest" woman out of her. LOL Finally got it all buttoned up. Had to remove the rear seats to get it in. Then her coax's were cutting out, turned out to be a loose RCA. It hits plenty hard and has good SQ. Dragged the GF out to hear it and she was amazed. Told me she'd never play it that loud, but I'm betting she will. Guy from work stopped by and his jaw was on the ground the entire time. Only problem so far is the package shelf is literally flapping up/down a 1/2" and I've already deadened it and added foam, etc... I'll probably have to screw it down. Tomorrow night I receive "favors" for my efforts
  20. mlstrass
    15" Q Build Log
    Close up of the "cove" routered around the baffle opening. Looks pretty good in person.
  21. mlstrass
    15" Q Build Log
    Tried a pic without the flash. Still doesn't do it justice...
  22. mlstrass
    15" Q Build Log
    Top view shows the "cut out" I did so part of the gasket would show.
  23. mlstrass
    15" Q Build Log
    Love it or hate it, it's done. GF LOVES it!!!
  24. mlstrass
    You can rent a "wet saw" to cut the tiles. Ceramic you can just score & snap, but marble is too dense. Looks very nice and would be worth the effort. Have you considered wood sides with just a marble/granite top?
  25. mlstrass
    2 15" Bl's (worklog)
    Looks very good. I would have added a brace or 2 top/bottom since I'm "assuming" only the baffle is doubled up.
