42 -
Content Type
Profiles
Forums
Gallery
Everything posted by CarlosRodriguez
sundown sa-12 4th order
CarlosRodriguez replied to CarlosRodriguez's topic in SPL & SQ / Fabrication
gain graph group delay highest group dely 33.22hz 52.16ms phase plot spl graph -
gotcha i have a ported one tuned to 35 hz would the subs do better at a 30 hz vs the 35 that its at? -
comfortably numb pink floyd sean paul U Aint know slowed I put on
voltmeter
CarlosRodriguez replied to ex650's topic in Amplifiers / Head Units / Processors / Electrical
i use a stinger voltmeter but thats just what i run.. just as long as you can see your voltage is the important part.... -
would this box be ok for these subs?
CarlosRodriguez replied to CarlosRodriguez's topic in General Audio
Yeah my bad guys I did the sketch just to give some what of an idea the port isn't cut like that over all it slams for what it is going to up grade the subs to something current with in a couple.of months once I can get rid of these and afford somthing else going to have about 2k RMS on tap once i get the right electical but for now here is a link to the subs playing -
what are you trying to achieve with the tune ? low end monster daily if it was me id do 32 but w.e up to you..
you should put your stereo at your loudest listening level that you usually play at a normal basis then you turn your bass nob up all the way and slowly turn your gains up on your eq until its at a satisfied listening level.. now you can turn your bass knob up all the way and no distortion or trying to make the amp do more then it can dirty signal
if i mont mistaken some manufactures suggests tuning at a certain level because thats where there drivers peak at that hz but will still be able to drop in the high 20"s all depending on the driver.. ive herd from a few 33 hz is prime but others say they like 40 hz idk?
which alternator do you run?
CarlosRodriguez posted a topic in Amplifiers / Head Units / Processors / Electrical
ok so heres the deal just hooked up my system the other day and turns out i got nasty volt drop from 14.3 to 12 with my amp setting on a little less then half no bass boost head unit at 3/4 so heres the question what brand alternator do you run, amps on it? price you payed for it.? Ive been looking around and i have mechman alt. dc power georgia power and irragie alt im shooting for 270 amps.. would be appreciated thanks in advance -
CarlosRodriguez replied to CarlosRodriguez's topic in Amplifiers / Head Units / Processors / Electrical
i talked to mechman and dc a while back but lost the emails and just got this job at mandalay bay casino in vegas so i can finally afford one soon.. plan on running about 3k rms and the 80 oem 80 amp just isnt cutting it lol -
ill do that thanks -
It is a 1994 bmw 325i -
Amp Stopped Working for no apparent reason..
CarlosRodriguez replied to whatmh5's topic in Amplifiers / Head Units / Processors / Electrical
i had a mtx te1500.1d i believe the model on it was called. if you send it in to mtx with out a warranty depending on the model they charged me 90, you just have to call customer support to get a quote and a ra number they should tell you the cost they said the 90 was flat rate no matter what was wrong with the amp. worth a call -
yeah like the other said i belive they have a whare house in vega sbut i could be wrong i :fing34:remember looking them up.. they slam
was watching tuffguy40's vids and came to check it out and liked what was going on
me in the box during a 60Hz blast, gangsters walk right in garage VIDS
CarlosRodriguez replied to kryptonitewhite's topic in Videos
couldn't you use just a dab of hot glue? so that way it would hold it but not permanently damage the gain nob and if anything goes wrong or needs adjustment you could always peel it off just a though..? -
whats up guys... just posting up the start of my box build.. the detentions are 15 x 30 x 30 6 inch slot port around 6.35 cubic ft before port around 4.5 after. the driver is going to be a re audio xxx 12 not sure the model though heres some pics not done yet still need to run sub wire and cut the speaker hole let me know what you think
