Dictator
Members
    904
  • Days Won
    4
Everything posted by Dictator
  1. Dictator
    p1's.....
    p1s suck......entry lvl subs just about. pair in my closet.
  2. or the bc3500 cost 600shipped. research it might like what you find about it
  3. Crescendo audio bc2000 is a good choice also i think its 330 or 339 shipped not shure but its around the 300-340 price range hell of a amp does rated power.
  4. Dictator
    agm charger?
    Agm's like slow charge or fast charge? Heard mix opinions from people.
  5. Make shure you ground the alt with 1/0gauge wire propely.
  6. Dam 12.9 at full tilt is 2shabby for that amount of power. I drop real low o yeah forgot i have a ohio shitty alternator
  7. Dictator
    My Transaction with Mechman
    Sorry to hear about the car . On the other hand plenty of sweet Volvo's out their that need a new home! Chicks dig Volvo's !
  8. Dictator
    Just finished another home subwoofer build
    Tried the dayton amp out yet?
  9. Dictator
    Alt not increasing voltage at idle!
    For rizzle! Its alright good learning experiance.
  10. Hello i have a 1992 volvo 240 wagon upgraded my amp from a aq 2200d to a Cresendo bc 3500d. Ordered a 275ohio alt was working great for 2months then stopped working sent it back to ohio had the alt looked at by the technician said it was working fine. Installed it again and started doing this weird voltage thing with my batteries. Voltage of batteries is 12.8 with car off when i turn the car on the voltage stays at 12.8 does not increase inless i tap the gas and it jumps to 13.8volts Why am i recieving no voltage increase when the car is turned on, which makes me think im getting no idle amp output. I did not upgrade any wires on the alt all factory. 55ah yellow top upfront and 35ah yellow top in the back. Inatalled the new cresendo and a Mb Quart Q.125 4channel drained the battery down to 60% inless then 30mins of beating. Why are the batteries draining if this alt is supposly 275 amps.My fail or the alt fail?
  11. Dictator
    Had Aq 2200 to begin with running 3500d now with two kinetic 2400's in rear. Fixed the previous alternator problem Installed smaller pulley and grounded the alternator to the engine and grounded the engine started working for 3weeks then shitted on me again. In the shop atm seeing if the alternator took a shit on me.
  12. Dictator
    Vid of my FIQ 15 on some Disturbed
    That looks awesome and props for rock FLEX!
  13. Every spare battery you hook up takes 10amps of current away from the alternator....the batteries are their to keep you from going below 12volts!!!!
  14. Dictator
    Local Audio Shop Rant
    154 hahahahaha.
  15. Dictator
    I wanna Upgrade.. But what to?..
    I would say ssa subwoofer all the way. Sealed box wouldnt be that hard to build if you dont like the sound of them sealed or not loud enough make a ported box.
  16. Dictator
    Got bored so i made a video.
    Sound likes a well tuned system!
  17. Dictator
    ticks and tips to dain dbs???
    Idk dont have experiance in that question would like to know also.
  18. Dictator
    which would be louder???
    ...lol fail thread!
  19. Dictator
    92 Volvo wagon GagaGansta Build!
    Thanks runs great needs a new paint job and some eye candy rims lol at least !!! I was just joking that seemed like hating lol
  20. Dictator
    Vehicle is 1992 volvo 240 wagon The goal of this build was to get loud on the mids and highs and get as loud and low as possible on two 12's!!!!!!!!!First box for this system was really nice but not enough port area so the bl's werent liking it very muddy sounding wasnt happy so i pulled out my old box and trimed it up to fit the vehicle and it was a perfect match up. Moves some air like it should! electrical consist of 275amp Ohio generator Alternator a 17ft run of welding supply 1/0guage all connections crimped with hydraulic crimper thanks to "Sirlancelot" Yellow top optima g34 upfront with one kinetic 2400 in the rear atm have one more to add in just ran out of 1/0guage terminals. Equipment: Clarion Deck 4volt preamp with decent equalizer good budget deck -Bass Amp Cresendo Audio 3500bc upgraded from a Aq200d very happy with the cresendo!!! -Mids highs amp: Mb Quart Q series 150rms x4 the components are 2.7ohms so its running at a lower Independence amps alright heats up real quick in 100degree weather like boiling eggs on top of it type heat. -Components Polk MM 6.5'sx2 125rms for each pair. They sound really good taking all the power from the mb quart with no problem! Pics of the old setup for recap for the peeps. Old Aq was a really good amp for a budget build for only 389 shipped. Then they raised the price to 429$ not worth it to me. That was about it for the old setup didn't have enough time to finish everything until i Sal the crescendo 3500d and i had to have it was so sexy and cheap! Was running the crescendo on the fi's in the stained in the varnish box received more output of the subs the quality of sound was really muddy didnt not enjoy it at all! For the mids highs where the sound was coming from wasnt a big deal i just wanted to get loud! I know your suppose to have sound coming from left to right but fiberglass takes to much time. So i just decided to stick on the mids and highs in a speaker pod enclosure made out of mdf then vinyl it sounds really good actually not that bad for the sound coming from behind. Picture of the other subwoofer box has alot more port area then the stained and varnished box. Not as pretty looking though but who cares as long as it gets loud and low! The amps in the compartment the car has little messing only because the volt meter run was a little short so its going across everything! One kinetic 2400 need to build a enclousure for the battery to keep it stable but its fine for now nothing is going to spark or do any damage. Mids highs from back you can see how they are not going anywhere with the stillets on them. Old sub box chilling on box's while i take out the subs out! Dont bother the oil leaks on drive way a shitty ford f-250 did that go figure a ford vehicle . Now with the subs installed with the box with lot more port area MADE a huge difference on the lows and the quality of sound!!!!!!! Last photo of Clarion with voltmeter and working on mounting gain knob! Thats all the pictures for now have only one more thing left to install which is the kinetic 2400 then ill be happy for the time being!
  21. Dictator
    Over-exaggeration
    This makes me proud to say I live in SC. /Sarcasism. :Shakeshead: i love the first part, "i have a 15" sundown audio SA-12" wow 15...sa-12???
  22. Dictator
    F'in Irene!
    7hz its alright....
  23. Dictator
    A Little KIA Fex!
    Looks good bro like to get a demo one day of this beast!
