8,101 -
Days Won
7
Content Type
Profiles
Forums
Gallery
Everything posted by sundownz
We are opening up a May sale for you guys -- enjoy ! IN STOCK ON SALE ITEM : SAX-100.4 -- Regular = $365 / SALE PRICE = $320 * Shipped in Continental 48 states EARLY ORDER ON SALE ITEMS : Both the SAZ-1000D and SAZ-3500D are expected in stock around the end of May to early June. SAZ-1000D -- Regular $315 / SALE PRICE = $275 * Shipped in Continental 48 states SAZ-3500D -- Regular $1075 / SALE PRICE = $865 * Shipped in Continental 48 states ---------- This sale lasts until May 31st or while supplies last ! To order contact your favorite Sundown Dealer or Paypal me at [email protected] with a description of your order.
At 1 ohm with two subs... no problem.
Indeed... sold out and discontinued. As Derricks stated I will have around 20 of them slightly used ones 2500s come in from the Team.
You can call and order the brass threaded rod, nuts, and washers from the same place I get them (they are local to me so I pick up): Piedmont Fastener Co812 South Main Street, Troutman, NC 28166-8514(704) 528-6150
If you find a used one... or if you get a motor we can still make drop-ins.
That is all you get until the prototype is here I will post pictures of a fully assembled woofer when it shows up ! (There are no other pictures of it uploaded anywhere on the server either)
Only a few days left to take advantage of this sale !
4500s made it an hour or so ago... starting to ship today and will finish by Friday.
PRE-SALE ORDERS ARE FINAL - THERE WILL BE NO REFUNDS -- If you are not 100% sure you will be financially stable then don't pre-order. THESE WILL NOT BE IN UNTIL AROUND the end of April to early May. DO NOT pre-order if you are in a rush or on a dead-line -- as always there can be delays with pre-orders. Just want that to be clear. --- PRICING: $1200 each SHIPPED in the continental USA TO ORDER - Paypal me @ [email protected] Regular price is $1549 MAP / $2149 MSRP. --- Rated Power : 4500 x 1 @ 1 ohm 2000 x 1 @ 2 ohms 900 x 1 @ 4 ohms TEST RESULTS: 3100 Watts @ 1 ohm nominal rising to 2.67 ohms on 14.4v dropping to 13.6 volts 4650 Wats @ 0.25 ohm nominal rising to 0.71 ohms on 14.4v dropping to 11.6 volts You will get more with a beefier electrical setup. 5290 Watts @ 1 ohm nominal rising to 2.12 ohms on 17.9 volts (did not measure drop) 6930 Watts @ 0.5 ohm nominal rising to 1.31 ohms on 17.9 volts (did not measure drop) ---
Available. Not doing pre-sale.
I'm ready Should just be a few more weeks !
At what impedance ? v.1 or v.2 ? What size ? Enclosure size ?
Can't do it -- won't fit under the window line. I haven't noticed any flex on it either.
Will go quick... especially as the date gets closer.
D2 coils / 3 Hard 10" Spiders (PSI) / Nightshade Cone * Starting rear part of spider glue joint * Finished up * Extra glue bead around the perimeter of the spider * Another shot. * CA glue covering all the exposed former wrap material as well as bottom of cone joint. * Top triple joint Dust cap is a simple plain black poly cap. Sub performs quite well free air on our 1500D on the bench - looks like this beast would handle a ton more power mechanically and thermally
ETA is still end of month to early June.
Amps will be done in two days... around a month early (they are on the ball) -- so I now expect these late JUNE instead of July. Therefore pre-ordering will end sooner... around June 20th.
It is a good bit more powerful - especially when wire down low for SPL competition usage.
Would power a BTL nicely.
I actually have a tracking # for the truck now -- called them up this morning and they are in South Carolina today so 99% likely I will get them tomorrow.
I will when dust cap is done drying.
Swapped to a 2 spider Z v.2 and found my frequency is actually 54 hz with this box : 920 watts = 148.6 1210 watts = 149.3 1510 watts = 150.1 * Sub cool down for 10 minutes * 1890 watts = 150.9 2570 watts = 152.2 2940 watts = 152.4 * Sub cool down for 10 minutes * 3320 watts = 153.0 3650 watts = 153.1 * Sub cool down for 10 minutes * 3850 watts = 153.4 So... SPL per watt is up now. Tried a few things to get my peak back to 53 hz with no luck yet.
