8,101 -
Days Won
7
Content Type
Profiles
Forums
Gallery
Everything posted by sundownz
As long as nobody walked off with them and they didn't get damaged in the shuffle, yes, SA-8 recones are on there.
My import agent just called me up and said stickering is done and I should have the subs tomorrow. If that is accurate we'll start shipping tomorrow and *hopefully* ship all the pre-sold subs by Friday.
I am hoping none of my subs come up missing. On the first run of 4500s they got held for a while and 3 amps were stolen! In any event - will update the forums as soon as I get word they are done stickering the boxes.
There is still hope We'll keep you updated.
I just got back from driving down there again... dropped off 1500 stickers so they can put as many as they want on them and I won't have to drive back down if they change their mind (they now have 2000 stickers total). I THINK I talked them into just doing two per box... but we'll see. Will keep you guys updated.
It's actually worse than that... my contact misunderstood and they want two labels on the outside box and two on the inside box (they are double boxed). It's going to take them all week to separate the boxes and label both... Sorry guys... out of my hands at the moment. I am trying to reason with them... we'll see what I can do.
<rant> You have GOT to be kidding me... apparently the "senior inspector" has something stuck up his rear-end and wants the "Made in China" stickers on four sides of every box now... SO I have to drive down there and bring MORE stickers and wait a few more days again. This is the stupidest thing I've ever heard of. </rant>
Since the amp plays on other sources it's not bad. The maximum input RCA voltage is 6 volts.
Latest from my import company: "I just spoke with the Senior Inspector. He is going to the exam station around lunch time to inspect the marking. He said he would call me with the results once he is finished. I will advise."
Early to mid July.
Do you have another source like an iPod with an RCA adapter you can try ?
The Z v.2 woofers are back in stock. There have been a few revisions made : 1) The top shorting ring has been removed -- but the internal ring was upgraded from aluminum to copper. 2) The coil windings changed from 4-layer flat aluminum to 4-layer round bifilar copper -- this lowers Fs a bit and I tested no loss in efficiency at lower power and a small gain at high power. Coil is a bit more robust than the aluminum was as well due to additional mass. Copper also has a lower thermal expansion to accommodate the Z v.2 tight gap. All in all it makes the driver more tolerant to abuse. --- We still have the 4-layer flat aluminum coils to match other subs on re-cones... also, the motors can be mixed as the shorting ring material change is not a huge difference.
Derrick is correct - we have plenty of 3500Ds.
Sold out. Unless you have talked to me in the last day or two and a deal is in the works no more are available at this time. ETA for more not yet set.
No, it doesn't.
Yes... "Blownest" may not be a word... but I think it needs to be after seeing this woofer. I do not know who this belonged to exactly but Nick @ SI is re-coning it at my shop today so we thoroughly documented the carnage. Just had to share. * Thats not so bad, right ? * Well... that isn't normal. * Back of the surround should be gray. * Melted material and discoloration on the pole. * Wow. * Kapton wrap of the former is melted and puddled up on top of the triple joint. * That used to be a plastic former cap from under the dust cap. * The solder actually re-melted... * Some of the solder formerly from the connection point * That should be black. * Insider of spider was burnt out. * Motor has been "anodized" with the burnt material. --- There are some more photos in the directory that I didn't link directly : http://www.sundownaudio.com/misc/SI_Mag_ASPLODE/
I can make 10s but I don't want to yet... still working on the spider specifically for 10s. If someone REALLY wanted one it could be done.
I suppose -- but I'm not changing the name as it's close enough Just a little improvement.
That should generate excitement New DP looks great.
They are on pre-sale until I post that it is over, so yes you can. A 200-amp Powermaster alt ? Thats fine.
Damn that sucks! Roughly how many pieces need to be stickered? Would hate to have that job. Almost 500 boxes.
