8,101 -
Days Won
7
Content Type
Profiles
Forums
Gallery
Everything posted by sundownz
From what i hear, the owner of that company, Sean(can't remember his last name) is also the same guy who is going to take over Sundown Audio completely once Jacob transfers ownership over to him in the near future. That I can confirm is incorrect. Sean is in charge of the Team program as I do not have the time to appropriately manage it any longer. As of right now ownership of the company isn't going anywhere.
All online stores should be updated any time now -- all local dealers have been e-mailed new price sheets as well. If you are a dealer and haven't received it yet let us know as dealer costs are also revised for 2014! The "Team" woofer will likely receive a name change before launch; but we are still debating what it will be -- we concluded that "Team" is too confusing since other people will be able to buy it. Many products that did change changed very little except for big amps and the NeoPro line. I did some massive number crunching to make sure all pricing was on point and mathematically / economically sound for us, dealers, and distributors. Some additional fine tuning may come during 2014 -- and do expect new products, revised products, etc to be added as the year proceeds
I'll be headed out at 3:30 AM to start my CES / west coast trip. See you guys on the 14th when I get back. All of the rest of the crew will be at work until Tuesday evening; when a few of the other guys will join me from then for the rest of the week. They will be back on the 12th. Some of the crew will be at the shop the entire time, of course, we will not be closed completely.
Third revision prototype is in : ** Free air test ** ** Test Bench test in-box **
Third prototype is done -- specs coming in between the first two prototypes. The box model graph is essentially identical to the original. Hopefully I have reached the perfect balance of mechanical durability and response -- should have it after new year some time in my hands Gray is the first prototype I published spec on which was a bit too soft. Yellow is the 2nd prototype that was way too stiff. Green is the 3rd prototype that I hope achieves the best balance.
Our Holiday Schedule is as follows : We are open December 23rd -- We are CLOSED December 24th through 27th. We are OPEN Dec 30th through 31st. We are CLOSED January 1st then back to normal January 2nd. Hope everyone has a safe and happy Holiday season from all the team here at Sundown Audio !
I am trying to get the specs more in line for smaller boxes. I will have to verify with the updated specs on the Rev.2 samples to see how close we can get within this cost range.
Did some heavier abuse testing yesterday. Ended up breaking the solder joint from the tinsel lead wires to voice coil lead at the neck joint on one side -- but did not actually break the neck joint or thermal the coil. Had it up around 550-700 watts clamped at the point of my testing before that failure occurred. These samples have tied-on leads and actually the "floating" leads would have prevented this type of failure as it was a result of excessive forward stroke tugging the tied lead out of the hole it passed through -- and of course I was doing 550-700 free air on a 300-watt rated driver anyway so I can't say I am disappointing Either way I have some Rev.2 prototypes in the works to address the high Qts and a few other minor things I want to improve. I have been spending alot of time as well making sure I can still offer them for the $60-70 range or VERY close to it
I have no plans to make a bigger amp than the NS-1 or anything between the 5k and the NS-1
The NS-1 v.2 is full available now, yes. The SAZ-5000D is a bit less of an extreme competition amp -- eg: it doesn't like 0.25 ohm burps on 19v in our Terra like the NS-1 does. But at normal loads and under normal circumstance is comparable to the NS-1 with less power output. It's design is similar to the SAZ-4500D (beefed up -- of course) so it's already a bit of a v.2 model.
Either you know nothing about Sundown or you have a biased opinion that is not based on product purchase. I have a lot of experience with Sundown products. Not one of their woofers would I choose for a sound quality install. Sure sundown woofers can sound good in the right install, it doesn't mean they are a SQ driver Define what you consider an SQ driver -- also; specify what part of our drivers don't fit the definition in terms of lines that address all major modes of distortion -- such as the SD-2 8" (under-hung, linear suspension, low natural Le variation) or the Z v.4 line (35mm linear magnetic travel, linear suspension, dual shorting rings). Unless your definition of SQ does not include objectively, measurably low distortion you'll find that you might be surprised.Now... I didn't set out to make the worlds top of the line SQ sub with any of our lines; that isn't our market. But you will find many of our drivers feature more distortion lowering technology than quite a few drivers considered to be "awesome" for SQ. Even our SA series has dual Faraday rings.
The SD-2 8" is one of the best in our line. In all actuality the X and Z v.4 also sound excellent and measure as such.
If there is damage from delivery that would be a SH claim issue to look into.
With the rattling something is probably broken inside.
Nick Lemon's of Stereo Integrity / Obsidian Audio will be doing the SA-8s for a bit as Mike (woofercooker) has been traveling for work and so forth so is not able to do them at this time. Re-coned SA8's - Car Audio Classifieds ---------- Nick has been re-coning both the 12-spoke and new style frame drivers that didn't meet QC standards and/or warranty replacements. At the moment the shallow cones for 12-spokes are out of stock -- so only the new style frame units are available. $90 plus shipping EACH UNIT If you are interested in these you MUST EMAIL NICK YOUR ZIP CODE!!! His e-mail address is [email protected] DO NOT PM NICK OR ME -- DO NOT E-MAIL SUNDOWN Quoting Nick's For Sale Below : "Re-coned and in perfect working order. The drivers are being sold as-is with no warranty. I bought a lot of used motors from Jake, am cleaning them up, putting new baskets and spacer rings on them and re-coning the drivers with all new soft parts. For those of you who don't know me, I own Stereo Integrity and am a partner/subwoofer designer for Obsidian Audio and I also build production drivers, do re-cones, and drop-in's for Sundown Audio. I can build any SA-8 you want. Normal coils are dual 2 Ohm and dual 4 Ohm."
Rev.2 Prototype is here -- not 100% where I want it but closer
Production is about to begin I will post ETA information and the pre-order once I have that.
We currently have more staff than ever answering inquiries so if you have a PROBLEM reaching us please read the above and it will help. Also read the below : Most of the time I discover with missed calls they are made outside of our hours. Lunch time seems to be the most common issue. Leave a message OR preferably send [email protected] a follow-up e-mail to return your call. Most of the time with problem e-mails I find that the customer has a spam filter or other filter blocking our replies. If sent via the "Contact Us" form I see alot of return addresses misspelled. This has happened countless times so PLEASE check your filters. E-Mail problems can happen the OTHER way around as well -- if you don't hear anything from us via e-mail for a long time CALL THE SHOP with your inquiry. This means we did not get your e-mail for some reason (spam filters, accident deletion, etc) -- it does NOT mean we are ignoring your message.
I have UPDATED this post on 11/2/13 : To ensure that contact is organized and prompt please read the following : We are open Monday through Friday. Our hours are 8 AM to 5 PM EASTERN Time -- we are CLOSED for lunch at approximately 12-1:00 every day; lunch time frame care vary +/- 30 minutes depending on what is going on that day. DO NOT post on Facebook or the Forums to request order status, warranty information, or pricing. It is VERY difficult to know who you are or what you ordered this way. Forums and Facebook are designed to share new product information, customer installs, updates, etc and are not optimal for the aforementioned things. On our OFFICIAL Facebook and forum names we DO NOT use any form of PMs -- these are too easily over-looked. MAKE SURE you provide your REAL NAME and a SUBJECT LINE in the e-mail -- if you are asking about an order make sure to tell us the name and e-mail on the Paypal payment as they very often do not match. For order status and tracking : [email protected] For basic pricing (including stock drop-ins) : [email protected] For odd-ball stuff (custom re-cones / parts) : [email protected] (be patient, my box gets bombarded - I may forward messages to other staff if they can answer) For dealer inquiries : http://www.sundownaudio.com/index.php/dealer-inquiry.html If you have a question about the form : [email protected] For warranty : http://www.sundownaudio.com/index.php/return-authorization-form.html For general information / tech questions : http://www.sundownaudio.com/index.php/contact.html or [email protected] For Team Sundown Inquiries : [email protected] If you cannot reach us electronically or are having an issue with the electronic methods you can call. It is preferred to use electronic contact so there is a written record for future reference. If you do call; DO NOT call us 100 times in a row if you don't get an answer the first time -- leave a message and/or wait 10-15 minutes and try again. Someone is not beside the phone 100% of the time but someone is there most of the time. We do not have an entire call center so be patient; if everyone is already ON the phone we can't answer. Again -- it is preferable to use the above electronic contact before calling. Calling opens up significant room for errors and leaves no record of the conversation. ALSO remember our hours; if you call when we aren't there we cannot answer... please leave a message !!! 828-459-1980
Revised prototype is on the way -- suspension is a little stiffer (ported F3 is nearly identical) with re-enforced glue joint and a few other modifications as well. I will post up testing on it when it's here
This is our second full-range Class-D / 19v stable multi-channel to hit the market after the SAX-125.4 model. It is a VERY compact unit designed to fit just about anywhere. They are available NOW for $400 from any authorized dealer in the USA. ----------
NeoPro-v.2 Info below. They will be in stock mid to late August. New power ratings : 6.5 - 180 RMS 8 - 200 10 - 300 * Included Grilles And mechanical drawings : http://www.sundownaudio.com/misc/protos/NeoPro_v2/NeoPro-10%20V.2%20mechanical%20drawing%2020130716.pdf http://www.sundownaudio.com/misc/protos/NeoPro_v2/NeoPro-8%20V.2%20mechanical%20drawing%2020130716.pdf http://www.sundownaudio.com/misc/protos/NeoPro_v2/NeoPro-6.5%20V.2%20mechanical%20drawing%2020130716.pdf
This is a direct replacement for our old SAX-100.4 model as it is a Class-A/B model amplifier. It is much more compact than the old SAX-100.4 but not nearly as compact as the SAX-125.4 model. We have had a great deal of demand for this unit as it is significantly less expensive than the SAX-125.4 model and is perfect for those that don't need such a small foot-print or a 19v stable amp (these are stable up to ~16v). They are available NOW for $400 from any authorized dealer in the USA. -----
I have REDUCED the cost on our tooled 10/12/15 frames now that we have sold enough complete drivers to pay for a significant part of the tooling charges. They ARE available stand-alone at the same prices (+SH) as you see listed above for DIY projects. You would also contact [email protected] to order them -- you would likely also want our vented frame spacer to go with them. Some other cones will work on our 12 and 15 frames but ONLY our 10" cones work on our 10" frames. Keep that in mind if you are doing a DIY project.
To order a re-cone e-mail [email [email protected]][email protected] -- do not e-mail my "sundownz" address if you need a quick response.To reduce back-and-forth e-mails ALWAYS include the following : 1) What you are ordering -- Model, Coil Configuration, Etc. 2) If you already have a basket or not; please check below for any special notes. 3) If you need ANY custom options please specify up front. 4) !!! YOUR ADDRESS AND NAME !!! 5) A picture of what you have goes a long way to be SURE we are talking about the same thing. IT WILL TAKE, ON AVERAGE, 10-14 days for a built item like a drop-in to be completed. It may take longer depending on how busy our build department is -- please keep this in mind. Updates will NOT be sent along the way -- an update will occur when the product is shipped. You can e-mail us to check on the status. ---------- EDIT 8/30/11 : WE CANNOT WARRANTY DIY RE-CONE ASSEMBLY ISSUES. Read and understand this -- if you are not 110% sure about re-coning the driver ask us or send it in. We can ONLY stand behind labor that we perform. Manufacturing defects in the kit itself are of course our responsibility but installation is 100% the customer responsibility. This includes ticking, broken parts, etc. EDIT 10/14/13 : MAKE SURE to check your re-cone BEFORE installing it for complete accuracy. This includes using a DMM to make sure you received the correct voice coil configuration. As this is a DIY process everyone performing a drop-in should have access to a multi-meter. If there is a mistake on the kit we need to know BEFORE you glue it all in place!!!Once the kit is glued into place we will not be be liable for any errors in it's construction. CHECK IT OVER FIRST. If it is not correct we will issue a call tag for it and build you the correct kit for you ASAP. Also... any CHANGES to a drop-in order must be done in the form of a new order. We will no longer CHANGE an existing drop-in order without refunding the original payment and creating an entirely new order so that ALL of your details are IN WRITING on the payment slip from Paypal. There will be absolutely NO changes to drop-in orders on the phone!!! Changing existing orders and making any adjustments on the phone open up too many possibilities for errors. ---------- This thread over-rides any prior quotes or costs. These prices are the same for everyone; Team, dealer, customer, etc. All costs + SH charges. ---------- KITS DO NOT include shims or glue. White paper trimmed / stacked to spec works perfectly for shimming -- use enough where it is snug but not so tight you can barely get the coil in the gap. For glue we suggest Loc-Tite 5-minute epoxy with mixing tubes to glue the spider to the frame (MAKE SURE to sand it first) and we suggest Amazing Goop or E6000 for the surround and dust cap (sand frame for surround and rough up the glue surface of the dust cap with sand paper as well). These can be purchased from Lowes or Home Depot very commonly and some Wal-Mart and Craft Stores. We can sell CA glue by request but it typically is not very cost effective for the end user. ---------- MODEL -- RE-CONE Price -- FRAME Price E8 v.2 (or v.1) -- $28.00 -- $5.00 * D2 / D4 available Stock * MUST buy basket to re-cone a v.1 model E8 v.3 -- $30.00 -- $5.00 * D2 / D4 Available E-10 -- $35 -- $10 E-12 -- $35 -- $10 E-15 -- $45 -- $10 * D2 / D4 Available !!!FOR SA-8 KITS SEE THIS THREAD TO DETERMINE WHAT MODEL YOU HAVE. WE MUST HAVE THIS INFO TO MAKE THE CORRECT KIT!!! SA-8 v.1 or v1.5 -- $32.00 -- $10.00 * MUST SPECIFY v.1 or v1.5 when ordering !!! * D2 / D4 available Stock * CCAW 4-layer D2 or D4 SPL Coils Available No Extra Charge (these are lighter but can still be used daily as the gap is not tighter than stock) * These kits now ship standard with a round lead wire that is more rugged SA-8 v.2 -- $50.00 -- $15.00 * D2 / D4 available Stock * SA-8 v.2 Kits Available with SPL 8-layer D1 Coil for $20.00 Extra (Very tight gap and may tick slightly at high excursion) * CCAW 4-layer D2 or D4 SPL Coils Available No Extra Charge (these are lighter but can still be used daily as the gap is not tighter than stock) * Extra Spiders Available for $5.00 Extra Each for a MAX of FIVE (stock is two); DO NOT order extra spiders for anything but SPL SD-2 8 -- $40.00 -- $15.00 * D4 Coils ONLY SD-2 10 -- $35.00 -- $15.00 SD-2 12 -- $35.00 -- $18.00 * D2 / D4 available SA-10 -- $40.00 -- $15.00 SA-12 -- $40.00 -- $18.00 SA-15 -- $50.00 -- $21.00 * SA-10/12/15 add $20.00 for SPL Coils (D1,D2,D4) * D2 / D4 available in stock copper NSv1 12 -- $100.00 -- $25.00 NSv1 15 -- $110.00 -- $30.00 NSv1 18 -- $120.00 -- $40.00 * 3H Nightshade Spiders Stock * Add $10.00 for double leads * Z v.3 Spider Available No Extra Charge * NS v.3 Spider Pack Add $10 * D1 / D2 Available NSv2 12 -- $130.00 -- $25.00 NSv2 15 -- $140.00 -- $30.00 NSv2 18 -- $150.00 -- $40.00 * 3H Nightshade Spiders Stock * Add $10.00 for double leads * Z v.3 Spider Available No Extra Charge * NS v.3 Spider Pack Add $10 * D1 / D2 Available (SPL COIL Available) Zv2 12 -- $100.00 -- $25.00 Zv2 15 -- $110.00 -- $30.00 Zv2 18 -- $120.00 -- $40.00 * Copper or Aluminum Coils Available * Z v.3 Spider Pack Now Standard (5/1/12) * MUST USE Z v.3 SPACER * Add $10 for NS v.3 Spider Pack * D1 / D2 Available Z v.3 10" -- $115.00 -- $20.00 Z v.3 12" -- $115.00 -- $25.00 Z v.3 15" -- $125.00 -- $30.00 Z v.3 18" -- $135.00 -- $40.00 * D1 / D2 Available (SPL COIL Available) * Add $10 for NS v.3 Spider Pack or "Traditional" 3H NS Pack * The 10/12 models use a different coil than the 15/18 models * The SPL coil can ONLY be used on the 10/12 with the "Traditional" 3H NS Pack !!!! IMPORTANT NOTE : YOU MUST USE OUR NEWEST 12-spoke 15" FRAMES TO USE THE Z v.3 OR NS v.3 SPIDER PACKS !!!! They are 8 3/8" spiders and require a modified top landing. The other spiders for 10/12 and the 18 are compatible with any 12-spoke / 6-spoke that I am aware of. Also -- the NS cone will NOT be offered on ANY drivers with a v.3 style spider pack in 15s or 18s. The v.3 spiders (Z v.3 and NS v.3) can exceed the mechanical limits of the NS style cones in these sizes. ----------- NEW PLATFORM PRODUCTS : MODEL -- RE-CONE Price -- FRAME Price X-10 -- $130.00 -- $50.00 X-12 -- $135.00 -- $60.00 X-15 -- $140.00 -- $80.00 X-18 -- $155.00 -- $50.00 * 18" Use the Standard 6-Spoke Frame w/ a 257mm Spider Adapter; the $50 frame price includes this adapter * D2 and D4 Coils Available (CCAW Round Wire) * Add $10.00 for Z v.4 Stiffness Spider * Add $20.00 for NS v.3 Stiffness Spider Z v.4 10 -- $150.00 -- $50.00 Z v.4 12 -- $155.00 -- $60.00 Z v.4 15 -- $160.00 -- $80.00 Z v.4 18 -- $175.00 -- $50.00 * 18" Use the Standard 6-Spoke Frame w/ a 257mm Spider Adapter; the $50 frame price includes this adapter * D1 and D2 Coils Available * Softer X Spider Available - NO EXTRA CHARGE * Add $10.00 for NS v.3 Stiffness Spider NS v.3 10 -- TBA NS v.3 12 -- TBA NS v.3 15 -- TBA NS v.3 18 -- TBA * -- Both the X and Z v.4 kits / Frames can be retrofit into the NS v.1, NS v.2, and Z v.3 motors; these motors cannot handle the FULL capacity of the new soft parts so a hard bottom is possible. ** -- SPL kits are in development with a different cone and spider type. Pricing is TBA on those. *** -- The Z v.2 motor bolt pattern is compatible with the new platforms as well but we do not suggest it as it has a limited amount of rearward travel (41mm). * The new baskets are BOLT PATTERN compatible with any of our 3" coil motors to-date. They use the standard 127mm pattern so can be used on MANY other products.
