sundownz
Vendors
    8,101
  • Days Won
    7
Everything posted by sundownz
  1. sundownz
    John, There is a mis-print regarding power wire size on the SAE-1000D. It accepts 4 gauge wire. I have it updated on the site, but on the print materials it still says 1/0 by mistake. http://www.sundownaudio.com/pp1000d.html So yes, you can trim wire to make it fit no problem.
  2. sundownz
    IM SO (kinda) PISSED
    He may have a spare around, if he does not contact Steve @ Smart Auto Sound and I'll send some spares up to Canada through him.
  3. sundownz
    Does Anyone Know what this sub is...
    Looks like an XBL^2 or underhung motor... don't know what it is exactly.
  4. sundownz
    Would you guys buy amps or subs off ebay?
    I've only had one problem on e-bay as a buyer and I got it worked out... albeit 3 months later. Indo Audio sent me the wrong Phoenix Gold EQ and it took about 3 months to get the right one, but I did eventually get it. Now... as a seller. I have almost been scammed twice. Both times buyers bought items, received them, never contacted me about anything, and filed charge-back reports. I won both cases because I followed everything on my end... still a huge PITA.
  5. sundownz
    Indeed... I have been listing a few amps on e-bay lately. Used, b-stock, and refurbished goods. The results have been pretty good so far and it's helping me move the amps I have laying around here.
  6. Sounds like it should be fine as long as you aren't sending too much RCA voltage into the 1500D through the line driver. The behavior you are experiencing *may* be some kind of protection in the line-driver unit to keep people from damaging their equipment. That is my only guess as to why it would begin to decrease the output level.
  7. sundownz
    New Sundown owner here
    There really is no reason to get the TC3K unless you want an SAZ-1500D per sub as the TC2K will do everything the 3K will at your power level. The FI SSD is another solid option. They do well on lower power as they are quite efficient, not that they won't handle more, but they don't really need it
  8. sundownz
    Yah, that LED seems to be really problematic... which is odd since I haven't heard of any problems with the power LED in the amp which is pretty much the same thing.
  9. sundownz
    electrical upgrades?
    At 1 ohm? A healthy factory alternator and a large and relatively new 1000 CA primary battery will do fine. Just be sure to upgrade the big three and run at least a 2 gauge power wire (1/0 is preferred).
  10. sundownz
    in love
    Yep, that is plenty.
  11. sundownz
    saz-1500d
    No shirts yet. They are a bit pricey and product development is ahead of shirts in my "to-do" list at the moment
  12. sundownz
    in love
    Do you mean that you have an underhood battery AND an HC1800 battery? Depending on how much of a basshead you are that might work fine. Your 105 amp alternator is a big limiting factor... and also, can you fit an HC2400? That would be much better suited to 3,000+ watts.
  13. sundownz
    Wiring options for 100.2
    Correct, the 100.2 will not handle a 2 ohm bridged load. It is 4 ohm stable in bridged mode, or 2 ohm stable in stereo mode. Your only option for stable wiring on the 100.2 is 8 ohms bridged.
  14. sundownz
    saz-1500d
    Indeed... I need to look into doing something in the manual. It seems obvious to me, but I guess that is because I make the amps.
  15. sundownz
    Canadian Sundown/Bassworx Big Bass Packages!!
    Steve will have these packages going for a while.
  16. And yes... that is a Lucinda Williams CD. I forgot to decline that one from BMG Music so I got it *laughs* Oh well, it earned me two free CDs with them
  17. sundownz
    saz-1500d
    I've been to Oak Island if that counts I'm in Mooresville, a pretty good drive from you.
  18. sundownz
    saz-1500d
    It does not matter. The + terminals are connected together inside as are the - terminals.
  19. sundownz
    Yo Jacob
    I am dealing with the circle problem right now. My jigsaw is not having fun cutting through 2.25 inches of mdf. The most my jigsaw has done is 1.5" and that was about it's maximum. You should probably cut one sheet at a time I need one of those jigs like Rich has for the router. That is the only way to do it if you do much box building at all.
  20. sundownz
    Got 2nd place today
    Congrats! What was your actual score?
  21. sundownz
    http://www.tcsounds.com/tc2000.htm 2x TC-2000 15" Dual 4 ohm Coils Wire all four coils in parallel for a 1 ohm load. Those subs would be okay sealed but really cry out for porting.
  22. sundownz
    Do you have a budget in mind for the 15s? That will help alot in picking them out
  23. sundownz
    No reason for a line driver in your system. Take it out, 2 volts is just fine. Less items in the signal chain the better, IMHO
  24. sundownz
    It does have remote knob and manual. The knob is a remote gain.
  25. sundownz
    The factory refurbished units have a 90-day warranty, if you look at the auction page it has the information. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...p;rd=1&rd=1 Right below item description.
