8,101 -
Days Won
7
Content Type
Profiles
Forums
Gallery
Everything posted by sundownz
Any update on the possible release of the next models of amps?
sundownz replied to helotaxi's topic in Sundown Audio
Rockford 3Sixty.2 for the win, that is all I had a world class sounding system in my BMW (when I had it) with the factory head unit. Nick at Stereo Integrity couldn't believe how great is sounded with factory HU and factory speaker placement, thanks to the 3Sixty.2 unit. A 5-channel will NOT be out be years end, I will tell you that up front. The SAE-50.4 may be out by then, though. I am working on giving it as much crossover flexibility as possible, but we'll have to see how much I can get in it at it's price point. Since the 50.4 is an SAE amp you may want to consider the SAE-1000D to match heatsink wise if that is important to you. -
Oops... typo! I meant to write SAX-250.2 prototype. Rated is 1000 watts @ 4 ohms. So, it did exceed that number. I am revising the existing 250.2 board stronger power supply FETs, higher voltage caps, and a much better crossover. Of course, the existing proto ran on a 1.9 ohm DCR for well over an hour when I was testing it so it's durable as it is. Still looking at next year for it, though You know I test everything extensively. With the revisions it should do everything I want it to without resorting to an incredibly large chassis. So far I don't have anything planned for a 5-channel, but perhaps a 6-channel where you could bridge channels 5+6 for 600 watts @ 4 ohms. This would be useful, also, for 3-way active setups and whatnot. I'll put it on my "to-do" list to see if I can possible get something like the SAE-1000D and SAX-100.4 in one chassis... unfortunatly I am fairly certain I would have to lose several of the crossovers features to fit in any controls for the D-Class channel. If you have seen the 100.4 you know it's end-panel is already stuffed full. -
It is likely that you could hurt them depending on frequency and box tuning. Just start out slow and learn the limits of the sub. Rob is a great guy and I hated to see him have to sell off his gear, but "real life" is always more important than hobbies
Yah, my other Civic is like that too... it's a bummer. I took it out completely and will have 2x HC2400 Kinetiks inside the car behind the front seats daily. I'll drop in a few more for comps I think you can still get a slightly larger battery if you modify the bracket... not 100% on that one, though. I do know that some SPL guys remove the stock airbox completely and stick a battery where that is located.
WinISD shows the 10" SD-1 woofer to be flattest tuned to 25 Hz. Increase the box to 1.5 ft^3 and drop tuning to 22 Hz and you get an F6 of 25 Hz with the 10" SD-1. The 12" SD-1 has an F3 of 38Hz in a large sealed box (3 cubes). It would actually do really well IB in a ceiling install for a home setup. It would also lend itself to isobaric sealed installs in the car, and for those who like more upper-end "boom" a smaller sealed box works fine as well. Qts is a tad high for porting IMHO, but people port woofers with much higher Q all the time these days. It would be incredibly loud ported as it tends to peak hard in moderate sized enclosures. LoL, yes yes... my mistake
Below is the box Rich built for the Civic: * Talk about prevision fit, the trunk arms actually contact the carpet But not enough to hurt anything, it closes smoothly. * Wider shot. ---- This way I can still utilize the whole trunk and not worry about smacking my woofers with boxes. I can even stack a think package on top of the box!
If your under-hood setup looks at all like mine you can fit a pretty big battery in there. I had to slot the mounting bracket so I could position the bolts a bit wider. I also had to remove the very tip end of the "cold air induction" hose that is on there from the factory. I haven't notice any decrease in gas mileage or performance, and I track every tank of gas If you look closely you will note that I soldered every ring terminal on there. I learned a hard lesson in my brothers truck after yanking the wire out of several ring terminals... solder them always!
They love low tuning, and with isobaric mounting the box requirement would be extremely small. I'd say 25 Hz tuning is as low as you really need to go for any car application, though
Hint... they throw down hard ported, tuned low Rich was kind enough to build a box to my specs for the SD-1s tuned in the 30s. I also tested them in a double flared box my brother built tuned dead on at 30 Hz and a bit larger than the one Rich made for me and the extension was even lower. That box was a bit large for my application, though, as I stuff my trunk full of amps every day The SD-1 is a keeper. I will be running two of the 10" SD-1s on a daily basis in my primary car if that tells you anything.
Thanks for the review Rich I am looking forward to hearing more about your 12s when you make the box for them.
Indeed, much larger than the 100.4 and cost gets out of line with what people really want to spend. I might consider a 150.4 or something along those lines, though. Much more reasonable to build. A 250.4 would be a 2000-watt RMS A/B amp when bridged at 4 ohms... that would be *expensive* I'm guessing around $1200 or so MSRP if I built it. --- Oh yah... I tested the 250.5 proto a bit yesterday. I got 1092 watts @ 4.85 ohms actual load with 13.8 volts dropping to 12.45 volts. The DCR of the load was 1.9 ohms (DD 9512 Dual 4 in parallel) -- it was the only way I could get anywhere near 4 ohms actual in my single sub test box. Using a nominal 4 ohm load (TC9 based D2 sub in series) I got as high as 618 watts @ 12.34 ohms actual load. -
Honda batteries are TINY too... I crammed a large battery under the hood of my 02' Civic and I only had to modify the top bracket, nothing else I'll have to get some pics up later, might work in your car too.
Nope, it's not a high current amp. I've been thinking of making an SAZ multi-channel that is high current in 2009 or so. -
4 gauge will run the amp, but it is pushing it for a long run.
Water proof Jacob.. Waterproof... you'll have a winner for sure *goes to find my surfboard wax) What kinda output you were thinking at (stereo and bridged) ? I want to do it's rating at 12.5 volts no sweat... 250 x 2 @ 4 ohms and 1000 x 1 @ 4 ohms. That is the idea -
There won't be any options at first. It's pretty tough to get a quality SPL sub out at all It's going to have a ridiculously hard paper based cone.
Indeed, that may be the case. I finally got rid of most of these used, b-stock, and refurbs though
My auctions are ending at insanely low prices tonight... not sure why there aren't more bidders. But some people got ridiculously good deals today.
DD offers the new composite cones, try one of those Should hold up to the pressure better than the regular paper.
had 2 death's in the family. other one died today
sundownz replied to stevew007's topic in Sundown Audio
Ouch! -
Seems alot of folks are interested in the 250.2 in the net' market. MSRP is going to be around $499 - $599 on it when it is released depending on what metal prices look like by that time and how much I beef it up from the proto. I really want the 250.2 to be a monster... like the 100.2 but 250% bigger Do you guys care if it's a surf board? -
Indeed... I've been waiting on the modified coil for a while. I am also working on arrangements to have the Nightshade assembled in the USA as well... so it'll take some time
Larry, Most companies don't consider it a b-stock type defect as it doesn't seriously hamper performance. I am a little more picky than most and pull them aside if I catch it as I inspect each amp before it ships out of here. I am trying to work out something with the factory to avoid the alignment problem but it's such a fine part and tight tolerance that it is difficult to get them 100% straight all the time. Until they can do that... I'll have B-Stocks from time to time. It is still only around 1% that are mis-aligned enough to look off, but thats too much for me
How much did it go for Jake? Only $150 for that thing! No love for the Matrix Elite I guess.
Note the model number "SAE" -- it's a different series. These are the "entry level" line and other amps to match them are in the works, specifically an SAE-50.4 and SAE-75.2 model. They will all have matching heatsinks with one another.
