sundownz
Vendors
    8,101
  • Days Won
    7
Everything posted by sundownz
  1. sundownz
    SD-1 v.2 10" Pre-Order OPEN
    Just a few more days
  2. sundownz
    question about the SD1 v1 10"
    1) Yes, you can tune them to 28 Hz -- use the larger end of the spectrum at 1.25 ft^3 each. That gives a very good response. 2) Use 25 - 30 in^2 of area. At 25 in^2 that is 30" long, at 30 in^2 that is 36.5" long for your 28 Hz tuning.
  3. sundownz
    d unit problems
    u mean my remote going to my amp?if so ill check.u ever known of someone haven that kind of problem w alpines? Maybe I understood you wrong, the amp shuts off or the radio? If the radio... then thats different. I would check your radio wiring, sounds to me like a wire is loose and is intermittently losing connection. Probably the main power or ground to the radio. I have not heard of a particular problem with Alpine head units doing anything like that, no.
  4. sundownz
    Refurb?
    I sell several types of amps on the forum: 1) Used -- Either traded in from the Team or a friend, or I may have had it on display at a show or used it myself. For whatever reason I sometimes end up with an amp that has been used at one point. These are usually sold with a 1-year warranty. 2) B-Stock -- These amps have cosmetic damage from the factory, otherwise they are brand new. These are usually sold with a 1-year warranty. 3) Refurbished -- Usually returned from a customer for warranty work, I almost always send a brand new replacement to the customer. The refurbished amp is the "old amp" from the customer after it has been repaired and fully tested. These are usually sold with a 90-day warranty. Reliability has been fine on the refurbished. I have them repaired by a very good technician, he tests his work, then I test it again after him.
  5. sundownz
    Cut out is 9 1/8"
  6. sundownz
    d unit problems
    Maybe your remote lead is loose somewhere ?
  7. Lots of things sold. Will update the list with a few b-stock items in the next few days.
  8. sundownz
    100.4 6-channel wiring question
    Oh... you are talking about running "tri-mode" on each set of channels eh ? If so... then you won't be able to use the crossovers on the amp without have weird response from the coaxials. Rarely someone would want to do this to run speakers and a woofer from the amp... but it requires passives to be effective.
  9. sundownz
    If your front components have passive crossovers thats fine.
  10. sundownz
    200 amp HO Alternator settup
    You can run 16v daily but you need a separate 12v system -- this means one 12v alternator and another 16v alternator.
  11. sundownz
    BIG UPDATE ON 2008 LINE UP!
    Everyone loves re-cones... can I guess who Brand X is? *laughs*
  12. sundownz
    whats the best rca's to use w my 1500d?
    Yah, the Esoteric work well and look pretty I use all kinds of cheapy Scosche and generic RCAs in my SPL truck, they work great.
  13. Still a good bit off... that still wasn't quite what I wanted out of it. Better cooling and suspension will happen before production.
  14. Several prototype and re-built subwoofers added
  15. sundownz
    Sundown Audio Nightshade Numbers
    no. you cannot possibly state that with the info given. the spl 12 is a potent driver. I'm sure the nightshade will be very nice as well, but it will be install dependant. bottom line- there isn't near enough info to state anything of that nature, just yet. Sorry, I should have clarified, I meant in size and beefiness of the sub, not in numbers necessarily. Either way I am sure it will give either of those 2 a run for their money and adds another option to Fi, DD, RE, Mach 5, Audioque and Treo for an awesome SPL sub. Indeed, it is quite beefy. Measurement wize I think it is larger than any of those with triple 1" x 9" slugs. Size isn't everything as I did not over-motor the sub. It is made to be listenable with acceptable box response daily, since I realize not everyone competes in SPL, so every tenth of SPL output was not the prime target -- it has a 0.40 Qts and an Fs of 38-40 Hz after break-in time on the 12" model. It should do quite well on the meter still, though, the motor is as strong as many competitive subs that I have measured like the DD 9500F and the BTL.
  16. sundownz
    Pre-order over in only 8 days, get em now if you want this price
  17. sundownz
    Jim, Some of the expensive ones don't make good contact with the ground pin for some reason. --- The cheapy RCA cables always work
  18. sundownz
    Huge Sundown Vinyls
    That is the second largest Sundown Audio sticker I have seen, nice
  19. sundownz
    Huge Sundown Vinyls
    I need a design for shirts... black shirt with white print. LMK what you come up with
  20. sundownz
    I just cleaned it a few days before that picture *laughs*
  21. sundownz
    8 inch woofer?
    I'm quite happy with the result... I may even use these in my Civic daily since I can make a narrower box and save trunk space.
  22. sundownz
    *laughs* One can only go so fast when it has to be just right
  23. sundownz
    It is a beast alright I'm very pleased... hoping to get them to production soon in 12" and 15" sizes initially.
  24. sundownz
    Purchase SAZ-1500
    SSA has a store: http://www.soundsolutionsaudio.com/shop/in...mp;productId=20 E-Mail them for their best price.
