8,101 -
Days Won
7
Content Type
Profiles
Forums
Gallery
Everything posted by sundownz
PWNT
Check them out... I think he wanted his doors to match his teeth... that is the word on the street.
If your bank account is linked the balance should come out of the account instantly.
Where ? I don't see one here.
Is this why a certain competitor is running a bunch of the 2 channels instead of a few 4 channels? Perhaps - that, and he wanted the most possible channel separation - totally different amps works well for that
Not much difference to you if you are not using the internal crossovers.
I don't think the gold is going to stay
SAX-100.4 is still SAX-100.4 but on the bottom there is a revision letter after the part number. SAX-100.4 SAX-100.4b SAX-100.4c SAX-100.4d
I'm sure he will
LoL - that is what he is doing right now until the door poppers are installed.
Indeed... two 1500s is a bit stronger than one 3000D -- but the 3500D changes the game and is roughly as strong as two 1500s.
2204 watts @ 3.26 ohms on your highest power level... yep, you are getting some clipping From 50-60 Hz your clamp is probably most accurate as it was designed for home AC measurements. IMO... just set the gains by ear - you have a pretty low distortion woofer, you will probably hear the amp clipping when it does.
Burnt leads on an E8 ? That is something I've never seen - even when we plugged them in to the wall socket. Any pics of that ?
Door handle ? There isn't one inside
All of the SAX amps use the Sanken FETs -- the 125.2/100.2 use the most of them per channel, though
I snapped this real quick of one of my runs - 2550 watts: My meter measures about 5-6 seconds into the burp and is a True Power meter. It says "2.55 kw" in case you can't tell due to the blurry-ness.
I posted too soon... while I was uploading I let the Jeep run and charge and the 1500D put out 2640 watts and 150.0 dB exactly
2495 watts @ 149.9 dB - (One SAZ-1500D on 17.9v) So with just a hair over rated power I am darn near 150 dB on two Z15s. Not too bad, huh ? That 1500D sure is putting out the power... I averaged two 149.9 dB runs (2420 one run / 2570 the next) to get the above power figure.
~65 x 4
What do you want to know ? The SAX multi-channels are being adopted into SQ competition in the USA now so they do well for SQ as well.
That was Dave Edwards old install - it was a big Phoenix Gold amp. He is working on going to all Sundown amps
Two used amps pending sale... That leaves one available.
Now is the time for everyone who voted to get in on the $425 price before April 18th
These are still here : * 3x Good Condition New Casing -- Used Amplifiers * $675 each w/ 1-year warranty
