sundownz
Vendors
    8,101
  • Days Won
    7
Everything posted by sundownz
  1. sundownz
    Prototype "SA" Series
    It would work quite well as long as your box is right Box being right as in 1.75-2 cu per sub? Tuned high or low? Yah, about 1.75 per tuned low would work well.
  2. sundownz
    For Diablo........And Jacob
    I'll check e-mails Monday - but damn that woofer is messed up!
  3. This is a Nightshade w/ cooling and 50mm WW 8-layer coil with a prototype cone we are testing. Coil is Dual-1 configuration. It includes the latest bolted down spider upgrade and utilizes a 3-layer spider. $400 for this prototype, shipped in continental 48 - there is only one like it right now.
  4. sundownz
    Prototype Nightshade For Sale - 15"
    Not sure if anyone has tried a Nightshade in a T-Line.
  5. sundownz
    Figuring out the last details on packaging before we start.
  6. sundownz
    Pre-Sale will be under 200
  7. sundownz
    Pre-Sale to begin shortly guys Keep your eyes peeled!
  8. sundownz
    They will be coming in around the same time.
  9. sundownz
  10. sundownz
    I have one more used 1000D but the RCA panel is dented a bit - I am going to test it to make sure all is okay.
  11. sundownz
    No - I have not started testing the SA-15 yet. Only D4 - I have not tested D2 yet.
  12. sundownz
    It takes 60-90 days to get a woofer once production starts.
  13. sundownz
    amp installation options (opinions welcome)
    The sides are wide open and the boards are not flush - ventilation should be fine.
  14. sundownz
    Production starting soon... 12" D4 will be first. Who wants some ?!
  15. sundownz
    SAZ-3500D Pre-Order
    any more info on the release date? I will post if there is - we still expect them early May.
  16. sundownz
    SAZ-3500D Pre-Order
    I am anxious to get these in and shipping! Don't miss out - be sure to get your pre-order in soon!
  17. sundownz
    wiring kit question
    For both amps I'd use a ~250 amp fuse. Use a 200-amp fuse in the back on the 2000D -- the 100.4 has it's own internal fuses already.
  18. sundownz
    Older Sundown 3000D?
    Perhaps... but it would take more than 800 more watts to gain one dB -- less than one dB and you won't hear it
  19. sundownz
    New to Sundown - UK member
    Welcome to the forum
  20. sundownz
    SAZ-2000D Pre-Sale OPEN
    They are just like a 1500D but more powerful - think of it that way
  21. sundownz
    SAE-1200D Sale Pricing
    SAE-1200D sale pricing for $350 is back again until the end of March. These amps are starting to gain in popularity and we really want to see some more customers post up reviews on them, so we are bringing the sale price back. You can contact your favorite dealer OR Paypal us directly at [email protected] to order! These are under-rated amps and can produce 1500 watts RMS @ 1 ohm --- The SAE-1200D is the first in the new generation of "SAE" line amplifiers from Sundown Audio designed to offer the best value possible. The SAE-1200D is designed to produce it's full 1200 watts of rated output at 12.8 volts! As with our SAZ line sound quality was just as much concern as power output so the SAE-1200D will not disappoint in this regard. The SAE line comes with the same warranty and service that our customers have come to expect from Sundown Audio, all at a more affordable price than ever. SPECIFICATIONS: o 1200 x 1 watts @ 1 ohm o 600 x 1 watts @ 2 ohms o 300 x 1 watts @ 4 ohms o 0.153v - 5.6v adjustable input sensitivity o 15 Hz - 250 Hz Frequency Response o > 90 dB S/N Ratio o 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current) o 50 Hz - 250 Hz adjustable 12dB Low-Pass Crossover o 15 Hz - 50 Hz adjustable 12dB Subsonic Filter o 0 or 180 degree adjustable phase switch o 0 - 12 dB adjustable bass boost with 60 Hz center frequency o Wired Remote Control unit included o 5x 30 Amp Internal Fuses o 17" L x 10.6" W x 2.2" H o MSRP $549 USD
  22. Regular MSRP $349. Special price $225 until end of March! You can order from your favorite dealer OR Paypal me directly at [email protected] Rated power output ----RMS power, 4 ohm stereo 50W x 4CH ----RMS power, 2 ohm stereo 80W x 4CH ----RMS power, 4 ohm bridged 160W x 2CH Signal to Noise Ratio >90dB Low pass frequency crossover 50Hz~500Hz (CH1&2) 50Hz~5KHz (CH3&4) High Pass Crossover 50Hz~5KHz (CH1&2) 50Hz~500Hz (CH3&4) Variable Subsonic Filter 10Hz to 500Hz Bass Boost 0~18dB Variable Bass-Boost Frequency Control 35Hz to 120Hz Frequency Response 10Hz ~ 40KHz (+/-1dB) THD@RMS Watts <0.1% Channel Separation 75dB Fuse Rating 25A x 2 Input Sensitivity Variable 200mV~6V (+/- 5%) Dimensions 252(W) x 58(H) x 310(L)mm
  23. sundownz
    SAX-50.4 Sale Until End of March!
    Tomorrow is the last day!
  24. sundownz
