8,101 -
Days Won
7
Content Type
Profiles
Forums
Gallery
Everything posted by sundownz
Yah, it'll have it.
Did you order an 18 ?
A pole vent (hole) by itself is not very good cooling. We noticed a big improvement with the plastic cooling plug - and the aluminum is just a better version of that.
Nightshade only.
Decided to open it up with super early pricing : http://www.soundsolutionsaudio.com/forum/i...showtopic=28844
So... who would do it ? Lets say if this amp was a full 1 dB louder than even the SAZ-3500D on 12v @ 1 ohm... and the 3500D was already 1 dB louder than the 3000D. Maybe it's already been in testing for a while So we are talking ~2dB gain from the SAZ-3000D on this bad boy. Pre-Order price would be around $1200 or so shipped. Lets see a show of hands.
I don't have any plans to make a sub to handle 5kw daily -- IMO, the suspension would be so stiff it would be incredibly inefficient. I see no reason to use 5kw to do the same thing you can do with 2kw
33mm -- I have a few old motors here and they just barely don't fit.
Re-directs air flow behind the former for better cooling -- a pole vent by itself is not a very effective cooling method. You may notice on the Fi subs the BL and BTL have no pole vents,
Indeed First two built with the plugs - picked up today!
Hmmm... the aluminum may not fit then. If you *really* must have them I can probably get them machined down a bit.
If your motors are not the very first run they will fit. I am assuming if we talked about it they are not that old ?
It will not fit original motors - the pole is a bit too small. We CAN add the plastic plugs to any generation motor and they work quite well anyway as we have used a few 100
Starting today it is standard on all drivers.
Next year spring break ? That may be possible.
Hard to say just yet - with pre-orders most orders rush in at the end.
I love that box!
From amp to sub use 12 awg.
They will be - working on the details of that. I couldn't bring myself to make an amp with vertical FETs... just don't like it.
Yep! I have parts coming in with the shipment
Two MOJOs would work nicely on this amp. Check out Knu Konceptz : http://www.knukonceptz.com/ I suggest simply using the low-end Klarity RCAs and using the Kolossus Fleks 1/0 cable for power and ground.
Remember these won't be in until late October - you can get your 3500D 2 months sooner.
Who needs furniture ? Cinder blocks + lumber FTW.
Regular price will be about $1549 MAP / $2149 MSRP.
