133 -
Content Type
Profiles
Forums
Gallery
Everything posted by weasle421
if he isn't buying right away a SI BM would work too and at $150-200 way under budget. and .5 sealed makes it able to go just about anywhere.
They have said quite a few times that they are the same for the new BTL's as well.
considering the sourece i don't know a lot, but that don't look like a neo motor to me sorry for the small pic, apparently i did something wrong that is a 10" sub btw.
Welcome to SSA. this should be benificial for all
Panasonic CQ-C7370U...
weasle421 replied to oldschool4life's topic in Amplifiers / Head Units / Processors / Electrical
i have an older 5305 and no problems. been running 2ohm on all 4 channels for around 2 years now gets hott but thats about it -
he wanted do do 59 bassrace
Happy Birthday Man!
but the sae's are meant for daily systems the saz's are for the spl crowd
eh thier cheap enough (cost) to replace every few months...lol I didn't even think about load when i mentioned the SI subs but 2 mags at .5 dialed way down would probably work well I belive they arre expecting the mags to be in in the next 2-3 weeks and the BM proto, so it may be awhile on the BM's
sux man...bout the same luck i have, try to fix it and it never works again...
just ignore me i'm bored nothing to cut on this router and whoring
may need the power to get out of a hole or 3
but it can be fun
what about the new mag or bm? mag should be avaliable in a month or so, production has started
belive it was 14.5 was the voltage after drop
I put no before i read the thread. And only said no because the saz lines were overbuilt and abble to do low loads. So if the 100 gets "upgreded" internally then i would have to say yes
trial and error as different formulas of mdf are gonna act different and most just use good wood glue to fill and strengthen
perfect 3 way active amp^^^^ why do I have to be broke...
Need 3.5k - 4k rms for (2) DD3512
weasle421 replied to curiouslooker's topic in Amplifiers / Head Units / Processors / Electrical
quick answer would be a sundown 3000d but they are out of stock ATM, wo't be till august when he gets more -
Bad idea?
weasle421 replied to mccleery3's topic in Amplifiers / Head Units / Processors / Electrical
the 1500d would be fine for the icons as for .5 daily i don't think you have enough current to do it safley and it would be the amp that fries not the alt -
no sub amps?
I would venture to say unless you are burping the power diff isn't gonna be enough to matter. But the single gain makes it nicer IMO, plus if the subs are in a common chanber box, would almost have to strap.
and sean has had that crx for years and knows how to get loud in it....... iirc he has done over a 150 with 2 xcite 8's think i'm gonna have to grab 2 for my frontier..no bass is getting old now if sean will just share the specs on that bandpass....
