1,421 -
Days Won
1
Content Type
Profiles
Forums
Gallery
Everything posted by mrogowski
You're dead.
How's the back? Me =
Help, TC1000 15" for HT use box parameters 4ohm 300w with winisd
mrogowski replied to smokinkane's topic in Home Audio
Have you considered going with a Sonotube rather than building a box? They're cheap and you can get yourself going within a few hours. Sub on the bottom, port on top. Best, Mark -
If you want to shop Canadian, check out what McBride has: http://www.loudspeakers.ca/products.htm Best, Mark
Yes, no problem. Perhaps look into snagging a Sonotube - good, cheap and easy to put together. Best, Mark
You guys should have seen my house when I was running sweeps with that setup... The magic frequency was 28Hz. EVERYTHING was moving.
My thoughts on using a plate amp in home and going active
mrogowski replied to topgun's topic in General Audio
Well, that way you can concentrate on the data lines and output filtering. Plus, it would be cheaper since they won't be paying more for XLR connectors. You can buy more tubes then.. -
I know, but wouldn't it be ultra cool if you didn't have to do that?... -
I find the 2496 to be a very powerful unit. All Behringer has to do is come out with a home audio version and get rid of those XLRs... One thing I can't understand tho is the folks who buy the Behringer 2496, EQ AND Feedback Destroyer. Why bother when you have all those options in the 2496? You don't need the other units. And yes, a watt does not equal a watt. That's why I'm running Crest on my bottoms... -
Agreed. It seemd that there are more movies coming out with alot of the ultra low stuff. I can't see it making THAT much of a difference. You will still get usable bass down low, and if you EQ it, who cares? Best, Mark
The whole trick to doing a HT sub is to build big and tune low. There is much more usable information in the nether regions as compared to straight audio, so you want to get as much of this as you can. If you can sacrifice going a bit bigger, 3 cubes tunes to 22Hz should give you good output for HT. Best, Mark
For sure, keep us updated on it. I still have to fix up the pictures on the blog...
Suck it up and buy a new one! Sorry to hear that - I DESPISE car repairs in any form, simply because everytime I took my old Lumina into the garage for something minor, it ended up costing me over $1000. This was EVERYTIME... I know, I know..... Alts can sure get expensive too...
If it were me I would do a single 6". Given its length and the fact that you will be faced with using an elbow, perhaps revisit the slot option. You will end up using roughly the same amount of space inside the box either doing tube or slot, so whichever way is easiest for you... Best, Mark
With those choices I would choose the dual 3". They will still be noisey, but at least you are pushing the noise down to lower freqencies. Best, Mark
There should be a rule that states lurkers who lurk for more than a year get an automatic 1000 post count.
Should be interesting...
That's it, tell her who's boss!
Hi Steve, Loyd has made some suggestions that may affect the overall cost of the unit. So currently, I cannot say for certain what the final cost will be. What I can tell you is it will not be as much as a DD Best regards, Mark
ah.
Yeah, the language of the bigbassman can sometimes be difficult to interpret: washer = top plate (the metal plate you see between the basket and the magnet) t-yoke = the backplate with the shaft going up the middle of the magnet structure
Welcome!
Yeah, sorry for the massive delay here. What should have taken a week has now taken a month. Not passing blame, but this homeland security thing is really getting out of hand... The shipment sat in Tacoma for two weeks while the ship it was on got a thorough lookover by customs. Then on to New York, where the shipment is getting yet another anal probe. Its there now so its not far away... Best, Mark
