mrogowski
SSA Regular
    1,421
  • Days Won
    1
Everything posted by mrogowski
  1. mrogowski
    Time for some fun
    You owe me a case of beer from Paddock Wood now.
  2. mrogowski
    Time for some fun
    Ok, that depth should pretty much do it. (internal) dimensions - 23"W x 28"D x 72"H = 26.8 cubes Sub area = 24 cubes tuned to 18Hz Port size - 5" x 23" x 33" long = 2.2 cubes Add R8 fibreglass on 3 sides Here's things with 1000 watts of power: Excursion SPL Port velocity
  3. mrogowski
    Time for some fun
    Then you need 24 cubes (plus space for port) in order to achieve that. If you can get it, tune it to 18Hz.
  4. mrogowski
    Time for some fun
    Gotta go bigger then. 22 cubes + Trust me, that will have plenty of output for you. Remember, you're dealing with four 18's with room gain...
  5. mrogowski
    Time for some fun
    Ok, Based on the above dimensions, I would suggest the following: - 16.3 cubes gross - Port tuning to 21Hz - Port size is 4.5" x 23" x 38" long; port it at the top of the cabinet rear - Add R8 fibreglass to back and sides You're good to go. Now GIMME MY MONEY!
  6. mrogowski
    Time for some fun
    You haven't received my bill yet
  7. mrogowski
    SPL-15's, IXL's Finally In!!
    The IXL-18 now comes in a dual 2 Ohm config, and I have LOTS of them.
  8. mrogowski
    SPL-15, IXL-10, IXL-12:
  9. mrogowski
    Input on 8's
    Alright, Aaron has pushed me to start looking into this... I would like to hear your input on what it is you would like to see in an 8" size. There are so many brands to chose from nowadays, from big-box companies to boutique 'internet-only' proprietorships. Some really good, some not so good. What is it about the 8" you purchased that made you decide to get it? Best, Mark
  10. mrogowski
    Time for some fun
    Based on your dimensions (23" x 17" x 72") you have about 16.3 cubes to work with per side. Does this sound about right? Give me a couple of days to determine the final TS parameters of the drivers and then we can do some modeling.
  11. mrogowski
    Time for some fun
    Based on your diagram, what are your dimensions for the sub boxes? What is your effective box volume?
  12. mrogowski
    Input on 8's
    Not yet. Put on the back-burner for awhile until I can come back to it...
  13. mrogowski
    Time for some fun
    Forgive me, I didn't read that part. Carry on...
  14. mrogowski
    Time for some fun
    Forget the MDF unless you plan to do some cabinet finishing. If its sheer cabinet strength you're after, go with ply - Fir or something else.
  15. mrogowski
    Dennis' Mach 5 Bitch Van Build Log
    One down, one to go
  16. mrogowski
    Box Design
    Coil1 ---> Coil2 ---> Amp '+' ------> '+' ----> '+' '-' --------> '-' ----> '-'
  17. mrogowski
    Box Design
    Click on the bottom picture on the IXL-15 page - it shows the dimensions there.
  18. mrogowski
    MAW-15 Ported
    You can try it, but on a personal note, I would go slightly bigger - say 2.5 cubes. Best, Mark
  19. mrogowski
    The baffle is done up along with the port. I will only add the one window brace you see here. Just waiting for the glue to dry before adding it.
  20. mrogowski
    Tomorrow I will work on bracing, port and baffle. I'll throw up more pictures tomorrow on the progress.
  21. mrogowski
    Phase 2 With the plywood sheets glued, its cutting and assembling time. What you see here is one half of the build. There will be two of these boxes that will slide into Dennis' van. The board leaning up against the box is the baffle. The box is tapered (difficult to see) - with the top is shallower than the bottom. A shot of the port hole. These cabinets will be tuned to 36Hz. You can see some of Dennis' IXL's in the background.
  22. mrogowski
    ixl 15
    If it is volume you are after, you can use the same size box as per the recommendation but tune high - 36Hz or so. The recommended tuning of 28Hz is geared more for sound quality installs where folks wish to hear the sub through a majority of the passband with some augmentation by the port at lower frequencies. Best, Mark
  23. mrogowski
    Nightshade Recone
    And you call yourself an EE
  24. mrogowski
    ixl 15
    True, scope out Sundown to see what they have.
  25. mrogowski
    mach 5 audio
    I agree. I had a line on one that sounded quite smooth. Unfortunately, things fell through so I'm back at square one...
